C:/ti/ccsv6/tools/compiler/gcc-arm-none-eabi-4_7-2013q3/arm-none-eabi/bin/gcc -I C:/ti/vision_sdk/tools/network_tools/build/../common/src -I. network_api.c -M > MAKEFILE.DEPEND
gcc.exe: error: CreateProcess: No such file or directory
I recommend you go about it with something similar to this ...
>type stub.c void main() {} >C:\ti\ccsv6\tools\compiler\gcc-arm-none-eabi-4_8-2014q3\bin\gccvar.bat >arm-none-eabi-gcc stub.c -M stub.o: stub.c >arm-none-eabi-gcc stub.c -o stub -lc -lgcc -lnosys
The command on line 1 shows you the contents of stub.c The command on line 4 shows you how to invoke a batch file that changes the path, but only for the current command window. The command on line 6 is what you attempted to do. The results are dumped to the screen, instead of being captured in a file. The command on line 9 shows you how to build and link all in one command line. The 3 -l options tell the compiler to use those standard libraries in the link.
Thanks and regards,
-George
