Other Parts Discussed in Thread: UNIFLASH, HALCOGEN
Hello, I've been using CCS Flash with an XDS100V2 programmer to successfully programme 5 off LS3137's in a chain: the first, #1 has its own code, then #2 - #5 have the same code.
Wanting to use the CCS7 debug feature on #1 I imported the ccxml configuration file to CCS7. However, whichever of the parts I select in CCS7 to debug (first one shown in clip below), it appears that #1 is never programmed. Is my config file wrong?
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<configurations XML_version="1.2" id="configurations_0">
<configuration XML_version="1.2" id="configuration_0">
<instance XML_version="1.2" desc="Texas Instruments XDS100v2 USB Emulator" href="connections/TIXDS100v2_Connection.xml" id="Texas Instruments XDS100v2 USB Emulator" xml="TIXDS100v2_Connection.xml" xmlpath="connections"/>
<connection XML_version="1.2" id="Texas Instruments XDS100v2 USB Emulator">
<instance XML_version="1.2" href="drivers/tixds100v2icepick_c.xml" id="drivers" xml="tixds100v2icepick_c.xml" xmlpath="drivers"/>
<instance XML_version="1.2" href="drivers/tixds100v2cs_dap.xml" id="drivers" xml="tixds100v2cs_dap.xml" xmlpath="drivers"/>
<instance XML_version="1.2" href="drivers/tixds100v2cortexR.xml" id="drivers" xml="tixds100v2cortexR.xml" xmlpath="drivers"/>
<platform XML_version="1.2" id="platform_0">
<instance XML_version="1.2" desc="TMS570LS3137_1" href="devices/tms570ls3137.xml" id="TMS570LS3137_1" xml="tms570ls3137.xml" xmlpath="devices"/>
<device HW_revision="1" XML_version="1.2" description="TMS570LS3137 QFP/BGA, 3MB Flash, 256kB RAM, 2ch FlexRay, 10/100M Ethernet" id="TMS570LS3137_1" partnum="TMS570LS3137">
<router HW_revision="1.0" XML_version="1.2" desc="IcePick_1" description="ICEPick_C Router" id="IcePick_C_0" isa="ICEPICK_C">
<subpath desc="Port16_1" id="Port16">
<router HW_revision="" XML_version="1.2" desc="Dap_1" description="CS_DAP Router" id="CS_DAP_0" isa="CS_DAP">
<subpath desc="PortR4_1" id="PortR4">
<cpu HW_revision="" XML_version="1.2" desc="CortexR4_1" description="Cortex_R4 CPU" id="Cortex_R4_0" isa="Cortex_R4"/>
</subpath>
</router>
</subpath>
<subpath desc="Port17_1" id="Port17"/>
</router>
</device>
<instance XML_version="1.2" desc="TMS570LS3137_2" href="devices/tms570ls3137.xml" id="TMS570LS3137_2" xml="tms570ls3137.xml" xmlpath="devices"/>
<device HW_revision="1" XML_version="1.2" description="TMS570LS3137 QFP/BGA, 3MB Flash, 256kB RAM, 2ch FlexRay, 10/100M Ethernet" id="TMS570LS3137_2" partnum="TMS570LS3137">
<router HW_revision="1.0" XML_version="1.2" desc="IcePick_2" description="ICEPick_C Router" id="IcePick_C_0" isa="ICEPICK_C">
<subpath desc="Port16_2" id="Port16">
<router HW_revision="" XML_version="1.2" desc="Dap_2" description="CS_DAP Router" id="CS_DAP_0" isa="CS_DAP">
<subpath desc="PortR4_2" id="PortR4">
<cpu HW_revision="" XML_version="1.2" desc="CortexR4_2" description="Cortex_R4 CPU" id="Cortex_R4_0" isa="Cortex_R4"/>
</subpath>
</router>
</subpath>
<subpath desc="Port17_2" id="Port17"/>
</router>
</device>
<instance XML_version="1.2" desc="TMS570LS3137_3" href="devices/tms570ls3137.xml" id="TMS570LS3137_3" xml="tms570ls3137.xml" xmlpath="devices"/>
<device HW_revision="1" XML_version="1.2" description="TMS570LS3137 QFP/BGA, 3MB Flash, 256kB RAM, 2ch FlexRay, 10/100M Ethernet" id="TMS570LS3137_3" partnum="TMS570LS3137">
<router HW_revision="1.0" XML_version="1.2" desc="IcePick_3" description="ICEPick_C Router" id="IcePick_C_0" isa="ICEPICK_C">
<subpath desc="Port16_3" id="Port16">
<router HW_revision="" XML_version="1.2" desc="Dap_3" description="CS_DAP Router" id="CS_DAP_0" isa="CS_DAP">
<subpath desc="PortR4_3" id="PortR4">
<cpu HW_revision="" XML_version="1.2" desc="CortexR4_3" description="Cortex_R4 CPU" id="Cortex_R4_0" isa="Cortex_R4"/>
</subpath>
</router>
</subpath>
<subpath desc="Port17_3" id="Port17"/>
</router>
</device>
<instance XML_version="1.2" desc="TMS570LS3137_0" href="devices/tms570ls3137.xml" id="TMS570LS3137_0" xml="tms570ls3137.xml" xmlpath="devices"/>
<device HW_revision="1" XML_version="1.2" desc="TMS570LS3137_4" description="TMS570LS3137 QFP/BGA, 3MB Flash, 256kB RAM, 2ch FlexRay, 10/100M Ethernet" id="TMS570LS3137_0" partnum="TMS570LS3137">
<router HW_revision="1.0" XML_version="1.2" desc="IcePick_0" description="ICEPick_C Router" id="IcePick_C_0" isa="ICEPICK_C">
<subpath desc="Port16_0" id="Port16">
<router HW_revision="" XML_version="1.2" desc="Dap_0" description="CS_DAP Router" id="CS_DAP_0" isa="CS_DAP">
<subpath desc="PortR4_0" id="PortR4">
<cpu HW_revision="" XML_version="1.2" desc="CortexR4_0" description="Cortex_R4 CPU" id="Cortex_R4_0" isa="Cortex_R4"/>
</subpath>
</router>
</subpath>
<subpath desc="Port17_0" id="Port17"/>
</router>
</device>
<instance XML_version="1.2" desc="TMS570LS3137" href="devices/tms570ls3137.xml" id="TMS570LS3137" xml="tms570ls3137.xml" xmlpath="devices"/>
<device HW_revision="1" XML_version="1.2" desc="TMS570LS3137_5" description="TMS570LS3137 QFP/BGA, 3MB Flash, 256kB RAM, 2ch FlexRay, 10/100M Ethernet" id="TMS570LS3137" partnum="TMS570LS3137"/>
</platform>
</connection>
</configuration>
</configurations>
