While debugging a code, I needed to watch a Variable both in decimal and hex format.
I added two instances of variable to expression window and then changed 'view format' of second instance to hexadecimal.
After a click or two, view format of first instance also changed to hexadecimal.
If this should not work, what is an easy way to monitor a variable in both decimal and hex?
MHG
