In the FPU 1.50 library there is the below function.
The comment at the end is:
";--- Last iteration done seperately to avoid possible pointer overrun into
; undefined memory"
While I understand and see that they are just dropping the ++ increment of the address pointer? and I assume them to mean that if it just so happens that this points to memory that is 'undefined' which I assume to mean an address that doesn't exist in the memory map from say the linker file.
What exact error would that cause? I mean if I am exiting this function there is no real harm in the address pointer pointing to an invalid address? So my question is why have they gone to the effort to prevent the address pointer from incrementing?
;;! \file source/vector/mpy_SP_RVxCV.asm
;;! \brief C-Callable multiplication of a real vector and a complex vector
;;! \author David M. Alter
;;! \date 07/14/11
;; HISTORY:
;; 07/14/11 - original (D. Alter)
;; DESCRIPTION: C-Callable multiplication of a real vector and a complex vector
;; y_re[i] = x[i]*w_re[i]
;; y_im[i] = x[i]*w_im[i]
;; FUNCTION:
;; extern void mpy_SP_RVxCV(complex_float *y, const complex_float *w,
;; const float32 *x, const Uint16 N)
;; USAGE: mpy_SP_RVxCV(y, x, c, N);
;; PARAMETERS: complex_float *y = result complex array
;; complex_float *w = input complex array
;; float32 *x = input real array
;; Uint16 N = length of w, x, and y arrays
;; RETURNS: none
;; BENCHMARK: 5*N + 15 cycles (including the call and return)
;; NOTES:
;; 1) N must be at least 2.
;; 2) The inputs and return value are of type 'complex_float':
;; typedef struct {
;; float32 dat[2];
;; } complex_float;
;; Group: C2000
;; Target Family: C28x+FPU32
;; Copyright (C) 2015 Texas Instruments Incorporated - http://www.ti.com/
;; ALL RIGHTS RESERVED
;;$TI Release: C28x Floating Point Unit Library V1.50.00.00 $
;;$Release Date: Jun 2, 2015 $
.global _mpy_SP_RVxCV
.text
_mpy_SP_RVxCV:
MOVL XAR6, *-SP[4] ;XAR6 = &x
ADDB AL, #-2 ;Subtract 2 from N since RPTB is 'n-1'
;times, and last iteration done separately
MOV32 R0H, *XAR5++ ;load first w_re value
;---Main loop
RPTB end_loop, @AL
MOV32 R1H, *XAR6++ ;load next x value
MPYF32 R2H, R1H, R0H ;y_re[i] = x[i]*w_re[i]
|| MOV32 R0H, *XAR5++ ;load next w_im
MPYF32 R3H, R1H, R0H ;y_re[i] = x[i]*w_re[i]
|| MOV32 R0H, *XAR5++ ;load next w_re
MOV32 *XAR4++, R2H ;store y_re[i]
MOV32 *XAR4++, R3H ;store y_im[i]
end_loop:
; undefined memory
MOV32 R1H, *XAR6 ;load next x value
|| MOV32 R0H, *XAR5 ;load next w_im
MOV32 *XAR4, R3H ;store y_im[i]
;Finish up
LRETR ;return
;end of function _mpy_SP_RVxCV()
.end
;; End of File
