I am having issues (graph is not updated and not all data is plotted) using the motor control Datalogger module to plot integer values (not normalized values) on the CCSv6 graph tool.
I done several things to try and get it to work, i.e removing calls to the S1 and S2 triggers from the assembly file (Util_DLOG4CHC.asm) and also removing the skip part. What exactly is the skip part anyways?
It worked a little better for each change, however, it still doesn't update the graph when a value changes.
Any suggestions?
Stephen
