• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » Missing registry keys after C2000 Code Generation Tool Installation
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • Missing registry keys after C2000 Code Generation Tool Installation
    • Pruf
      Posted by Pruf
      on Apr 26 2010 09:23 AM
      Expert1030 points
      On some of our PC's (with Windows XP Professional) Code Composer Studio V3.3 (3.3.82.13) does not recognize a Code Generation Tool installation. Means in the component manager the tools are not in the list under "Build Tools\TMS320C28XX". What I have found out is that in this cases all the necessary registry keys are missing. The user has full administrative rights on that PC.
      I have seen that the keys under "HKEY_CLASSES_ROOT\CLSID\" as well as under "HKEY_LOCAL_MACHINE\SOFTWARE\Texas Instruments" are missing.
      Has anybody an idea?
      Thanks.
      c2000 ccs v3.3 code generation tools
      Report Abuse
      • Reply
      You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    • George Mock
      Posted by George Mock
      on Apr 26 2010 10:02 AM
      Guru51565 points
      Please confirm you followed all the steps as described here: http://processors.wiki.ti.com/index.php/Compiler_Installation_and_Selection#CCStudio_3.x .
      Thanks and regards,
      -George
      TI C/C++ Compiler Forum Moderator
      Please click Verify Answer on the best reply to your question.
      The Compiler Wiki answers most common questions.
      Track an issue with SDOWP. Enter your bug id in the "Find Record ID" box.
      Report Abuse
      • Reply
    • Pruf
      Posted by Pruf
      on Apr 27 2010 00:41 AM
      Expert1030 points
      Yes, I followed all those steps as I have done the last years I used this tools and uControllers. On my PC everything works well.
      I have seen this behaviour on two PC's for the time beeing. If you can tell me what the conditions are in order that the keys in the registry can be created I can check why they are not complied.
      By now I can't see any difference in the two PC's. They both running Windows XP Professional SP3 and the users have administrative rights on it.
      Thanks.
      Patrick
      Report Abuse
      • Reply
    • George Mock
      on Apr 27 2010 08:53 AM
      Guru51565 points
      I'll move this thread to the CCS forum.  We compiler folks don't know anything about the registry entries, but they do.
      Thanks and regards,
      -George
      Report Abuse
      • Reply
    • Ki-Soo Lee
      Posted by Ki-Soo Lee
      on Apr 27 2010 10:21 AM
      Guru117055 points
      Patrick - there should be a *.reg file in the same folder as your standalone CGT install. Can you manually run that? That *.reg file should add the needed registry entries.
      ki
      Don't forget to verify answers to your forum questions by using the green "Verify Answer" button.
      Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
      Having CCSv5 problems? Check out the CCSv5 Troubleshooting Guide
      Click here to track an issue. Enter your bug id in the "Find Record ID" box
      Report Abuse
      • Reply
    • Pruf
      Posted by Pruf
      on Apr 28 2010 04:13 AM
      Expert1030 points
      The following investigations have been done with "C2000 Code Generation Tools 5.2.5"
      Step 1: Running the installation does not create any registry keys.
      Step 2: Running "compiler.reg" creates the necessary keys in the registry, unfortunately not for the archiver. So that works more or less.
      Step 3: Running "RemoveRegistryKeys.exe" does not remove the registry keys created in step 2.
      Step 4: Running "uninstall_cgt_c2000.exe" does uninstall all the files and directories but does not remove registry keys created in step 2.
      --> Running a *.reg file works, so the user has all the rights needed to create the keys.
      ==> I think something is wrong with the installer (?)
      Patrick
      Report Abuse
      • Reply
    • Ki-Soo Lee
      on Apr 28 2010 08:32 AM
      Guru117055 points
      The installer seems to work ok. I just tried installing C2000 CGT 5.2.5 and the keys were created and it showed up in component manager. Then running the uninstaller removes the keys.
      Other than Admin privileges, you don't need anything else on Windows XP (32 bit I assume). I'm not sure what else to check. To workaround the issue for now, they can manually add the keys to the registry
      ki
      Report Abuse
      • Reply
    • sm53442
      Posted by sm53442
      on Jul 30 2010 12:08 PM
      Prodigy180 points
      I have checked the file "compiler.reg" (below). Obviously there is no section for "archiver". Maybe that is the reason why there is no archiver registry keys found in the Windows registry after manully register the keys of cgt.  Is it supposed to be like this in the cgt 7.0.3?
      "compiler.reg" in cgt 7.0.3.
      Windows Registry Editor Version 5.00
      [HKEY_LOCAL_MACHINE\SOFTWARE\Texas Instruments\CGT_C:|Program Files|Texas Instruments|C6000 Code Generation Tools 7.0.3|bin|]
      "ProductName"="Texas Instruments C6000 Code Generation Tools"
      "VendorName"="Texas Instruments"
      "Version"="7.0.3"
      [HKEY_LOCAL_MACHINE\SOFTWARE\Texas Instruments\CGT_C:|Program Files|Texas Instruments|C6000 Code Generation Tools 7.0.3|bin|\TMS320C62XX\Build Tools\Assembler\SearchPath_1]
      "bActive"=dword:00000001
      "Order"=dword:00000000
      "Path"="C:\\Program Files\\Texas Instruments\\C6000 Code Generation Tools 7.0.3\\include\\"
      [HKEY_LOCAL_MACHINE\SOFTWARE\Texas Instruments\CGT_C:|Program Files|Texas Instruments|C6000 Code Generation Tools 7.0.3|bin|\TMS320C62XX\Build Tools\Compiler\SearchPath_1]
      [HKEY_LOCAL_MACHINE\SOFTWARE\Texas Instruments\CGT_C:|Program Files|Texas Instruments|C6000 Code Generation Tools 7.0.3|bin|\TMS320C62XX\Build Tools\Linker\SearchPath_1]
      "Path"="C:\\Program Files\\Texas Instruments\\C6000 Code Generation Tools 7.0.3\\lib\\"
      [HKEY_LOCAL_MACHINE\SOFTWARE\Texas Instruments\CGT_C:|Program Files|Texas Instruments|C6000 Code Generation Tools 7.0.3|bin|\TMS320C64XX\Build Tools\Assembler\SearchPath_1]
      [HKEY_LOCAL_MACHINE\SOFTWARE\Texas Instruments\CGT_C:|Program Files|Texas Instruments|C6000 Code Generation Tools 7.0.3|bin|\TMS320C64XX\Build Tools\Compiler\SearchPath_1]
      [HKEY_LOCAL_MACHINE\SOFTWARE\Texas Instruments\CGT_C:|Program Files|Texas Instruments|C6000 Code Generation Tools 7.0.3|bin|\TMS320C64XX\Build Tools\Linker\SearchPath_1]
      [HKEY_LOCAL_MACHINE\SOFTWARE\Texas Instruments\CGT_C:|Program Files|Texas Instruments|C6000 Code Generation Tools 7.0.3|bin|\TMS320C67XX\Build Tools\Assembler\SearchPath_1]
      [HKEY_LOCAL_MACHINE\SOFTWARE\Texas Instruments\CGT_C:|Program Files|Texas Instruments|C6000 Code Generation Tools 7.0.3|bin|\TMS320C67XX\Build Tools\Compiler\SearchPath_1]
      [HKEY_LOCAL_MACHINE\SOFTWARE\Texas Instruments\CGT_C:|Program Files|Texas Instruments|C6000 Code Generation Tools 7.0.3|bin|\TMS320C67XX\Build Tools\Linker\SearchPath_1]
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
