Hi All,
Does anyone know what this warning message is meaning?
warning #24017-D: Option --optimizer_interlist is not valid with -Ooff
I did enable interlisting to get a asm output, but what's the Coff?
TTjarco
Hi All,
TTjarco
The option --optimizer_interlist has meaning only if you build with optimization. However, you have disabled optimization with the option --opt_level=off. A shortened equivalent option is -Ooff. You might be using it implicitly. The solution is to use --src_interlist instead of --optimizer_interlist. The --src_interlist option interlists C code comments into the assembly output without regard to the optimization level.
Thanks and regards,
-George
