When the heap size =0, does anybody know why the printf fonction works correctly with IAR while it does not work with CCS?
Best regards
Mich
I can only guess why it works with IAR, but it doesn't work for the TI compiler because when you use printf, by default it allocates an I/O buffer. If you want to use printf without a heap, you'll need to use setvbuf to set the stdout buffer to a static object.
