Hello fellow engineers,
Is there a way to force compiler to override default sections (.text, .data, .bss, ...)?
I have read the compiler documentation (SPRU514G) but I did not find anything related to renaming sections. The toolchain does not have tool for manipulating sections in object files either. The only way seems to be passing sections definitions to the linker but this out of the question since it forces me to maintain specific section files to every output executable. Incremental linking could solve this issue but we are using CMake for our project and I think making CMake understand concept of incremental linking would take a lot of work. Also I don't like compiler pragmas (e.g. CODE_SECTION) as I would need to add one pragma for each variable or function in the library.
To clarify my problem consider following:
library foo:
* foo.obj
* foo1.obj
* foo2.obj
library bar:
* bar.obj
* bar1.obj
* bar2.obj
executable foobar:
* library foo
* library bar
* linker_sections.cmd
executable foo:
* library foo
executable bar:
* library bar
In order to place sections from foo and bar libraries to memory segment "FOO" in the executable foobar, the linker_section.cmd file must have something like this:
SECTIONS {
GROUP {
.foo.bss: {
-l"foo.lib" (.ebss, .bss, .econst, .const)
-l"bar.lib" (.ebss, .bss, .econst, .const)
} load = FOO, PAGE = 1
SECTIONS {
GROUP {
.foo.text: {
-l"foo.lib" (.text)
-l"bar.lib" (.text)
} load = FOO, PAGE = 0
However, I cannot reuse this linker_sections.cmd file for executables foo since it links bar library to the executable. More elegant solution would be renaming sections in libraries to include prefix libfoo: and use following shared linker_sections.cmd:
SECTIONS {
GROUP {
.foo.bss: {
*(libfoo:.bss)
*(libbar:.bss)
SECTIONS {
GROUP {
.foo.text: {
*(libfoo:.text)
*(libbar:.text)
This linker_sections.cmd file could be shared with all executables. (The syntax might not be correct but should give you some idea what I am looking for).
Any advices? Thank you for at least reading this post! :)
