I believe I found a few CCS bugs. In CCS Version: 7.3.0.00019, I copied a project from another project in the same workspace. In order to get this copied project to build, I had to fix a few things. I've had to do this with a few projects now.
1. In "general settings" the target device had changed itself from ti.targets.arm.elf.M4F to ti.targets.arm.elf.M4. This results in a build error as the proper library file isn't found. Trivial to fix but figuring out what caused it took a few minutes. Ideally CCS would keep the same target device.
2. In the .cproject file, some of the xml fields kept the old project's paths so the auto generated makefiles couldn't find config.bld. The excerpts below show the offending sections. The highlighted parts are the folder names that I had to change.
<tool id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.614135008" name="XDCtools" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool">
<option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH.1203689341" name="Package repositories (--xdcpath)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH" valueType="stringList">
<listOptionValue builtIn="false" value="${XDC_CG_ROOT}/packages"/>
<listOptionValue builtIn="false" value="${TARGET_CONTENT_BASE}"/>
</option>
<option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.TARGET.606357614" name="Target (-t)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.TARGET" value="ti.targets.arm.elf.M4F" valueType="string"/>
<option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.BUILD_CONFIGURATION_FILE.1929286763" name="Build configuration file (-b)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.BUILD_CONFIGURATION_FILE" value="${PROJECT_ROOT}/OldProjectName/configPkg/config.bld" valueType="string"/>
<tool id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.624706169" name="XDCtools" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool">
<option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH.1491284185" name="Package repositories (--xdcpath)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH" valueType="stringList">
</option>
<option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.TARGET.954356362" name="Target (-t)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.TARGET" value="ti.targets.arm.elf.M4F" valueType="string"/>
<option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.BUILD_CONFIGURATION_FILE.797499136" name="Build configuration file (-b)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.BUILD_CONFIGURATION_FILE" value="${PROJECT_ROOT}/OldProjectName/configPkg/config.bld" valueType="string"/>
Hope this is helpful and not just a problem on my end.
