Hello, I would appreciate a solution to the following problem:
I have just loaded and updated CCS 7 (Version: 7.1.0.00016 ) on my PC#2 (Win 7), and trying to run the program inserted in this post that is running on another PC#1 (Win 7) of mine running CCS 6.
I do not currently have access to PC#1 as I am currently remote.
I added the main.c file directly into a new Project from the functioning version of this code on PC#1.
When I build the new Project on PC#2 I am receiving the following two errors:
1. Error #10234-D: unresolved symbols
2. Error #10010: errors encountered during linking
BTW, "blinky" loads and runs on my LaunchPad (TM4C123GXL).
Thanks!
Error descriptions:
Properties:
Code
The API's are not highlighting. Possibly I am not referencing the API source library correctly, or at all, or I am using the incorrect compiler, or?
Also, I have removed reference ROM_ to the API's, which was functioning on my other PC (Win 7) running CCS 6.
* Optocoupler driver (4N25) for N-Channel MOSFET (IRF630) power supply.
* See schematic: N-channel MOSFET with optocoupler * This code uses PWM Module 1 Generator 0 and Generator 3 * PWM Module 1 Generator 0: M1PWM0, GPIO pin PD0. PWMGenConfigure using PWM_GEN_MODE_DOWN In count down mode, it will count from a value down to zero, and then reset to the preset value. This will produce left-aligned PWM signals (that is the rising edge of the two PWM signals produced by the generator will occur at the same time). * PWM Module 1 Generator 3: M1PWM6, GPIO pin PF2. PWMGenConfigure using PWM_GEN_MODE_UP_DOWN In count up/down mode, it will count up from zero to the preset value, count back down to zero, and then repeat the process. This will produce center-aligned PWM signals (that is, the middle of the high/low period of the PWM signals produced by the generator will occur at the same time).*/ #include <stdint.h> #include <stdbool.h> #include "inc/hw_memmap.h" #include "inc/hw_types.h" #include "driverlib/sysctl.h" #include "driverlib/gpio.h" #include "driverlib/debug.h" #include "driverlib/pwm.h" #include "driverlib/pin_map.h" #include "inc/hw_gpio.h" // Not required for this program //#include "driverlib/rom.h" int main( void ) { // Set-up System Clock (SYSCLK) and PWM Clock (PWMCLK) SysCtlClockSet( SYSCTL_SYSDIV_10 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ ); // SYSCLK set to 20 MHz (referred to as "ticks") // TM4C123x_ROM USER’S GUIDE page 199/348 // TM4C123GH6PM RevE DataSheet, Register 8: Run-Mode Clock Configuration (RCC), offset 0x060 // SYSCTL_OSC_MAIN = OSCSRC (Oscillator Source), MOSC (Main oscillator), page 257 / 1409 // SYSCTL_XTAL_16MHZ = XTAL (Crystal Value), page 256/1409 // SYSCTL_SYSDIV_10 = SYSDIV (System Clock Divisor), page 254/1409 // SYSCTL_USE_PLL = USEPWMDIV (Enable PWM Clock Divisor), page 255/1409 // Set-up PWM Clock (PWMCLK) SysCtlPWMClockSet( SYSCTL_PWMDIV_64 ); // Sets the PWM clock by dividing the 20.0 MHz (ticks) SYSCLK by 64 = PWM clock 312.5 KHz [312,500 Hz] (PWMCLK) // TM4C123x_ROM USER’S GUIDE page 217/348 // TM4C123GH6PM RevE DataSheet, Register 8: Run-Mode Clock Configuration (RCC), offset 0x060 // SYSCTL_PWMDIV_64 = PWMDIV, page 255/1409 // Enable PWM module 1, Generator 0 to output on GPIO Port D, pin 0, and Generator 3 to output on GPIO Port F, pin 2 SysCtlPeripheralEnable( SYSCTL_PERIPH_PWM1 ); // Enable the PWM peripheral PWM module 1 SysCtlPeripheralEnable( SYSCTL_PERIPH_GPIOD ); // Enable GPIO: Port D SysCtlPeripheralEnable( SYSCTL_PERIPH_GPIOF ); // Enable GPIO: Port F /*-----Configure PWM module 1, Generator 0, PWM 1 to output a defined frequency and pulse duty cycle on GPIO GPIO Port D, Pin PD0 M1PWM0 */ GPIOPinTypePWM( GPIO_PORTD_BASE, GPIO_PIN_0 ); // Configures Port D, Pin 0 for use by the PWM peripheral. //The program loads but will not run on the TM4C123G_LaunchPad when it is a ROM_ API // The program loads and runs on the TM4C123G_LaunchPad when it is a 2.1.3.156 Driver Library API GPIOPinConfigure( GPIO_PD0_M1PWM0 ); // Configures the alternate function of Port D, Pin 0 to PWM output // TM4C123GH6PM Microcontroller Data Sheet-SPMS376E, 23.4 GPIO Pins and Alternate Functions, p1351 PWMGenConfigure( PWM1_BASE, PWM_GEN_0, PWM_GEN_MODE_DOWN ); // Configures a PWM Module 1, Generator 0. In MODE_DOWN, counts from the PWM generator's Period (load) down to zero, // and then reset to the preset PWM generator's Period (load) value. // Tiva C Series TM4C123x ROM USER’S GUIDE, PWM, 15.2.1.5 ROM_PWMGenConfigure, page 157. // TM4C123GH6PM Microcontroller Data Sheet-SPMS376E, 20.3.2 PWM Timer, p1234 & Figure 20-3. PWM Count-Down Mode, p1235 PWMGenPeriodSet( PWM1_BASE, PWM_GEN_0, 5208 ); // Sets the PWM Generator 0's Period (load) value. This is the frequency of the square wave. // The Period (load) value is defined as the number of PWM clock ticks between zero pulse signals on the generator block. // PWMCLK frequency [ticks per second (Hz)] = 62,500 ticks per second // PWM Period = (1/f) = 0.0000032 Seconds per tick // Desired frequency [f] = number of Hz // Desired period = (1/f) = Seconds per period // Ticks per desired period = Seconds per period / Seconds per tick // 60 Hz = 5208 ticks //ROM_PWMDeadBandEnable(PWM1_BASE, PWM_GEN_0, 1000, 1000); // Enable the dead-band generation on the PWM0 output signal as a percentage of the PWMGenPeriodSet ticks // % of PWMGenPeriodSet ticks = PWMPulseWidthSet( PWM1_BASE, PWM_OUT_0, ( PWMGenPeriodGet(PWM1_BASE, PWM_GEN_0) / 4) ); // Sets the PWM Generator 0 pulse width output by using PWMGenPeriodGet to get the period previously set. // Set Duty Cycle: In this case PWM generator's period is divided the by 10 to get 10% duty cycle. PWMOutputState( PWM1_BASE, PWM_OUT_0_BIT, true ); // Enables the output of PWM Module 1, Generator 0 PWMGenEnable( PWM1_BASE, PWM_GEN_0 ); // Enables the timer/counter for a PWM Module 1, Generator 0 GPIOPadConfigSet(GPIO_PORTD_BASE, GPIO_PIN_0, GPIO_STRENGTH_8MA, GPIO_PIN_TYPE_STD); // Enable GPIO Port D Pad and Pins 0 for 8 MA output /*----- Configure PWM module 1, Generator 3, PWM 1 to output a defined frequency and pulse duty cycle on GPIO Port F, Pin PF2 M1PWM6 --------*/ GPIOPinTypePWM( GPIO_PORTF_BASE, GPIO_PIN_2 ); // Configures Port F, Pin 2 for use by the PWM peripheral //The program loads but will not run on the TM4C123G_LaunchPad when it is a ROM_ API // The program loads and runs on the TM4C123G_LaunchPad when it is a 2.1.3.156 Driver Library API GPIOPinConfigure( GPIO_PF2_M1PWM6 ); // Configures the alternate function of Port F, Pin 0 to PWM output // TM4C123GH6PM Microcontroller Data Sheet-SPMS376E, 23.4 GPIO Pins and Alternate Functions, p1351 PWMGenConfigure( PWM1_BASE, PWM_GEN_3, PWM_GEN_MODE_UP_DOWN ); // Configures a PWM Module 1, Generator 2. In MODE_UP_DOWN, counts from the PWM generator's Period (load) down to zero, /*In count up/down mode, it will count up from zero to the preset value, count back down to zero, and then repeat the process. This will produce center-aligned PWM signals (that is, the middle of the high/low period of the PWM signals produced by the generator will occur at the same time).*/ // Tiva C Series TM4C123x ROM USER’S GUIDE, PWM, 15.2.1.5 ROM_PWMGenConfigure, page 157 // TM4C123GH6PM Microcontroller Data Sheet-SPMS376E, 20.3.2 PWM Timer, p1234 & Figure 20-4. PWM Count-Up/Down Mode, p1235 PWMGenPeriodSet( PWM1_BASE, PWM_GEN_3, 5208 ); // Sets the PWM Generator 0's Period (load) value. This is the frequency of the square wave. // The Period (load) value is defined as the number of PWM clock ticks between zero pulse signals on the generator block. // PWMCLK frequency [ticks per second (Hz)] = 62,500 ticks per second // PWM Period = (1/f) = 0.0000032 Seconds per tick // Desired frequency [f] = number of Hz // Desired period = (1/f) = Seconds per period // Ticks per desired period = Seconds per period / Seconds per tick // 60 Hz = 5208 ticks PWMDeadBandEnable(PWM1_BASE, PWM_GEN_3, 200, 200); // Enable the dead-band generation on the PWM0 output signal as a percentage of the PWMGenPeriodSet ticks // % of PWMGenPeriodSet ticks = PWMPulseWidthSet( PWM1_BASE, PWM_OUT_6, ( PWMGenPeriodGet(PWM1_BASE, PWM_GEN_3) / 4 ) ); // Sets the PWM Generator 0 pulse width output (Duty Cycle) by using PWMGenPeriodGet to get the period previously set. // In this case PWM generator's period is divided the by 10 to get 10% duty cycle. //ROM_PWMOutputInvert(PWM1_BASE, PWM_OUT_0_BIT, true); // Inverts the output of PWM Module 1, Generator 0, Bit 1 //(This function is not needed as a PWM's Generators two outputs are mutually inverted) PWMOutputState( PWM1_BASE, PWM_OUT_6_BIT, true ); // Enables the output of PWM Module 1, Generator 2, PWM 4 PWMGenEnable( PWM1_BASE, PWM_GEN_3 ); // Enables the timer/counter for a PWM Module 1, Generator 0 GPIOPadConfigSet(GPIO_PORTF_BASE, GPIO_PIN_2, GPIO_STRENGTH_8MA, GPIO_PIN_TYPE_STD); // Enable GPIO Port F Pad and Pin 0 for 8 MA output while( 1 ) { ; } }
