I notice that CCS 6.2.0.00050 has a new "Stack Usage" view, which wasn't in previous CCS versions.
The Stack Usage view warns you if a function makes "Indirect Calls", and by right clicking on a function in the view you can add annotations to specify which indirect functions get called to assist in getting the correct stack usage reported.
CCS 6.2 doesn't appear to contain any help for the "Stack Usage" view, and from looking the annotations get stored in the workspace .metadata\.plugins\org.eclipse.core.resources\.projects\<project_name>\com.ti.ccstudio.project.ui.views\stackUsageannotated.dat file. i.e. if create a new workspace and import the project any annotations added in the Stack Usage view will be lost.
Is it possible to configure the Stack Usage view to read the Indirect Calls from a text file, in a similar way to the cg_xml call_graph utility?
