• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » TI C/C++ Compiler » TI C/C++ Compiler - Forum » DWARF information parsing with TI C6000
Share
TI C/C++ Compiler
  • Forum
Options
  • Subscribe via RSS
This question is answered
Stanimir Kabaivanov
Posted by Stanimir Kabaivanov
on Mar 20 2012 11:59 AM
Prodigy20 points
Hello everyone,
We have detected an interesting case when reading debug information for our tools for files
that have been built with C6000 compiler.
Besides the specific usage of DIE elements with name CIE_RETA that have been explained in
TI documentation we have found that name attribute in DIEs containing CIE_RETA have one
extra byte in length.
It was possible to detect this issue by debugging inside the parser and comparing the parsing
steps with the output produced by ofd6x.exe
1. Output from ofd6x.exe:
00016a64 27 DW_TAG_TI_assign_register
00016a65 DW_AT_location DW_OP_regx 127
00016a68 DW_AT_name DETR <- the size is OK (6d - 68=5 bytes=4 chars + term)
00016a6d 27 DW_TAG_TI_assign_register
00016a6e DW_AT_location DW_OP_regx 228
00016a72 DW_AT_name CIE_RETA <- the size is bigger (7c-72=10 bytes>8 chars + term)!
00016a7c 28 DW_TAG_pointer_type
00016a7d DW_AT_address_class DW_ADDR_TI_PTR32
The fact that this string attribute (it is possible to confirm it is a string because the attribute type
is DW_FORM_string or 0x08) has different size than it should have makes our parser read
incorrect abbrev. identifier (because of the wrong offset) and terminate the parsing of DIEs
for current compilation unit.
Could you please help me with a link to a document that describes this behavior
or with additional information what would be the preferred way of handling such cases.
Thank you very much in advance for your help,
C6000 DWARF coff
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • George Mock
    Posted by George Mock
    on Mar 21 2012 10:35 AM
    Guru51445 points
    I am using v7.3.1 of the C6000 compiler tools.  And I cannot reproduce what you describe.  So, one possible solution is to upgrade your compiler to v7.3.x.  If that isn't possible for some reason, please submit a test case.  The last part of the forum usage guidelines gives the details on doing that.
    Thanks and regards,
    -George
    TI C/C++ Compiler Forum Moderator
    Please click Verify Answer on the best reply to your question.
    The Compiler Wiki answers most common questions.
    Track an issue with SDOWP. Enter your bug id in the "Find Record ID" box.
    Report Abuse
    • Reply
  • Stanimir Kabaivanov
    on Mar 22 2012 06:48 AM
    Prodigy20 points
    Dear George,
    Thank you very much for your reply. As this is a project of our customer I am not able to upload it directly without a permission. However I will try to obtain one and provide you with an example.
    As far as I'm aware the compiler version that have been used for building this out file is built with compiler version 6.1.19.0:
        File Name:               broken.out
    Format: TI-COFF Version 2
    File Type: executable file
    Time Stamp: Fri Feb 24 18:14:30 2012
    Machine: TI C6x
    Machine Endian: little endian
    Entry Point: 0xc01277c0
    Vendor: Texas Instruments, Inc.
    Vendor Version: 6001
    Number of Sections: 29
    File Length: 36663922
    TI-COFF f_flags: 0x00000193
    TI-COFF f_flag: F_RELFLG (relocation info stripped)
    CPU Generation: 0x9
    Control Data Endian: little endian
    Start of .text Section: 0xc0000020
    Start of .data Section: 0xc0000010
    Size of .text Section: 1268224
    Size of .data Section: 0
    Size of .bss Section: 6626
    For a number of reason this customer wants to stick this compiler version, so we're trying to find out why exactly this situation happens.
    What I can provide as an additional information is that this special case happened when building C++ application which also has stlport library.
    Since we have tested with other projects it was possible to observe similar size behavior of CIE_RETA, but in our other projects the CIE_RETA tag
    was always put at the end of the compilation unit, and in this case having one extra byte and reading zero abbrev id is actually correct and does not have
    side effects on our parsing:
        00013569  56    DW_TAG_TI_assign_register
    0001356a DW_AT_location DW_OP_regx 127
    0001356d DW_AT_name DETR
    00013572 56 DW_TAG_TI_assign_register
    00013573 DW_AT_location DW_OP_regx 228
    00013577 DW_AT_name CIE_RETA
    DIE Table at Offset 00013581
    Length: 55403
    Version: 2
    .debug_abbrev Offset: 00000823
    Address Size: 4
    Thank you very much once again for your information,
    Report Abuse
    • Reply
  • George Mock
    on Mar 22 2012 14:10 PM
    Verified Answer
    Verified by JohnS
    Guru51445 points
    I have not exactly reproduced your issue.  But I did experiment and find that, for a simple test case, the v7.3.4 compiler always encodes the CIE_RETA register name in 9 bytes, and the v6.1.20 compiler appears to encode it in 10 bytes.  So, I filed the entry SDSCM00043576 in the SDOWP system.  In it, I describe this difference in detail and ask for an explanation.  Perhaps it is a bug that has been fixed.  I don't know.  But I think this is the best way to find out.  You can track this issue with SDOWP link below in my signature.
    BTW, I used v6.1.20 and not v6.1.19 because I wanted to use the latest version along that release stream.  Release v6.1.20 differs from v6.1.19 only in bug fixes.
    Thanks and regards,
    -George
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
