I want to convert my .out file after project building to .s19 (motorola format)
Command i use for generating s19 in the post build setting:
"${CG_TOOL_HEX}.exe" -m2 --byte -memwidth 16 -romwidth 16 -order LS -exclude".trace" -exclude".args" -exclude"passwords" -exclude"csm_rsvd" -map"${BuildArtifactFileBaseName}.mxp" "${BuildArtifactFileName}" & del ${BuildArtifactFileBaseName}.s19 & ren ${BuildArtifactFileBaseName}.m00 ${BuildArtifactFileBaseName}.s19
Expected output (as i was getting with DSP-BIOS):
Actual Output (with sysbios build):
I'm doing this for my debug and release builds, same output.
I am designing a parser to read the S19 output, and hence i am failing here. Please provide inputs to identify the mistake in my conversion command.
