I have add a Post-build steps to convert the bin file to intel hex file, and configure Specify maximum number of data items per line of output as 16. But the generated hex file is 32bytes per line.
hex file as follow:
:2001E0003504010035040100350401000000000000000000350401003504010035040100A3
:20020000350401003504010000000000000000003504010035040100350401003504010082
:200220003504010035040100350401003504010035040100350401003504010035040100EE
:200240003504010035040100350401003504010035040100350401003504010035040100CE
:0C026000350401003504010035040100E4
:20026C002DE9F04306462DED018A7079ADF1100D16F002FFAFA20CCA11F0FCFF14F068FE00
command:
"${CCS_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/armofd" "${CG_TOOL_ROOT}/bin/armhex" "${CCS_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin"
"${CG_TOOL_ROOT}/bin/armhex" -i "${BuildArtifactFileName}" -o="${BuildArtifactFileBaseName}.hex" -memwidth=8 -romwidth=32 -olength=16
Is this a compiler issue? Or TI has another tools to convert?
