I'm using a CCS workspace to build several projects. I have two projects which build libraries: libA, libB. Another project builds a program: fdtab. I want project fdtab to link in the library produced by project libA. In project fdtab, I just want to specify the dependent project (libA) and which configuration to use (debug). I want the library pathname to be specified by the libA project.
I've tried using the Export page in project libA to specify what resource to export. In project fdtab, I use the References tab of the Paths and Symbols page to specify project libA and which configuration to use. This sort of works, but the library from project libA is added two times to my linker path.
Now I want to switch from using libA to using libB. In project fdtab, I unselect my libA dependency and select by libB dependency. This adds the library from libB to my link path (two times again) but does not remove the library from the libA project.
Please advise if there is a better way to do this.
Thank you,
~Ramsey
