Hi everyone,
I'm using CCS 6.1.3 build to run a C/C++ project on a TIVA MCU. Yesterday for some unknown reason my display console stopped working. I now get a message when trying to open a console (from View::console menu) that appears for less than a second that states "No consoles to display at this time". At the beginning of the project run time, I can see that the console screen appears several times for about 100 mSec each but with no text on it and then it closes again. I can still run, and put break points on the project, but don't see anything on the console anymore.
Note that this appears to be a project based problem and not a CCS wide problem because when I run another project with the same CCS the console works normally.
Below is the screen shot of the failing console:
Following old advice from other Eclipse users I've tried to solve this problem by deleting my .metadata directory or changing the project's "Debug Configurations:Common" setting to allocate a console, or try to create a new console. Nothing has worked so far.
Any help is appreciated.
Fred
