I was wondering if it possible to output a statically linked elf binary? The Code Generation Tools seem to only have options for dynamically linked.
Cheers,
Kuba
Cheers,
Kuba
Thanks for your reply.
I have just tried what you said - When I run the build tools within CCStudio on a fresh project, none of the files are identified as an ELF executable, statically linked (using the 'file' command). All of them are data, text, and xml.
Am I missing something..?
When I start playing around with the options, for example using --linux, I get a dynamically linked ELF executable.
What I'm looking for is a way to build a statically linked ELF executable.
Cheers,
Kuba
By default, C6000 executables are static COFF executables. You need to use EABI. The --linux option implies both --abi=eabi and --dynamic, and you do not want --dynamic.
