Hi Danish,
I tried your suggestion in previous blog as below;
"You have unzipped your install package in D:/CCS5[1].4.0.00091_win32/ and the [1] is causing problems for unzip. Can you please rename the folder to something else, e.g. D:/CCS5 and try your install again. Please let me know if you have any more issues, or if this resolves your problem"
using this I am able to install the CCS 5.4 but while ccs opens first time I see below error, can you help me for the same. Also find the attached installed log.
debugserver_5.4.0.279_install.logmsvc2008.log
[1CC4:3214][2018-01-03T13:15:42]: Burn v3.6.3429.0, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Users\mohammed.zakariya\Downloads\CCS5.4.0.00091\CCS5.4\baserepo\vcredist_x86_2012.exe, cmdline: '/q /l D:/ccs54/ccsv5/install_logs/MSVC2012.log /nostart -burn.unelevated BurnPipe.{E234890C-8994-483A-AEAA-25A48BB896F9} {E66B7E5F-F485-4FB4-82FF-111AE1844F1A} 9004' [1CC4:3214][2018-01-03T13:15:42]: Setting string variable 'WixBundleLog' to value 'D:/ccs54/ccsv5/install_logs/MSVC2012.log' [1CC4:3214][2018-01-03T13:15:42]: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\mohammed.zakariya\Downloads\CCS5.4.0.00091\CCS5.4\baserepo\vcredist_x86_2012.exe' [1CC4:3214][2018-01-03T13:15:43]: Detect 2 packages [1CC4:3214][2018-01-03T13:15:43]: Detected related bundle: {33d1fd90-4274-48a1-9bc1-97e33d9c2d6f}, type: Upgrade, scope: PerMachine, version: 11.0.61030.0, operation: Downgrade [1CC4:3214][2018-01-03T13:15:43]: Detected related package: {BD95A8CD-1D9F-35AD-981A-3E7925026EBB}, scope: PerMachine, version: 11.0.61030.0, language: 0 operation: Downgrade [1CC4:3214][2018-01-03T13:15:43]: Detected related package: {B175520C-86A2-35A7-8619-86DC379688B9}, scope: PerMachine, version: 11.0.61030.0, language: 0 operation: Downgrade [1CC4:3214][2018-01-03T13:15:43]: Detected package: vcRuntimeMinimum_x86, state: Obsolete, cached: None [1CC4:3214][2018-01-03T13:15:43]: Detected package: vcRuntimeAdditional_x86, state: Obsolete, cached: None [1CC4:3214][2018-01-03T13:15:43]: Condition 'VersionNT >= v6.0 OR (VersionNT = v5.1 AND ServicePackLevel >= 2) OR (VersionNT = v5.2 AND ServicePackLevel >= 1)' evaluates to true. [1CC4:3214][2018-01-03T13:15:43]: Detect complete, result: 0x0 [1CC4:2FC8][2018-01-03T13:15:43]: A newer version of this product is installed but downgrade failure has been suppressed; continuing... [1CC4:3214][2018-01-03T13:15:43]: Plan 2 packages, action: Modify [1CC4:3214][2018-01-03T13:15:43]: Planned package: vcRuntimeMinimum_x86, state: Obsolete, default requested: None, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None [1CC4:3214][2018-01-03T13:15:43]: Planned package: vcRuntimeAdditional_x86, state: Obsolete, default requested: None, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None [1CC4:3214][2018-01-03T13:15:43]: Planned related bundle: {33d1fd90-4274-48a1-9bc1-97e33d9c2d6f}, type: Upgrade, default requested: None, ba requested: None, execute: None, rollback: None, dependency: None [1CC4:3214][2018-01-03T13:15:43]: Plan complete, result: 0x0 [1CC4:3214][2018-01-03T13:15:43]: Apply begin [232C:24E8][2018-01-03T13:15:43]: Creating a system restore point. [232C:24E8][2018-01-03T13:15:54]: Created a system restore point. [1CC4:3214][2018-01-03T13:15:54]: Apply complete, result: 0x0, restart: None, ba requested restart: No [1CC4:3214][2018-01-03T13:15:54]: Shutting down, exit code: 0x0 [1CC4:3214][2018-01-03T13:15:55]: Variable: ServicePackLevel = 1 [1CC4:3214][2018-01-03T13:15:55]: Variable: VersionNT = 6.1.0.0 [1CC4:3214][2018-01-03T13:15:55]: Variable: WixBundleAction = 5 [1CC4:3214][2018-01-03T13:15:55]: Variable: WixBundleElevated = 1 [1CC4:3214][2018-01-03T13:15:55]: Variable: WixBundleInstalled = 1 [1CC4:3214][2018-01-03T13:15:55]: Variable: WixBundleLog = D:/ccs54/ccsv5/install_logs/MSVC2012.log [1CC4:3214][2018-01-03T13:15:55]: Variable: WixBundleName = Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.51106 [1CC4:3214][2018-01-03T13:15:55]: Variable: WixBundleOriginalSource = C:\Users\MOHAMM~1.ZAK\AppData\Local\Temp\ijtmp_D616A7EC-35A7-4E81-8D61-E0720D299064\baserepo\vcredist_x86_2012.exe [1CC4:3214][2018-01-03T13:15:55]: Variable: WixBundleProviderKey = {8e70e4e1-06d7-470b-9f74-a51bef21088e} [1CC4:3214][2018-01-03T13:15:55]: Variable: WixBundleTag = [1CC4:3214][2018-01-03T13:15:55]: Variable: WixBundleVersion = 11.0.51106.1 [1CC4:3214][2018-01-03T13:15:55]: Exit code: 0x0, restarting: No
Mohammed
