I'm running CCSv6 on TMS320C6657 1 with XDS2xx. My code works in debug mode but very slowly. I want to run it from a command line in Release mode without bothering with debugging.
How is that done?
How is that done?
You can either use loadti to simply load the code to the target board or, if you need more control, Debug Server Scripting (DSS) is the right tool for the job.
Hope this helps,
Rafael
