so i tried to compile a file and i get this message
>> warning: Backtracked too many times
>> internal error: compress_section: Compressor could not converge
>> Compilation failure
i got this when i added 3 new cases to a switch statement. did i hit the switch statement limit? how do i fix this?
UPDATE:
So after some debugging including all the case statements is not what is causing it, it is the meat of one of the statements. so in that case statement i can get it to compile if i remove code similar to this
while(isConnected() == FALSE)
Task_sleep(100);
ChangeState(NEW_STATE);
if i do not include that code it compiles
further information: if i put it in release mode i do not have this problem so it is apparently a debug mode issue
