Hello I am having an XDS100v2 emulator intermittent issue on my desktop computer. The issue doesn't seem to happen on my laptop.
A test return the information given below. I ran xds100serial from the command line (i.e. C:\ti\ccsv6.1\ccsv6\ccs_base\common\uscif>xds100serial). It returned the results shown below.
What could be causing the issue?
Stephen
UPDATE2:
After conecting to the target, the xds100serial application indicates there are no XDS100 emulators on the system even though it seems like the target is connected, i.e. I can run and stop and then run the target.
Scanning for XDS100 emulators...
No XDS100 emulators were found on the system.
UPDATE1:
Restarting code composer fix the problem until it happens again a short time later. I seem to remember there was an emulator update not too long ago. Could that be causing the issue.
After restarting Code composer:
VID/PID Type Serial # Description
0403/a6d0 XDS100v1/v2 SDVDRWT2 Texas Instruments Inc.XDS100 Ver 2.0
xds100serial from the command line (at the time of the issue)
- Scanning for XDS100 emulators...
XDS100v2 test
[Start: Texas Instruments XDS100v2 USB Debug Probe]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\shallacy\AppData\Local\Texas Instruments\
CCS\ccsv6.1\0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'jioserdesusb.dll'.
An error occurred while soft opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-151' (0xffffff69).
The title is 'SC_ERR_FTDI_OPEN'.
The explanation is:
One of the FTDI driver functions used during
the connect returned bad status or an error.
The cause may be one or more of: invalid XDS100 serial number,
blank XDS100 EEPROM, missing FTDI drivers, faulty USB cable.
Use the xds100serial command-line utility in the 'common/uscif'
folder to verify the XDS100 can be located.
[End: Texas Instruments XDS100v2 USB Debug Probe]
