Hello compiler/c-library experts
Here is our setup:
- device: C6424
- CCS Version: 4.2.4.00033
- xdctools_3_23_00_32
- C6000 Code Generation Tools 7.3.2
- For legacy reasons we are still building for COFF-ABI
- All code is compiled as C++ (.cpp extension) with minimal C++ constructs - even if instances of "utility objects" exist, they are stack-local...
I'm implementing a bootloader (bare metal, no SYS/BIOS) which is part of a 2-stage chain-load process... and space (internal memory) is at a premium...
Is there a way to shed unused RTS baggage?
Also the following options do not seem to make a difference (unless I''m making a mistake...)
- --printf_support=minimal
- --disable_auto_rts
I also found an older thread on the forum: http://e2e.ti.com/support/development_tools/compiler/f/343/t/55673.aspx#199742
But, I could not get much out of it...
-ram
Linker Cmd File:
-c
-heap 0x1000
-stack 0x1000
/* Memory Map: 48-kB */
MEMORY
BOOT: o = 0x10800000 l = 0x00000060
L2_RAM: o = 0x10800060 l = 0x0000BFA0
SECTIONS
boot > BOOT
-lrts64plus.lib<boot.obj> (.text)
.text > L2_RAM
* (.text)
.stack > L2_RAM
.bss > L2_RAM
.cinit > L2_RAM
.pinit > L2_RAM
.cio > L2_RAM
.const > L2_RAM
.data > L2_RAM
.switch > L2_RAM
.sysmem > L2_RAM
.far > L2_RAM
Output Map
TMS320C6x Linker PC v7.3.2
>> Linked Mon Mar 26 16:33:43 2012
OUTPUT FILE NAME: <--- deleted --->
ENTRY POINT SYMBOL: "_c_int00" address: 10800000
MEMORY CONFIGURATION
name origin length used unused attr fill
BOOT 10800000 00000060 00000060 00000000 RWIX
L2_RAM 10800060 0000bfa0 00009db0 000021f0 RWIX
SECTION ALLOCATION MAP
output attributes/
section page origin length input sections
.pinit 0 10800060 00000000 UNINITIALIZED
boot 0 10800000 00000060
10800000 00000060 rts64plus.lib : boot.obj (.text:_c_int00)
.text 0 10800060 00007140
10800060 00000880 main.obj (.text)
108008e0 00000580 rts64plus.lib : _printfi.obj (.text:__getarg_diouxp)
10800e60 00000540 : divd.obj (.text:__divd)
108013a0 00000480 : _printfi.obj (.text:__setfield)
10801820 00000440 : _printfi.obj (.text:__printfi)
10801c60 00000300 : _printfi.obj (.text:_ecvt)
10801f60 00000300 : _printfi.obj (.text:_fcvt)
10802260 00000300 : fputs.obj (.text:_fputs)
10802560 000002e0 : _printfi.obj (.text:__pproc_fge)
10802840 000002c0 : _printfi.obj (.text:__pproc_fwp)
10802b00 000002a0 : _printfi.obj (.text:__pconv_e)
10802da0 00000280 : memory.obj (.text:_free)
10803020 00000260 : imath64.obj (.text:__divull)
10803280 00000260 : mpyd.obj (.text:__mpyd)
108034e0 00000240 : _printfi.obj (.text:__pproc_diouxp)
10803720 00000220 : _printfi.obj (.text:__pproc_str)
10803940 00000200 : addd.obj (.text:__addd)
10803b40 00000200 : frcaddd.obj (.text:__frcaddd)
10803d40 00000200 : _printfi.obj (.text:__pconv_g)
10803f40 000001c0 : _printfi.obj (.text:__mcpy)
10804100 000001a0 : imath40.obj (.text:__divul)
108042a0 00000180 : trgdrv.obj (.text:_HOSTrename)
10804420 00000180 : memory.obj (.text:_malloc)
108045a0 00000180 : setvbuf.obj (.text:_setvbuf)
10804720 00000180 libdevices.a : gpio_simple.obj (.text)
108048a0 00000140 rts64plus.lib : fputc.obj (.text:_fputc)
108049e0 00000140 : lowlev.obj (.text:_getdevice)
10804b20 00000120 : _printfi.obj (.text:__pproc_fflags)
10804c40 00000120 : fclose.obj (.text:_fclose)
10804d60 00000100 : trgdrv.obj (.text:_HOSTlseek)
10804e60 00000100 : autoinit.obj (.text:__auto_init)
10804f60 00000100 : frcmpyd.obj (.text:__frcmpyd)
10805060 00000100 : _printfi.obj (.text:__ltostr)
10805160 00000100 : _io_perm.obj (.text:__wrt_ok)
10805260 00000100 : fflush.obj (.text:_fflush)
10805360 00000100 libdevices.a : led.obj (.text)
10805460 000000e0 rts64plus.lib : trgdrv.obj (.text:_HOSTopen)
10805540 000000e0 : cmpd.obj (.text:__cmpd)
10805620 000000e0 : atoi.obj (.text:_atoi)
10805700 000000e0 : lowlev.obj (.text:_close)
108057e0 000000e0 : exit.obj (.text:_exit)
108058c0 000000e0 : memset.obj (.text:_memset)
108059a0 000000c0 : trgdrv.obj (.text:_HOSTread)
10805a60 000000c0 : trgdrv.obj (.text:_HOSTunlink)
10805b20 000000c0 : trgdrv.obj (.text:_HOSTwrite)
10805be0 000000c0 : fopen.obj (.text:__cleanup)
10805ca0 000000c0 : _printfi.obj (.text:__div)
10805d60 000000c0 : divu.obj (.text:__divu)
10805e20 000000c0 : fflush.obj (.text:__doflush)
10805ee0 000000c0 : fseek.obj (.text:_fseek)
10805fa0 000000c0 : lowlev.obj (.text:_lseek)
10806060 000000c0 : ltoa.obj (.text:_ltoa)
10806120 000000c0 : lowlev.obj (.text:_write)
108061e0 000000a0 : trgdrv.obj (.text:_HOSTclose)
10806280 000000a0 : new_.obj (.text:___nw__FUi)
10806320 000000a0 : imath40.obj (.text:__divli)
108063c0 000000a0 : _printfi.obj (.text:__ecpy)
10806460 000000a0 : _printfi.obj (.text:__fcpy)
10806500 000000a0 : fixdli.obj (.text:__fixdli)
108065a0 000000a0 : _printfi.obj (.text:__pconv_f)
10806640 000000a0 : cpy_tbl.obj (.text:_copy_in)
108066e0 000000a0 : lowlev.obj (.text:_finddevice)
10806780 000000a0 : memcpy64.obj (.text:_memcpy)
10806820 000000a0 : memory.obj (.text:_minsert)
108068c0 000000a0 : memory.obj (.text:_mremove)
10806960 00000080 : fixdi.obj (.text:__fixdi)
108069e0 00000080 : fltlid.obj (.text:__fltlid)
10806a60 00000080 : llshift.obj (.text:__llshl)
10806ae0 00000080 : renormd.obj (.text:__renormd)
10806b60 00000080 : fprintf.obj (.text:_fprintf)
10806be0 00000080 : trgmsg.obj (.text:_readmsg)
10806c60 00000080 : lowlev.obj (.text:_unlink)
10806ce0 00000060 : assert.obj (.text:__abort_msg)
10806d40 00000060 : imath64.obj (.text:__subcull)
10806da0 00000060 : memccpy.obj (.text:_memccpy)
10806e00 00000060 : trgmsg.obj (.text:_writemsg)
10806e60 00000040 : isinf.obj (.text:___isinf)
10806ea0 00000040 : _printfi.obj (.text:___isnan)
10806ee0 00000040 : args_main.obj (.text:__args_main)
10806f20 00000040 : frcmpyd_div.obj (.text:__frcmpyd_div)
10806f60 00000040 : llshift.obj (.text:__llshru)
10806fa0 00000040 : negd.obj (.text:__negd)
10806fe0 00000040 : imath40.obj (.text:__remli)
10807020 00000040 : subd.obj (.text:__subd)
10807060 00000020 : newhandler.obj (.text:___default_new_handler__Fv)
10807080 00000020 : delete.obj (.text:___dl__FPv)
108070a0 00000020 : array_del.obj (.text:___dla__FPv)
108070c0 00000020 : array_new.obj (.text:___nwa__FUi)
108070e0 00000020 : negll.obj (.text:__negll)
10807100 00000020 : _lock.obj (.text:__nop)
10807120 00000020 : fprintf.obj (.text:__outc)
10807140 00000020 : fprintf.obj (.text:__outs)
10807160 00000020 : exit.obj (.text:_abort)
10807180 00000020 : remove.obj (.text:_remove)
.bss 0 10800060 00000000 UNINITIALIZED
.data 0 10800060 00000000 UNINITIALIZED
.stack 0 108071a0 00001000 UNINITIALIZED
108071a0 00000008 rts64plus.lib : boot.obj (.stack)
108071a8 00000ff8 --HOLE--
.sysmem 0 108081a0 00001000 UNINITIALIZED
108081a0 00000008 rts64plus.lib : memory.obj (.sysmem)
108081a8 00000ff8 --HOLE--
.far 0 108091a0 00000534 UNINITIALIZED
108091a0 00000324 rts64plus.lib : defs.obj (.far)
108094c4 00000004 : fopen.obj (.far)
108094c8 0000011c : lowlev.obj (.far)
108095e4 00000004 : vars.obj (.far)
108095e8 000000d0 : trgdrv.obj (.far)
108096b8 0000000c : exit.obj (.far)
108096c4 00000008 : _lock.obj (.far)
108096cc 00000008 : memory.obj (.far)
.const 0 108096d8 000004b8
108096d8 00000300 main.obj (.const:.string)
108099d8 00000101 rts64plus.lib : ctype.obj (.const:__ctypes_)
10809ad9 00000003 : assert.obj (.const:.string)
10809adc 00000084 libdevices.a : led.obj (.const:.string)
10809b60 00000023 rts64plus.lib : _printfi.obj (.const:.string)
10809b83 00000002 : fputs.obj (.const:.string)
10809b85 00000003 --HOLE-- [fill = 0]
10809b88 00000008 : divd.obj (.const:_initial_approx$1)
.cinit 0 10809b90 00000164
10809b90 0000005c rts64plus.lib : defs.obj (.cinit)
10809bec 00000004 --HOLE-- [fill = 0]
10809bf0 0000005c : lowlev.obj (.cinit)
10809c4c 00000004 --HOLE-- [fill = 0]
10809c50 0000002c : exit.obj (.cinit)
10809c7c 00000004 --HOLE-- [fill = 0]
10809c80 0000002c : memory.obj (.cinit)
10809cac 00000004 --HOLE-- [fill = 0]
10809cb0 0000001c : _lock.obj (.cinit)
10809ccc 00000004 --HOLE-- [fill = 0]
10809cd0 0000000c : fopen.obj (.cinit)
10809cdc 00000004 --HOLE-- [fill = 0]
10809ce0 0000000c : vars.obj (.cinit)
10809cec 00000004 --HOLE-- [fill = 0]
10809cf0 00000004 (.pad.cinit) [fill = 0]
.cio 0 10809cf4 00000120 UNINITIALIZED
10809cf4 00000120 rts64plus.lib : trgmsg.obj (.cio)
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
address name
10800060 $bss
10800060 .bss
10800060 .data
10800060 .text
10807160 C$$EXIT
10806e58 C$$IO$$
10804844 _GpioMgr_getPinVal__F10Gpio_PinId
10804720 _GpioMgr_setPinDir__F10Gpio_PinId14Gpio_Direction
108047d0 _GpioMgr_setPinVal__F10Gpio_PinId13Gpio_PinValue
108061e0 _HOSTclose
10804d60 _HOSTlseek
10805460 _HOSTopen
108059a0 _HOSTread
108042a0 _HOSTrename
10805a60 _HOSTunlink
10805b20 _HOSTwrite
10809cf4 __CIOBUF_
108081a0 __STACK_END
00001000 __STACK_SIZE
00001000 __SYSMEM_SIZE
00000001 __TI_args_main
108096c0 ___TI_enable_exit_profile_output
ffffffff ___TI_pprof_out_hndl
ffffffff ___TI_prof_data_size
ffffffff ___TI_prof_data_start
ffffffff ___binit__
10800060 ___bss__
ffffffff ___c_args__
10809b90 ___cinit__
10800060 ___data__
10807060 ___default_new_handler__Fv
10807080 ___dl__FPv
108070a0 ___dla__FPv
10800060 ___edata__
10800060 ___end__
108071a0 ___etext__
10806e60 ___isinf
10806280 ___nw__FUi
108070c0 ___nwa__FUi
ffffffff ___pinit__
10800060 ___text__
10806ce0 __abort_msg
10803940 __addd
10806ee0 __args_main
10804e60 __auto_init
10805d60 __c6xabi_divu
10805be0 __cleanup
108096b8 __cleanup_ptr
10805540 __cmpd
108099d8 __ctypes_
10800e60 __divd
10806320 __divli
10805d60 __divu
10804100 __divul
10803020 __divull
10805e20 __doflush
108096bc __dtors_ptr
10806960 __fixdi
10806500 __fixdli
108069e0 __fltlid
10803b40 __frcaddd
10804f60 __frcmpyd
10806f20 __frcmpyd_div
108094c0 __ft_end
108091a0 __ftable
10806a60 __llshl
10806f60 __llshru
108096c4 __lock
10803280 __mpyd
10806fa0 __negd
108070e0 __negll
108095e4 __new_handler
10807100 __nop
10801820 __printfi
10806fe0 __remli
10806ae0 __renormd
108071a0 __stack
10806d40 __subcull
10807020 __subd
108081a0 __sys_memory
10809380 __tmpnams
108096c8 __unlock
10805160 __wrt_ok
10807160 _abort
10805620 _atoi
10805360 _bootstrap__3LedSFv
10800000 _c_int00
10805700 _close
10806640 _copy_in
108057e0 _exit
10804c40 _fclose
10805260 _fflush
10806b60 _fprintf
108048a0 _fputc
10802260 _fputs
10802da0 _free
10805ee0 _fseek
10805fa0 _lseek
10806060 _ltoa
108008ac _main
10804420 _malloc
10806da0 _memccpy
10806780 _memcpy
108058c0 _memset
108048a0 _putc
10806be0 _readmsg
10807180 _remove
108053e0 _set__3LedSFUib
108045a0 _setvbuf
10806c60 _unlink
10806120 _write
10806e00 _writemsg
ffffffff binit
10809b90 cinit
10800060 edata
10800060 end
108071a0 etext
ffffffff pinit
GLOBAL SYMBOLS: SORTED BY Symbol Address
address name
10800000 _c_int00
10800060 $bss
10800060 .bss
10800060 .data
10800060 .text
10800060 ___bss__
10800060 ___data__
10800060 ___edata__
10800060 ___end__
10800060 ___text__
10800060 edata
10800060 end
108008ac _main
10800e60 __divd
10801820 __printfi
10802260 _fputs
10802da0 _free
10803020 __divull
10803280 __mpyd
10803940 __addd
10803b40 __frcaddd
10804100 __divul
10804420 _malloc
108045a0 _setvbuf
108048a0 _fputc
108048a0 _putc
10804c40 _fclose
10804d60 _HOSTlseek
10804f60 __frcmpyd
10805160 __wrt_ok
10805260 _fflush
10805460 _HOSTopen
10805540 __cmpd
10805620 _atoi
10805700 _close
108057e0 _exit
108058c0 _memset
108059a0 _HOSTread
10805b20 _HOSTwrite
10805be0 __cleanup
10805d60 __divu
10805e20 __doflush
10805ee0 _fseek
10805fa0 _lseek
10806060 _ltoa
10806120 _write
108061e0 _HOSTclose
10806280 ___nw__FUi
10806320 __divli
10806500 __fixdli
10806640 _copy_in
10806780 _memcpy
10806960 __fixdi
108069e0 __fltlid
10806a60 __llshl
10806ae0 __renormd
10806b60 _fprintf
10806be0 _readmsg
10806c60 _unlink
10806d40 __subcull
10806da0 _memccpy
10806e00 _writemsg
10806e58 C$$IO$$
10806e60 ___isinf
10806f60 __llshru
10806fa0 __negd
10806fe0 __remli
10807020 __subd
10807080 ___dl__FPv
108070e0 __negll
10807100 __nop
10807160 C$$EXIT
10807160 _abort
10807180 _remove
108071a0 ___etext__
108071a0 __stack
108071a0 etext
108091a0 __ftable
10809380 __tmpnams
108094c0 __ft_end
108096c4 __lock
108096c8 __unlock
108099d8 __ctypes_
10809b90 ___cinit__
10809b90 cinit
10809cf4 __CIOBUF_
ffffffff ___binit__
ffffffff ___pinit__
ffffffff binit
ffffffff pinit
[118 symbols]
