Other Parts Discussed in Thread: PROFIBUS, SYSBIOS,
Hi all,
I am developing a project based on a TI example. The folder "src" was marked for not being compiled with a "source location filter" (Project properties -> Paths and symbols -> Source Location tab, then "Edit filter"). Usually I keep my code in a folder called "src", so I renamed the original folder to "src-dontbuild" and added a new one.
To my surprise, everytime I start Code Composer, my own "src" folder is marked for being excluded from compilation. I remove the filter, compile, and it runs fine, but the next time I restart Code Composer, it marks my folder again and does not build it by default.
Is there any way to make these settings permanent? (as they should be)
BTW I am using CCS 7.2.0.00013
Thank you very much in advance,
Alejandro.
