The attachment arm_compiler_incorrect_optimization.zip contains bl_hsmmcsd.pp which is a pre-processed source file, and bl_hsmmcsd.asm which is the assembler listing file produced by the compiler when the following build options were used:
"/opt/ti/ti_ccs6_1/ccsv6/tools/compiler/ti-cgt-arm_5.2.4/bin/armcl" -mv7A8 --code_state=32 --abi=eabi -me -O2 --include_path="/opt/ti/ti_ccs6_1/ccsv6/tools/compiler/ti-cgt-arm_5.2.4/include" --include_path="/home/Mr_Halfword/AM3352-SOM-EVB_bare_metal/bootloader" --include_path="/home/Mr_Halfword/AM3352-SOM-EVB_bare_metal/AM3352_SOM_platform" --include_path="/opt/ti/AM335X_StarterWare_02_00_01_01/include/armv7a" --include_path="/opt/ti/AM335X_StarterWare_02_00_01_01/include" --include_path="/opt/ti/AM335X_StarterWare_02_00_01_01/include/hw" --include_path="/opt/ti/AM335X_StarterWare_02_00_01_01/include/armv7a/am335x" --include_path="/opt/ti/AM335X_StarterWare_02_00_01_01/third_party/fatfs/src" --include_path="/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/include" --include_path="/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/include/armv7a/am335x" --include_path="/opt/ti/AM335X_StarterWare_02_00_01_01/mmcsdlib/include" -g --gcc --preproc_with_comment --preproc_with_compile --define=am335x --define=AM3352_SOM --define=MMCSD --define=am3352 --display_error_number --diag_warning=225 --diag_wrap=off --src_interlist "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c"
When compiled with the optimization level of 2, the ARM v5.2.4 compiler was found to generate incorrect code for the following loop in the HSMMCSDXferStatusGet function:
for (i = 0; i < hsmmcsd_dataLen; i+=4) { temp = HWREG(MMCSD_BASE + MMCHS_DATA); hsmmcsd_buffer[i] = *((char*)&temp); hsmmcsd_buffer[i+1] = *((char*)&temp + 1); hsmmcsd_buffer[i+2] = *((char*)&temp + 2); hsmmcsd_buffer[i+3] = *((char*)&temp + 3); }
The symptom of the incorrect code observed in the debugger was elements for the "hsmmcsd_buffer[i] = *((char*)&temp)" writes were not correct. E.g.:
- The value of hsmmcsd_buffer[0] was zero.
- The expected value for hsmmcsd_buffer[0] appeared in hsmmcsd_buffer[4].
- The expected value for hsmmcsd_buffer[4] appeared in hsmmcsd_buffer[8].
The pre-processed version of the loop is:
for (i = 0; i < hsmmcsd_dataLen; i+=4) { temp = (*((volatile unsigned int *)((0x48060000) + (0x220)))); hsmmcsd_buffer[i] = *((char*)&temp); hsmmcsd_buffer[i+1] = *((char*)&temp + 1); hsmmcsd_buffer[i+2] = *((char*)&temp + 2); hsmmcsd_buffer[i+3] = *((char*)&temp + 3); }
The assembler listing file shows the following code has been generated for the loop:
;* --------------------------------------------------------------------------* ;** ----------------------- U$25 = &U$10[-4]; ;** 272 ----------------------- L$1 = U$16+3u>>2; ;** ----------------------- #pragma MUST_ITERATE(1, 1073741823, 1) ;** ----------------------- #pragma LOOP_FLAGS(4096u) .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 272,column 21,is_stmt,isa 2 ADD A1, A1, #3 ; [DPU_8_PIPE0] |272| SUB V9, V9, #4 ; [DPU_8_PIPE1] MOV A1, A1, LSR #2 ; [DPU_8_PIPE0] |272| ;* --------------------------------------------------------------------------* ;* BEGIN LOOP ||$C$L3|| ;* ;* Loop source line : 270 ;* Loop closing brace source line : 277 ;* Known Minimum Trip Count : 1 ;* Known Maximum Trip Count : 1073741823 ;* Known Max Trip Count Factor : 1 ;* --------------------------------------------------------------------------* ||$C$L3||: ;** -----------------------g6: ;** 272 ----------------------- temp = *(volatile unsigned *)0x48060220u; ;** 273 ----------------------- *(U$25 += 4) = *&temp; ;** 274 ----------------------- U$25[1] = *(&temp+1); ;** 275 ----------------------- U$25[2] = *(&temp+2); ;** 276 ----------------------- U$25[3] = *(&temp+3); ;** 270 ----------------------- if ( --L$1 ) goto g6; LDR A3, [V1, #0] ; [DPU_8_PIPE0] |272| .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 273,column 21,is_stmt,isa 2 LDRB A2, [SP, #4] ; [DPU_8_PIPE0] |273| .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 272,column 21,is_stmt,isa 2 STR A3, [SP, #4] ; [DPU_8_PIPE0] |272| .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 273,column 21,is_stmt,isa 2 STRB A2, [V9, #4]! ; [DPU_8_PIPE0] |273| .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 274,column 21,is_stmt,isa 2 LDRB LR, [SP, #5] ; [DPU_8_PIPE0] |274| STRB LR, [V9, #1] ; [DPU_8_PIPE0] |274| .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 275,column 21,is_stmt,isa 2 LDRB A2, [SP, #6] ; [DPU_8_PIPE0] |275| STRB A2, [V9, #2] ; [DPU_8_PIPE0] |275| .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 276,column 21,is_stmt,isa 2 LDRB A2, [SP, #7] ; [DPU_8_PIPE0] |276| .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 270,column 29,is_stmt,isa 2 SUBS A1, A1, #1 ; [DPU_8_PIPE1] |270| .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 276,column 21,is_stmt,isa 2 STRB A2, [V9, #3] ; [DPU_8_PIPE0] |276| .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 270,column 29,is_stmt,isa 2 BNE ||$C$L3|| ; [DPU_8_PIPE1] |270| ; BRANCHCC OCCURS {||$C$L3||} ; [] |270|
In the generated loop, the temp variable is at offset 4 on the stack, and V1 holds the address for MMCSD_BASE + MMCHS_DATA (which is the hardware register which is the source of the data). Analysis on the generated assembler which I think is incorrect:
LDR A3, [V1, #0] ; [DPU_8_PIPE0] |272| // Load A3 from HWREG(MMCSD_BASE + MMCHS_DATA) .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 273,column 21,is_stmt,isa 2 LDRB A2, [SP, #4] ; [DPU_8_PIPE0] |273| // Load A2 from the byte at address of temp+0 .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 272,column 21,is_stmt,isa 2 STR A3, [SP, #4] ; [DPU_8_PIPE0] |272| // Write A3 to the temp variable .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 273,column 21,is_stmt,isa 2 STRB A2, [V9, #4]! ; [DPU_8_PIPE0] |273| // Write A2 to the byte hsmmcsd_buffer[i], which is the value from temp on the *previous* loop iteration .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 274,column 21,is_stmt,isa 2
i.e. believe the correct instruction sequence should be:
LDR A3, [V1, #0] ; [DPU_8_PIPE0] |272| // Load A3 from HWREG(MMCSD_BASE + MMCHS_DATA) .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 273,column 21,is_stmt,isa 2 STR A3, [SP, #4] ; [DPU_8_PIPE0] |272| // Write A3 to the temp variable .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 273,column 21,is_stmt,isa 2 LDRB A2, [SP, #4] ; [DPU_8_PIPE0] |273| // Load A2 from the byte at address of temp+0 .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 272,column 21,is_stmt,isa 2 STRB A2, [V9, #4]! ; [DPU_8_PIPE0] |273| // Write A2 to the byte hsmmcsd_buffer[i], which is the value from temp on the current iteration .dwpsn file "/opt/ti/AM335X_StarterWare_02_00_01_01/bootloader/src/bl_hsmmcsd.c",line 274,column 21,is_stmt,isa 2
As a work-around the following was used to compile the HSMMCSDXferStatusGet function at optimization level 1, leaving the rest of the source file compiled at optimization level 2:
#pragma FUNCTION_OPTIONS(HSMMCSDXferStatusGet,"--opt_level=1")
With this change the program operated correctly.
Note that I haven't tried to create a smaller standalone test case, hopefully the attached preprocessed source file will allow the problem to be re-created.
