Hi there,
Due to RTOS constraint, code like [ dbg_LogMsg(1,"ERR."__FUNCTION__); ] is used a lot with CGT4.9.1.
CGT5.1 reports : error #18: expected a ")"
What's the replacement ?
Thanks!
Yulin.
I'm not really sure what is going on. Please build again with the options --gen_acp_raw --verbose_diagnostics. The option --gen_acp_raw causes the compiler to create a file named source_file_name.rl which contains your source before and after preprocessing. Please show the .rl file lines related to this one. The option --verbose_diagnostics causes the compiler to issue a more verbose form of the diagnostic that echoes the problem source line with a ^ character pointing to where in the line the problem begins. Please show that diagnostic.
Thanks and regards,
-George
Archaeologist,
"C:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv5e --code_state=32 --abi=ti_arm9_abi -me -O2 -g --include_path="C:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --gcc --define="_DEBUG" --diag_warning=225 --diag_error=225 --display_error_number --printf_support=nofloat --std_lib_func_redefined --preproc_with_compile --preproc_dependency="test.pp" "D:/prj/mtg_ccs6/shl/cvr730/test.c"
"D:/prj/mtg_ccs6/shl/cvr730/test.c", line 11: error #18: expected a ")"
Yulin.
George,
L 1 "D:/prj/mtg_ccs6/shl/cvr730/test.c" N#include <stdio.h> L 1 "C:/ti/ccsv6/tools/compiler/arm_5.1.6/include/stdio.h" 1 N/*****************************************************************************/ N/* STDIO.H v5.1.6 */ N/* */ N/* Copyright (c) 1993-2014 Texas Instruments Incorporated */ N/* http://www.ti.com/ */ N/* */ N/* Redistribution and use in source and binary forms, with or without */ N/* modification, are permitted provided that the following conditions */ N/* are met: */ N/* */ N/* Redistributions of source code must retain the above copyright */ N/* notice, this list of conditions and the following disclaimer. */ N/* */ N/* Redistributions in binary form must reproduce the above copyright */ N/* notice, this list of conditions and the following disclaimer in */ N/* the documentation and/or other materials provided with the */ N/* distribution. */ N/* */ N/* Neither the name of Texas Instruments Incorporated nor the names */ N/* of its contributors may be used to endorse or promote products */ N/* derived from this software without specific prior written */ N/* permission. */ N/* */ N/* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS */ N/* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT */ N/* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR */ N/* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT */ N/* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, */ N/* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */ N/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, */ N/* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY */ N/* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT */ N/* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE */ N/* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ N/* */ N/*****************************************************************************/ N#ifndef _STDIO N#define _STDIO N N N#include <linkage.h> L 1 "C:/ti/ccsv6/tools/compiler/arm_5.1.6/include/linkage.h" 1 N/*****************************************************************************/ N/* linkage.h v5.1.6 */ N/* */ N/* Copyright (c) 1998-2014 Texas Instruments Incorporated */ N/* http://www.ti.com/ */ N/* */ N/* Redistribution and use in source and binary forms, with or without */ N/* modification, are permitted provided that the following conditions */ N/* are met: */ N/* */ N/* Redistributions of source code must retain the above copyright */ N/* notice, this list of conditions and the following disclaimer. */ N/* */ N/* Redistributions in binary form must reproduce the above copyright */ N/* notice, this list of conditions and the following disclaimer in */ N/* the documentation and/or other materials provided with the */ N/* distribution. */ N/* */ N/* Neither the name of Texas Instruments Incorporated nor the names */ N/* of its contributors may be used to endorse or promote products */ N/* derived from this software without specific prior written */ N/* permission. */ N/* */ N/* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS */ N/* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT */ N/* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR */ N/* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT */ N/* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, */ N/* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */ N/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, */ N/* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY */ N/* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT */ N/* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE */ N/* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ N/* */ N/*****************************************************************************/ N N#ifndef _LINKAGE N#define _LINKAGE N N/* No modifiers are needed to access code or data */ N N#define _CODE_ACCESS N#define _DATA_ACCESS N#define _DATA_ACCESS_NEAR N N/*--------------------------------------------------------------------------*/ N/* Define _IDECL ==> how inline functions are declared */ N/*--------------------------------------------------------------------------*/ N#ifdef _INLINE N#define _IDECL static __inline N#define _IDEFN static __inline N#define __INLINE static __inline N#else S#define _IDECL extern _CODE_ACCESS S#define _IDEFN _CODE_ACCESS S#define __INLINE __EXTERN N#endif N N#endif /* ifndef _LINKAGE */ L 42 "C:/ti/ccsv6/tools/compiler/arm_5.1.6/include/stdio.h" 2 N#include <stdarg.h> L 1 "C:/ti/ccsv6/tools/compiler/arm_5.1.6/include/stdarg.h" 1 N/*****************************************************************************/ N/* stdarg.h v5.1.6 */ N/* */ N/* Copyright (c) 1996-2014 Texas Instruments Incorporated */ N/* http://www.ti.com/ */ N/* */ N/* Redistribution and use in source and binary forms, with or without */ N/* modification, are permitted provided that the following conditions */ N/* are met: */ N/* */ N/* Redistributions of source code must retain the above copyright */ N/* notice, this list of conditions and the following disclaimer. */ N/* */ N/* Redistributions in binary form must reproduce the above copyright */ N/* notice, this list of conditions and the following disclaimer in */ N/* the documentation and/or other materials provided with the */ N/* distribution. */ N/* */ N/* Neither the name of Texas Instruments Incorporated nor the names */ N/* of its contributors may be used to endorse or promote products */ N/* derived from this software without specific prior written */ N/* permission. */ N/* */ N/* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS */ N/* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT */ N/* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR */ N/* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT */ N/* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, */ N/* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */ N/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, */ N/* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY */ N/* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT */ N/* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE */ N/* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ N/* */ N/*****************************************************************************/ N N#ifndef _STDARG N#define _STDARG N N#ifdef __cplusplus S#define _NS_PREFIX std:: Snamespace std { N#else N#define _NS_PREFIX N#endif /* __cplusplus */ N N#ifdef __TI_EABI_SUPPORT__ Stypedef struct __va_list { S void * __ap; S} va_list; N#else Ntypedef char *va_list; N#endif N N#ifdef __cplusplus S} /* namespace std */ N#endif N N#define _VA_RNDUP(sz) (((sz) + 3) & ~3) N#define _VA_MASK(tp) ((__ALIGNOF__(tp) == 8) ? 7 : 3) N#define _VA_ALN(ap,tp) (((int)(ap) + _VA_MASK(tp)) & ~(_VA_MASK(tp))) N N#ifdef __TI_EABI_SUPPORT__ S#define va_start(ap, parmN) \ S ((ap).__ap = ((void *)((((int)__va_parmadr(parmN))&~3) + \ S _VA_RNDUP(sizeof(parmN))))) X#define va_start(ap, parmN) ((ap).__ap = ((void *)((((int)__va_parmadr(parmN))&~3) + _VA_RNDUP(sizeof(parmN))))) N#else N#define va_start(ap, parmN) \ N ((ap) = (__va_argref(parmN) \ N ? (_NS_PREFIX va_list)((int)__va_parmadr(parmN) + 4 ) \ N : (sizeof(parmN) < sizeof(int)) \ N ? (_NS_PREFIX va_list)((int)__va_parmadr(parmN) + 4 & ~3) \ N : (_NS_PREFIX va_list)((int)__va_parmadr(parmN) + sizeof(parmN)))) X#define va_start(ap, parmN) ((ap) = (__va_argref(parmN) ? (_NS_PREFIX va_list)((int)__va_parmadr(parmN) + 4 ) : (sizeof(parmN) < sizeof(int)) ? (_NS_PREFIX va_list)((int)__va_parmadr(parmN) + 4 & ~3) : (_NS_PREFIX va_list)((int)__va_parmadr(parmN) + sizeof(parmN)))) N#endif N N#ifdef __big_endian__ S#ifdef __TI_EABI_SUPPORT__ S#define va_arg(_ap, _type) \ S (((_ap).__ap = (void*)(_VA_ALN((_ap).__ap, _type) + \ S _VA_RNDUP(sizeof(_type)))), \ S (*(_type *)((int)(_ap).__ap - \ S (__va_argcsu(_type) ? _VA_RNDUP(sizeof(_type)) \ S : (sizeof(_type)))))) X#define va_arg(_ap, _type) (((_ap).__ap = (void*)(_VA_ALN((_ap).__ap, _type) + _VA_RNDUP(sizeof(_type)))), (*(_type *)((int)(_ap).__ap - (__va_argcsu(_type) ? _VA_RNDUP(sizeof(_type)) : (sizeof(_type)))))) S#else S#define va_arg(_ap, _type) \ S (__va_argref(_type) \ S ? ((_ap += sizeof(_type*)),(**(_type**)(_ap-(sizeof(_type*))))) \ S : ((_ap += _VA_RNDUP(sizeof(_type))),(*(_type*)(_ap-(sizeof(_type)))))) X#define va_arg(_ap, _type) (__va_argref(_type) ? ((_ap += sizeof(_type*)),(**(_type**)(_ap-(sizeof(_type*))))) : ((_ap += _VA_RNDUP(sizeof(_type))),(*(_type*)(_ap-(sizeof(_type)))))) S#endif N#else N#ifdef __TI_EABI_SUPPORT__ S#define va_arg(_ap, _type) \ S (((_ap).__ap = (void *)(_VA_ALN((_ap).__ap,_type) + \ S _VA_RNDUP(sizeof(_type)))), \ S (*(_type *) ((int)(_ap).__ap - _VA_RNDUP(sizeof(_type))))) X#define va_arg(_ap, _type) (((_ap).__ap = (void *)(_VA_ALN((_ap).__ap,_type) + _VA_RNDUP(sizeof(_type)))), (*(_type *) ((int)(_ap).__ap - _VA_RNDUP(sizeof(_type))))) N#else N#define va_arg(_ap, _type) \ N (__va_argref(_type) \ N ? ((_ap += sizeof(_type*)), (**(_type**)(_ap- sizeof(_type*)))) \ N : ((_ap += _VA_RNDUP(sizeof(_type))), \ N (*(_type*)(_ap- _VA_RNDUP(sizeof(_type)))))) X#define va_arg(_ap, _type) (__va_argref(_type) ? ((_ap += sizeof(_type*)), (**(_type**)(_ap- sizeof(_type*)))) : ((_ap += _VA_RNDUP(sizeof(_type))), (*(_type*)(_ap- _VA_RNDUP(sizeof(_type)))))) N#endif N#endif N N#define va_end(ap) ((void)0) N N#endif /* _STDARG */ N N#if defined(__cplusplus) && !defined(_CPP_STYLE_HEADER) X#if 0L && !0L Susing std::va_list; N#endif /* _CPP_STYLE_HEADER */ L 43 "C:/ti/ccsv6/tools/compiler/arm_5.1.6/include/stdio.h" 2 N N/*---------------------------------------------------------------------------*/ N/* Attributes are only available in relaxed ANSI mode. */ N/*---------------------------------------------------------------------------*/ N#ifndef __ATTRIBUTE N#if __TI_STRICT_ANSI_MODE__ X#if 0 S#define __ATTRIBUTE(attr) N#else N#define __ATTRIBUTE(attr) __attribute__(attr) N#endif N#endif N N/*---------------------------------------------------------------------------*/ N/* A header file conforming to ARM CLIB ABI (GENC-003539), should */ N/* define _AEABI_PORTABLE when _AEABI_PORTABILITY_LEVEL is defined. */ N/*---------------------------------------------------------------------------*/ N#if defined(_AEABI_PORTABILITY_LEVEL) && !defined(_AEABI_PORTABLE) X#if 0L && !0L S#define _AEABI_PORTABLE N#endif N N/*---------------------------------------------------------------------------*/ N/* The macro definition that guards CLIB ABI (GENC-003539) requirements. */ N/*---------------------------------------------------------------------------*/ N#if defined(__TI_EABI_SUPPORT__) X#if 0L S#define _AEABI_PORTABILITY_CHECK (defined(__TMS470__) && \ S defined(__TI_EABI_SUPPORT__) && \ S _AEABI_PORTABILITY_LEVEL != 0) X#define _AEABI_PORTABILITY_CHECK (defined(__TMS470__) && defined(__TI_EABI_SUPPORT__) && _AEABI_PORTABILITY_LEVEL != 0) N#else N#define _AEABI_PORTABILITY_CHECK 0 N#endif N N#ifdef __cplusplus S//---------------------------------------------------------------------------- S// <cstdio> IS RECOMMENDED OVER <stdio.h>. <stdio.h> IS PROVIDED FOR S// COMPATIBILITY WITH C AND THIS USAGE IS DEPRECATED IN C++ S//---------------------------------------------------------------------------- Sextern "C" namespace std { N#endif N N/****************************************************************************/ N/* TYPES THAT ANSI REQUIRES TO BE DEFINED */ N/****************************************************************************/ N#ifndef _SIZE_T N#define _SIZE_T Ntypedef __SIZE_T_TYPE__ size_t; Xtypedef unsigned size_t; N#endif N Ntypedef struct { N int fd; /* File descriptor */ N unsigned char* buf; /* Pointer to start of buffer */ N unsigned char* pos; /* Position in buffer */ N unsigned char* bufend; /* Pointer to end of buffer */ N unsigned char* buff_stop; /* Pointer to last read char in buffer */ N unsigned int flags; /* File status flags (see below) */ N} FILE; N N#ifndef _FPOS_T N#define _FPOS_T N#if _AEABI_PORTABILITY_CHECK X#if 0 Stypedef struct __fpos_t_struct { S unsigned long long __pos; S struct { S unsigned int __state1, __state2; S } __mbstate; S} fpos_t; N#else Ntypedef long fpos_t; N#endif /* c6x */ N#endif /* _FPOS_T */ N N/****************************************************************************/ N/* DEVICE AND STREAM RELATED MACROS */ N/****************************************************************************/ N/****************************************************************************/ N/* MACROS THAT DEFINE AND USE FILE STATUS FLAGS */ N/****************************************************************************/ N#if _AEABI_PORTABILITY_CHECK X#if 0 Sextern FILE *__aeabi_stdin, *__aeabi_stdout, *__aeabi_stderr; S#define stdin (__aeabi_stdin) S /* pointer to a FILE object associated with standard input stream */ S#define stdout (__aeabi_stdout) S /* pointer to a FILE object associated with standard output stream */ S#define stderr (__aeabi_stderr) S /* pointer to a FILE object associated with standard error stream */ Sextern const int __aeabi_IOFBF; S#define _IOFBF (__aeabi_IOFBF) Sextern const int __aeabi_IONBF; S#define _IONBF (__aeabi_IONBF) Sextern const int __aeabi_IOLBF; S#define _IOLBF (__aeabi_IOLBF) Sextern const int __aeabi_BUFSIZ; S#define BUFSIZ (__aeabi_BUFSIZ) Sextern const int __aeabi_FOPEN_MAX; S#define FOPEN_MAX (__aeabi_FOPEN_MAX) Sextern const int __aeabi_TMP_MAX; S#define TMP_MAX (__aeabi_TMP_MAX) Sextern const int __aeabi_FILENAME_MAX; S#define FILENAME_MAX (__aeabi_FILENAME_MAX) Sextern const int __aeabi_L_tmpnam; S#define L_tmpnam (__aeabi_L_tmpnam) S N#else /* _AEABI_PORTABILITY_CHECK */ N N#define _IOFBF 0x0001 N#define _IOLBF 0x0002 N#define _IONBF 0x0004 N#define _BUFFALOC 0x0008 N#define _MODER 0x0010 N#define _MODEW 0x0020 N#define _MODERW 0x0040 N#define _MODEA 0x0080 N#define _MODEBIN 0x0100 N#define _STATEOF 0x0200 N#define _STATERR 0x0400 N#define _UNGETC 0x0800 N#define _TMPFILE 0x1000 N N#define _SET(_fp, _b) (((_fp)->flags) |= (_b)) N#define _UNSET(_fp, _b) (((_fp)->flags) &= ~(_b)) N#define _STCHK(_fp, _b) (((_fp)->flags) & (_b)) N#define _BUFFMODE(_fp) (((_fp)->flags) & (_IOFBF | _IOLBF | _IONBF)) N#define _ACCMODE(_fp) (((_fp)->flags) & (_MODER | _MODEW)) N N/****************************************************************************/ N/* MACROS THAT ANSI REQUIRES TO BE DEFINED */ N/****************************************************************************/ N#define BUFSIZ 256 N N#define FOPEN_MAX _NFILE N#define FILENAME_MAX 256 N#define TMP_MAX 65535 N N#ifdef __cplusplus S#define stdin (&std::_ftable[0]) S#define stdout (&std::_ftable[1]) S#define stderr (&std::_ftable[2]) N#else N#define stdin (&_ftable[0]) N#define stdout (&_ftable[1]) N#define stderr (&_ftable[2]) N#endif N N#define L_tmpnam _LTMPNAM N N#endif /* _AEABI_PORTABILITY_CHECK */ N N#define SEEK_SET (0x0000) N#define SEEK_CUR (0x0001) N#define SEEK_END (0x0002) N N#ifndef NULL N#define NULL 0 N#endif N N#ifndef EOF N#define EOF (-1) N#endif N N/******** END OF ANSI MACROS ************************************************/ N N#define P_tmpdir "" /* Path for temp files */ N N/****************************************************************************/ N/* DEVICE AND STREAM RELATED DATA STRUCTURES AND MACROS */ N/****************************************************************************/ N#define _NFILE 10 /* Max number of files open */ N#define _LTMPNAM 16 /* Length of temp name */ N Nextern _DATA_ACCESS FILE _ftable[_NFILE]; Xextern FILE _ftable[10]; Nextern _DATA_ACCESS char __TI_tmpnams[_NFILE][_LTMPNAM]; Xextern char __TI_tmpnams[10][16]; N N/****************************************************************************/ N/* FUNCTION DEFINITIONS - ANSI */ N/****************************************************************************/ N/****************************************************************************/ N/* OPERATIONS ON FILES */ N/****************************************************************************/ Nextern _CODE_ACCESS int remove(const char *_file); Xextern int remove(const char *_file); Nextern _CODE_ACCESS int rename(const char *_old, const char *_new); Xextern int rename(const char *_old, const char *_new); Nextern _CODE_ACCESS FILE *tmpfile(void); Xextern FILE *tmpfile(void); Nextern _CODE_ACCESS char *tmpnam(char *_s); Xextern char *tmpnam(char *_s); N N/****************************************************************************/ N/* FILE ACCESS FUNCTIONS */ N/****************************************************************************/ Nextern _CODE_ACCESS int fclose(FILE *_fp); Xextern int fclose(FILE *_fp); Nextern _CODE_ACCESS FILE *fopen(const char *_fname, const char *_mode); Xextern FILE *fopen(const char *_fname, const char *_mode); Nextern _CODE_ACCESS FILE *freopen(const char *_fname, const char *_mode, Xextern FILE *freopen(const char *_fname, const char *_mode, N register FILE *_fp); Nextern _CODE_ACCESS void setbuf(register FILE *_fp, char *_buf); Xextern void setbuf(register FILE *_fp, char *_buf); Nextern _CODE_ACCESS int setvbuf(register FILE *_fp, register char *_buf, Xextern int setvbuf(register FILE *_fp, register char *_buf, N register int _type, register size_t _size); Nextern _CODE_ACCESS int fflush(register FILE *_fp); Xextern int fflush(register FILE *_fp); N N/****************************************************************************/ N/* FORMATTED INPUT/OUTPUT FUNCTIONS */ N/****************************************************************************/ Nextern _CODE_ACCESS int fprintf(FILE *_fp, const char *_format, ...) Xextern int fprintf(FILE *_fp, const char *_format, ...) N __ATTRIBUTE ((__format__ (__printf__, 2, 3))); X __attribute__((__format__ (__printf__, 2, 3))); Nextern _CODE_ACCESS int fscanf(FILE *_fp, const char *_fmt, ...) Xextern int fscanf(FILE *_fp, const char *_fmt, ...) N __ATTRIBUTE ((__format__ (__scanf__, 2, 3))); X __attribute__((__format__ (__scanf__, 2, 3))); Nextern _CODE_ACCESS int printf(const char *_format, ...) Xextern int printf(const char *_format, ...) N __ATTRIBUTE ((__format__ (__printf__, 1, 2))); X __attribute__((__format__ (__printf__, 1, 2))); Nextern _CODE_ACCESS int scanf(const char *_fmt, ...) Xextern int scanf(const char *_fmt, ...) N __ATTRIBUTE ((__format__ (__scanf__, 1, 2))); X __attribute__((__format__ (__scanf__, 1, 2))); Nextern _CODE_ACCESS int sprintf(char *_string, const char *_format, ...) Xextern int sprintf(char *_string, const char *_format, ...) N __ATTRIBUTE ((__format__ (__printf__, 2, 3))); X __attribute__((__format__ (__printf__, 2, 3))); Nextern _CODE_ACCESS int snprintf(char *_string, size_t _n, Xextern int snprintf(char *_string, size_t _n, N const char *_format, ...) N __ATTRIBUTE ((__format__ (__printf__, 3, 4))); X __attribute__((__format__ (__printf__, 3, 4))); Nextern _CODE_ACCESS int sscanf(const char *_str, const char *_fmt, ...) Xextern int sscanf(const char *_str, const char *_fmt, ...) N __ATTRIBUTE ((__format__ (__scanf__, 2, 3))); X __attribute__((__format__ (__scanf__, 2, 3))); Nextern _CODE_ACCESS int vfprintf(FILE *_fp, const char *_format, va_list _ap) Xextern int vfprintf(FILE *_fp, const char *_format, va_list _ap) N __ATTRIBUTE ((__format__ (__printf__, 2, 0))); X __attribute__((__format__ (__printf__, 2, 0))); Nextern _CODE_ACCESS int vfscanf(FILE *_fp, const char *_fmt, va_list _ap) Xextern int vfscanf(FILE *_fp, const char *_fmt, va_list _ap) N __ATTRIBUTE ((__format__ (__scanf__, 2, 0))); X __attribute__((__format__ (__scanf__, 2, 0))); Nextern _CODE_ACCESS int vprintf(const char *_format, va_list _ap) Xextern int vprintf(const char *_format, va_list _ap) N __ATTRIBUTE ((__format__ (__printf__, 1, 0))); X __attribute__((__format__ (__printf__, 1, 0))); Nextern _CODE_ACCESS int vscanf(const char *_format, va_list _ap) Xextern int vscanf(const char *_format, va_list _ap) N __ATTRIBUTE ((__format__ (__scanf__, 1, 0))); X __attribute__((__format__ (__scanf__, 1, 0))); Nextern _CODE_ACCESS int vsprintf(char *_string, const char *_format, Xextern int vsprintf(char *_string, const char *_format, N va_list _ap) N __ATTRIBUTE ((__format__ (__printf__, 2, 0))); X __attribute__((__format__ (__printf__, 2, 0))); Nextern _CODE_ACCESS int vsnprintf(char *_string, size_t _n, Xextern int vsnprintf(char *_string, size_t _n, N const char *_format, va_list _ap) N __ATTRIBUTE ((__format__ (__printf__, 3, 0))); X __attribute__((__format__ (__printf__, 3, 0))); Nextern _CODE_ACCESS int vsscanf(const char *_str, const char *_fmt, va_list _ap) Xextern int vsscanf(const char *_str, const char *_fmt, va_list _ap) N __ATTRIBUTE ((__format__ (__scanf__, 2, 0))); X __attribute__((__format__ (__scanf__, 2, 0))); N N/****************************************************************************/ N/* CHARACTER INPUT/OUTPUT FUNCTIONS */ N/****************************************************************************/ Nextern _CODE_ACCESS int fgetc(register FILE *_fp); Xextern int fgetc(register FILE *_fp); Nextern _CODE_ACCESS char *fgets(char *_ptr, register int _size, Xextern char *fgets(char *_ptr, register int _size, N register FILE *_fp); Nextern _CODE_ACCESS int fputc(int _c, register FILE *_fp); Xextern int fputc(int _c, register FILE *_fp); Nextern _CODE_ACCESS int fputs(const char *_ptr, register FILE *_fp); Xextern int fputs(const char *_ptr, register FILE *_fp); Nextern _CODE_ACCESS int getc(FILE *_p); Xextern int getc(FILE *_p); Nextern _CODE_ACCESS int getchar(void); Xextern int getchar(void); Nextern _CODE_ACCESS char *gets(char *_ptr); Xextern char *gets(char *_ptr); Nextern _CODE_ACCESS int putc(int _x, FILE *_fp); Xextern int putc(int _x, FILE *_fp); Nextern _CODE_ACCESS int putchar(int _x); Xextern int putchar(int _x); Nextern _CODE_ACCESS int puts(const char *_ptr); Xextern int puts(const char *_ptr); Nextern _CODE_ACCESS int ungetc(int _c, register FILE *_fp); Xextern int ungetc(int _c, register FILE *_fp); N N/****************************************************************************/ N/* DIRECT INPUT/OUTPUT FUNCTIONS */ N/****************************************************************************/ Nextern _CODE_ACCESS size_t fread(void *_ptr, size_t _size, size_t _count, Xextern size_t fread(void *_ptr, size_t _size, size_t _count, N FILE *_fp); Nextern _CODE_ACCESS size_t fwrite(const void *_ptr, size_t _size, Xextern size_t fwrite(const void *_ptr, size_t _size, N size_t _count, register FILE *_fp); N N/****************************************************************************/ N/* FILE POSITIONING FUNCTIONS */ N/****************************************************************************/ Nextern _CODE_ACCESS int fgetpos(FILE *_fp, fpos_t *_pos); Xextern int fgetpos(FILE *_fp, fpos_t *_pos); Nextern _CODE_ACCESS int fseek(register FILE *_fp, long _offset, Xextern int fseek(register FILE *_fp, long _offset, N int _ptrname); Nextern _CODE_ACCESS int fsetpos(FILE *_fp, const fpos_t *_pos); Xextern int fsetpos(FILE *_fp, const fpos_t *_pos); Nextern _CODE_ACCESS long ftell(FILE *_fp); Xextern long ftell(FILE *_fp); Nextern _CODE_ACCESS void rewind(register FILE *_fp); Xextern void rewind(register FILE *_fp); N N/****************************************************************************/ N/* ERROR-HANDLING FUNCTIONS */ N/****************************************************************************/ Nextern _CODE_ACCESS void clearerr(FILE *_fp); Xextern void clearerr(FILE *_fp); Nextern _CODE_ACCESS int feof(FILE *_fp); Xextern int feof(FILE *_fp); Nextern _CODE_ACCESS int ferror(FILE *_fp); Xextern int ferror(FILE *_fp); Nextern _CODE_ACCESS void perror(const char *_s); Xextern void perror(const char *_s); N N#define _getchar() getc(stdin) N#define _putchar(_x) putc((_x), stdout) N#define _clearerr(_fp) ((void) ((_fp)->flags &= ~(_STATERR | _STATEOF))) N N#define _ferror(_x) ((_x)->flags & _STATERR) N N#define _remove(_fl) (unlink((_fl))) N N#ifdef __cplusplus S} /* extern "C" namespace std */ N#endif /* __cplusplus */ N N#endif /* #ifndef _STDIO */ N N#if defined(__cplusplus) && !defined(_CPP_STYLE_HEADER) X#if 0L && !0L Susing std::size_t; Susing std::FILE; Susing std::fpos_t; Susing std::_ftable; Susing std::__TI_tmpnams; Susing std::remove; Susing std::rename; Susing std::tmpfile; Susing std::tmpnam; Susing std::fclose; Susing std::fopen; Susing std::freopen; Susing std::setbuf; Susing std::setvbuf; Susing std::fflush; Susing std::fprintf; Susing std::fscanf; Susing std::printf; Susing std::scanf; Susing std::sprintf; Susing std::snprintf; Susing std::sscanf; Susing std::vfprintf; Susing std::vprintf; Susing std::vsprintf; Susing std::vsnprintf; Susing std::fgetc; Susing std::fgets; Susing std::fputc; Susing std::fputs; Susing std::getc; Susing std::getchar; Susing std::gets; Susing std::putc; Susing std::putchar; Susing std::puts; Susing std::ungetc; Susing std::fread; Susing std::fwrite; Susing std::fgetpos; Susing std::fseek; Susing std::fsetpos; Susing std::ftell; Susing std::rewind; Susing std::clearerr; Susing std::feof; Susing std::ferror; Susing std::perror; S#if _AEABI_PORTABILITY_CHECK Susing std::__aeabi_stdin; Susing std::__aeabi_stdout; Susing std::__aeabi_stderr; Susing std::__aeabi_IOFBF; Susing std::__aeabi_IONBF; Susing std::__aeabi_IOLBF; Susing std::__aeabi_BUFSIZ; Susing std::__aeabi_FOPEN_MAX; Susing std::__aeabi_TMP_MAX; Susing std::__aeabi_FILENAME_MAX; Susing std::__aeabi_L_tmpnam; S#endif S N#endif /* _CPP_STYLE_HEADER */ N N L 2 "D:/prj/mtg_ccs6/shl/cvr730/test.c" 2 N Nint dbg_LogMsg(unsigned char id, char* msg) N{ N printf("%03d %s\n",id,msg); N return 0; N} N Nvoid main(void) N{ E "D:/prj/mtg_ccs6/shl/cvr730/test.c" 11 22 expected a ")" N dbg_LogMsg(55,"ERR."__FUNCTION__); N}
"C:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv5e --code_state=32 --abi=ti_arm9_abi -me -O2 -g --include_path="C:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --gcc --define="_DEBUG" --diag_warning=225 --diag_error=225 --display_error_number --printf_support=nofloat --std_lib_func_redefined --preproc_with_compile --preproc_dependency="test.pp" --gen_acp_raw --verbose_diagnostics "D:/prj/mtg_ccs6/shl/cvr730/test.c"
1 error detected in the compilation of "D:/prj/mtg_ccs6/shl/cvr730/test.c".
Yulin.
__FUNCTION__ is not a preprocessor name. It is a variable. You need to change your code to expect a variable where you want to use __FUNCTION__. The implementation of dbg_LogMsg needs to change to ...
int dbg_LogMsg(unsigned char, char *, const char *);
A call to it looks like ...
dbg_LogMsg(55, "ERR.", __FUNCTION__);
The GCC compiler documentation on __FUNCTION__ can be found at https://gcc.gnu.org/onlinedocs/gcc/Function-Names.html .
Thanks and regards,
-George
