I am porting IAR code to CCS V6.0.
I find the code size using TI compiler TI4.3.1 was bit higher , so i am trying to decided to see the code size with GCC in CCS6.0
After i change the compiler and i build in GCC in CCS , it gives me errors.
fatal error: intrinsics.h: No such file or directory abs.c line 25 C/C++ Problem
I want to know which is the intrinsic.h fileor equivalent in GCC compiler (CCS6).
Also where i can find documents regarding porting IAR to CCS GCC compiler ?
