Dear TI's Experts,
I'm developing an application with f28069 device.
I'm try to enable FPU32 (fpu32 instead of softlib) in compiler option and use run time support lib (except IQ math) rts2800_fpu32.lib
I got linker error like this:
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<fd_to
i.obj>" specifies ISA revision "C2800", which is not compatible with ISA
revision "C2700" specified in a previous file or on the command line
error #16008-D: file
l.obj>" specifies ISA revision "C2800", which is not compatible with ISA
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<fs_ad
d.obj>" specifies ISA revision "C2800", which is not compatible with ISA
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<fs_cm
p.obj>" specifies ISA revision "C2800", which is not compatible with ISA
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<fs_mp
y.obj>" specifies ISA revision "C2800", which is not compatible with ISA
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<fs_ne
g.obj>" specifies ISA revision "C2800", which is not compatible with ISA
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<fs_to
fd.obj>" specifies ISA revision "C2800", which is not compatible with ISA
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<i_div
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<i_tof
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<l_tof
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<ll_di
v.obj>" specifies ISA revision "C2800", which is not compatible with ISA
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<ltoa.
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<memcc
py.obj>" specifies ISA revision "C2800", which is not compatible with ISA
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<s_fre
xp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<s_sca
lbn.obj>" specifies ISA revision "C2800", which is not compatible with ISA
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<strcp
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<fd_ad
"C:\ti\ccsv6\tools\compiler\ti-cgt-c2000_16.6.0.STS\lib\rts2800_ml.lib<s_cop
ysign.obj>" specifies ISA revision "C2800", which is not compatible with ISA
warning #10247-D: creating output section "DLOG2" without a SECTIONS
Please let me know how I could solve this issue?
I don't want to use IQ math because it looks too complex to me and I don't have enough time to investigate how to use it.
Fitz
