Please help me find this vexing problem. Using CCS 6.0.1.00040, setting the stack size does not appear to change the linker behavior. It appears that the generated Linker.cmd file overrides the command line option. How can I increase the stack size when it ignores my input?
.cproject file:
<option id="com.ti.ccstudio.buildDefinitions.MSP430_4.3.linkerID.STACK_SIZE.495318596" name="Set C system stack size (--stack_size, -stack)" superClass="com.ti.ccstudio.buildDefinitions.MSP430_4.3.linkerID.STACK_SIZE" value="0xFF" valueType="string"/>
Link command:
"C:/ti6/ccsv6/tools/compiler/msp430_4.3.4/bin/cl430" -vmspx --abi=eabi --code_model=small --data_model=small -O4 --opt_for_speed=2 --advice:power="all" --advice:hw_config="1.1,1.2" -g --cpp_default --define=__MSP430FR5739__ --diag_warning=225 --display_error_number --diag_wrap=off --silicon_errata=CPU15 --silicon_errata=CPU18 --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --single_inline --remove_hooks_when_inlining --printf_support=nofloat -z -m"Pass4.map" --heap_size=0xFF --stack_size=0xFF --use_hw_mpy=F5 --cinit_hold_wdt=on -i"C:/ti6/ccsv6/ccs_base/msp430/include" -i"C:/ti6/ccsv6/tools/compiler/msp430_4.3.4/lib" -i"C:/ti6/ccsv6/tools/compiler/msp430_4.3.4/include" -i"C:/ti6/ccsv6/ccs_base/msp430/lib" -i"C:/ti6/ccsv6/ccs_base/msp430/lib/5xx_6xx_FRxx" --reread_libs --diag_remark=10252-D --warn_sections --display_error_number --diag_wrap=off --xml_link_info="Pass4_linkInfo.xml" --scan_libraries --rom_model --fill_value=0x00 -o "Pass4.out" -l"./configPkg/linker.cmd" "../lnk_msp430fr5739.cmd"
Linker.cmd:
/* Elf symbols */
--symbol_map __TI_STACK_BASE=_stack
--symbol_map __TI_STACK_SIZE=_STACK_SIZE
--symbol_map __TI_STATIC_BASE=__bss__
--symbol_map __c_int00=_c_int00
--symbol_map __TI_cleanup_ptr=_cleanup_ptr
--symbol_map __TI_dtors_ptr=_dtors_ptr
--args 0x0
-heap 0x0
-stack 0x40
PROJECT_linInfo.xml:
<object_component id="oc-9d">
<name>.stack</name>
<uninitialized>true</uninitialized>
<run_address>0x1fc0</run_address>
<size>0x4</size>
<input_file_ref idref="fl-17"/>
</object_component>
