Hello, I have CCS v5.4.0 installed as well as ccs v7. Both versions connect to the 'TI resource Explorer'. v7 however doesn't connect to tthe 'Resource Explorer'. The settings are equal for both.
I guess I need to know which ip address and port number to look for? I found:
If after the above steps Resource Explorer is still unable to connect, provide the proxy settings for your network manually:
- Open 'Network Connections' preferences as above
- Under 'Active Provider', select 'Manual'
- Enter the proxy URLs and ports for both HTTP and HTTPS
- Click OK
- Close and restart CCS
So, which proxy URLs and ports for http and https must I look for?
kind regards,
Laurent
