The enclosed program (extract.c) is an extract from my larger code. When compiled this way:
msp430-elf-gcc -Os -g -c extract.c
the resulting object code ends up incorrect. See the enclosed object dump file (dump.txt) with my annotations.
Description:
The program (function qfree) amounts to two loops. When the second loop is entered, variable chunk (held in r14) is not initialized properly, but its value as left by the previous loop is incorrectly assumed. The problem disappears when chunk is declared as volatile.
typedef unsigned int word; typedef word *address; static address *mpools; #define m_nextp(c) ((address)(*(c))) #define m_setnextp(c,p) (*(c) = (word)(p)) #define m_size(c) (*((c)-1)) #define m_magic(c) (*((c)+1)) #define m_hdrlen 1 #define MA_NP 0 #define NULL 0 static void qfree (address ch) { #if 0 // Trying to circumvent a bug in TI MSPGCC volatile #endif address chunk, cc; cc = (address)(mpools + MA_NP); for (chunk = mpools [MA_NP]; chunk != NULL; chunk = m_nextp (chunk)) { if (chunk + m_size (chunk) + m_hdrlen == ch) { /* Merge at the front */ m_setnextp (cc, m_nextp (chunk)); m_size (chunk) += m_hdrlen + m_size (ch); ch = chunk; } else if (ch + m_size (ch) + m_hdrlen == chunk) { /* Merge at the back */ m_setnextp (cc, m_nextp (chunk)); m_size (ch) += m_hdrlen + m_size (chunk); } else { /* Skip */ cc = chunk; } } /* Insert */ cc = (address)(mpools + MA_NP); for (chunk = mpools [MA_NP]; chunk != NULL; cc = chunk, chunk = m_nextp (chunk)) if (m_size (chunk) >= m_size (ch)) break; m_setnextp (ch, chunk); m_setnextp (cc, ch); m_magic (ch) = 0xdeaf; } void initializer (address *a) { mpools = a; } void freeer (address a) { qfree (a); } void secondfreer (address a) { // To prevent inline compilation (for clarity) qfree (a + 2); }
extract.o: file format elf32-msp430 Disassembly of section .text: 00000000 <qfree>: qfree(): C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:15 0: 1a 15 pushm #2, r10 ;16-bit words 00000002 <.LCFI0>: C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:23 2: 1b 42 00 00 mov &0x0000,r11 ;0x0000 00000006 <.LVL1>: // =============================================== // PG: initializing chunk for the first loop (r14) // =============================================== 6: 2e 4b mov @r11, r14 ; 00000008 <.LVL2>: C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 8: 0a 4b mov r11, r10 ; a: 0d 4e mov r14, r13 ; 0000000c <.L2>: c: 0d 93 cmp #0, r13 ;r3 As==00 // ============================================================== // PG: this exits the first loop and enters the second one at .L6 // ============================================================== e: 00 24 jz $+2 ;abs 0x10 00000010 <.Loc.26.1>: 10: 1f 4d fe ff mov -2(r13),r15 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 (discriminator 1) 14: 1f 53 inc r15 ; 16: 0f 5f rla r15 ; 18: 0f 5d add r13, r15 ; 1a: 29 4d mov @r13, r9 ; // ============= // PG: r12 is ch // ============= 1c: 0c 9f cmp r15, r12 ; 1e: 00 20 jnz $+2 ;abs 0x20 00000020 <.Loc.28.1>: 20: 8a 49 00 00 mov r9, 0(r10) ; 00000024 <.Loc.29.1>: C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:26 24: 1c 4c fe ff mov -2(r12),r12 ; 00000028 <.LVL4>: 28: 1c 5d fe ff add -2(r13),r12 ; 2c: 1c 53 inc r12 ; 2e: 8d 4c fe ff mov r12, -2(r13) ; 0xfffe 00000032 <.LVL5>: 32: 0c 4d mov r13, r12 ; 34: 30 40 00 00 br #0x0000 ; 00000038 <.L3>: 38: 1f 4c fe ff mov -2(r12),r15 ; 3c: 1f 53 inc r15 ; 3e: 0f 5f rla r15 ; 40: 0f 5c add r12, r15 ; 42: 0d 9f cmp r15, r13 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:28 44: 00 20 jnz $+2 ;abs 0x46 00000046 <.Loc.33.1>: 46: 8a 49 00 00 mov r9, 0(r10) ; 0000004a <.Loc.34.1>: 4a: 1f 4c fe ff mov -2(r12),r15 ; 4e: 1f 5d fe ff add -2(r13),r15 ; 52: 1f 53 inc r15 ; 54: 8c 4f fe ff mov r15, -2(r12) ; 0xfffe 58: 30 40 00 00 br #0x0000 ; 0000005c <.L9>: 5c: 0a 4d mov r13, r10 ; 0000005e <.L4>: 5e: 2d 4d mov @r13, r13 ; 60: 30 40 00 00 br #0x0000 ; 00000064 <.L8>: // ========================================== // PG: if (m_size (chunk) >= m_size (ch)) ... // ========================================== 64: 9e 9c fe ff cmp -2(r12),-2(r14) ; 0xfffe 68: fe ff C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:29 6a: 00 2c jc $+2 ;abs 0x6c 0000006c <.LVL10>: // =================================================================== // PG: What is in r14 now??? It is used here as chunk, but it is never // initialized for the second loop!!! // =================================================================== 6c: 0b 4e mov r14, r11 ; 6e: 2e 4e mov @r14, r14 ; 00000070 <.L6>: // ====================================================================== // PG: Here is actually where the second loop is entered with r14 left as // it was at the end of the first loop! // ====================================================================== 70: 0e 93 cmp #0, r14 ;r3 As==00 72: 00 20 jnz $+2 ;abs 0x74 00000074 <.L7>: 74: 8c 4e 00 00 mov r14, 0(r12) ; 00000078 <.Loc.49.1>: 78: 8b 4c 00 00 mov r12, 0(r11) ; 0000007c <.Loc.50.1>: 7c: bc 40 af de mov #57007, 2(r12) ;#0xdeaf 80: 02 00 00000082 <.Loc.52.1>: 82: 19 17 popm #2, r10 ;16-bit words 84: 30 41 ret // ============================================================================ // ============================================================================ // ============================================================================ 00000086 <initializer>: initializer(): 86: 82 4c 00 00 mov r12, &0x0000 ; 0000008a <.Loc.56.1>: 8a: 30 41 ret 0000008c <freeer>: 8c: b0 12 00 00 call #0 ; 00000090 <.LVL14>: 90: 30 41 ret 00000092 <secondfreer>: 92: 2c 52 add #4, r12 ;r2 As==10 00000094 <.LVL16>: 94: b0 12 00 00 call #0 ; 00000098 <.LVL17>: 98: 30 41 ret Disassembly of section .bss: 00000000 <mpools>: ... Disassembly of section .debug_frame: 00000000 <.debug_frame>: qfree(): C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:15 0: 10 00 bra @r0+ ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:23 2: 00 00 beq 4: ff ff .word 0xffff; ???? 6: ff ff .word 0xffff; ???? C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 8: 03 00 mova @r0, r3 ; a: 01 7e subc r14, r1 ; c: 00 0c bra @r12 ; e: 01 02 mova @r2, r1 ; 10: 80 01 00 00 mova #65536, r0 ;0x10000 C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 (discriminator 1) 14: 18 00 mova @r0+, r8 ; ... 22: 00 00 beq C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:26 24: 04 00 mova @r0, r4 ; 26: 00 00 beq 28: 00 0e bra @r14 ; 2a: 06 8a sub r10, r6 ; 2c: 02 89 sub r9, r2 ; 2e: 03 00 mova @r0, r3 ; 30: 0c 00 mova @r0, r12 ; ... 3e: 00 00 beq 40: 0c 00 mova @r0, r12 ; ... C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:28 4e: 00 00 beq 50: 0c 00 mova @r0, r12 ; ... Disassembly of section .debug_info: 00000000 <.debug_info>: C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:15 0: 28 01 00 00 mova &65536, r8 ;0x10000 C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:23 4: 04 00 mova @r0, r4 ; 6: 00 00 beq C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 8: 00 00 beq a: 04 01 mova @r1, r4 ; c: 00 00 beq e: 00 00 beq 10: 0c 00 mova @r0, r12 ; ... C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 (discriminator 1) 22: 00 00 beq C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:26 24: 00 02 bra @r2 ; 26: 00 00 beq 28: 00 00 beq 2a: 01 01 mova @r1, r1 ; 2c: 30 00 00 00 bra 0(r0) ; 30: 03 02 mova @r2, r3 ; 32: 07 00 mova @r0, r7 ; 34: 00 00 beq 36: 00 02 bra @r2 ; 38: 00 00 beq 3a: 00 00 beq 3c: 01 02 mova @r2, r1 ; 3e: 42 00 rrcm.a #1, r2 ; 40: 00 00 beq 42: 04 02 mova @r2, r4 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:28 44: 25 00 00 00 mova &0, r5 ; 48: 05 00 mova @r0, r5 ; 4a: 00 00 beq 4c: 00 01 bra @r1 ; 4e: 0f 00 mova @r0, r15 ; 50: 00 00 beq 52: 00 00 beq 54: 00 00 beq 56: 00 01 bra @r1 ; 58: 9c 89 00 00 sub 0(r9), 1536(r12); 0x0600 5c: 00 06 5e: 63 68 .word 0x6863; ???? 60: 00 01 bra @r1 ; 62: 0f 37 jge $-480 ;abs 0xfffffe82 64: 00 00 beq 66: 00 00 beq C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:29 68: 00 00 beq 6a: 00 07 bra @r7 ; 6c: 00 00 beq 6e: 00 00 beq 70: 01 15 pushm #1, r1 ;16-bit words 72: 37 00 00 00 mova 0(r0), r7 ; 76: 00 00 beq 78: 00 00 beq 7a: 08 63 adc r8 ; 7c: 63 00 01 15 mova r0, &201985 ; 0x31501 80: 37 00 00 00 mova 0(r0), r7 ; 84: 00 00 beq initializer(): 86: 00 00 beq 88: 00 09 bra @r9 ; 8a: 00 00 beq 8c: 00 00 beq 8e: 01 36 jge $-1020 ;abs 0xfffffc92 ... 98: 01 9c cmp r12, r1 ; 9a: aa 00 00 00 adda #0, r10 ; 9e: 0a 61 addc r1, r10 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:31 a0: 00 01 bra @r1 ; a2: 36 aa dadd @r10+, r6 ; a4: 00 00 beq a6: 00 01 bra @r1 ; a8: 5c 00 rrcm #1, r12 ; aa: 04 02 mova @r2, r4 ; ac: 37 00 00 00 mova 0(r0), r7 ; b0: 09 00 mova @r0, r9 ; b2: 00 00 beq b4: 00 01 bra @r1 ; b6: 3a 00 00 00 mova 0(r0), r10 ; ba: 00 00 beq bc: 00 00 beq be: 00 01 bra @r1 ; c0: 9c e4 00 00 xor 0(r4), 1536(r12); 0x0600 c4: 00 06 c6: 61 00 01 3a mova r0, &80385 ; 0x13a01 ca: 37 00 00 00 mova 0(r0), r7 ; ce: 00 00 beq d0: 00 00 beq d2: 0b 00 mova @r0, r11 ; d4: 00 00 beq d6: 00 48 br r8 ; d8: 00 00 beq da: 00 0c bra @r12 ; dc: 01 5c add r12, r1 ; de: 03 f3 .word 0xf303; ???? e0: 01 5c add r12, r1 ; e2: 00 00 beq e4: 09 00 mova @r0, r9 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:33 e6: 00 00 beq e8: 00 01 bra @r1 ; ea: 3e 00 00 00 mova 0(r0), r14 ; ee: 00 00 beq f0: 00 00 beq f2: 00 01 bra @r1 ; f4: 9c 1a 01 00 rpt r12 { movax @r0, r1 ; f8: 00 06 bra @r6 ; fa: 61 00 01 3e mova r0, &81409 ; 0x13e01 fe: 37 00 00 00 mova 0(r0), r7 ; 102: 00 00 beq 104: 00 00 beq 106: 0b 00 mova @r0, r11 ; 108: 00 00 beq 10a: 00 48 br r8 ; 10c: 00 00 beq 10e: 00 0c bra @r12 ; 110: 01 5c add r12, r1 ; 112: 05 f3 and #0, r5 ;r3 As==00 114: 01 5c add r12, r1 ; 116: 23 04 00 00 mova &262144,r3 ;0x40000 11a: 0d 00 mova @r0, r13 ; 11c: 00 00 beq 11e: 00 01 bra @r1 ; 120: 04 aa dadd r10, r4 ; 122: 00 00 beq 124: 00 05 bra @r5 ; 126: 03 00 mova @r0, r3 ; 128: 00 00 beq ... Disassembly of section .debug_abbrev: 00000000 <.debug_abbrev>: qfree(): C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:15 0: 01 11 rra r1 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:23 2: 01 25 jz $+516 ;abs 0x206 4: 0e 13 reti ;return from interupt 6: 0b 03 mova @r3, r11 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 8: 0e 1b 0e 11 rpt #15 { rrax.? r14 ; Reserved use of A/L and B/W bits detected c: 01 12 push r1 ; e: 06 10 rrc r6 ; 10: 17 00 mova @r0+, r7 ; 12: 00 02 bra @r2 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 (discriminator 1) 14: 16 00 mova @r0+, r6 ; 16: 03 0e mova @r14, r3 ; 18: 3a 0b 3b 0b mova 2875(r11),r10 ;0x00b3b 1c: 49 13 calla r9 ; 1e: 00 00 beq 20: 03 24 jz $+8 ;abs 0x28 22: 00 0b bra @r11 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:26 24: 0b 3e jmp $-1000 ;abs 0xfffffc3c 26: 0b 03 mova @r3, r11 ; 28: 0e 00 mova @r0, r14 ; 2a: 00 04 bra @r4 ; 2c: 0f 00 mova @r0, r15 ; 2e: 0b 0b mova @r11, r11 ; 30: 49 13 calla r9 ; 32: 00 00 beq 34: 05 2e jc $-1012 ;abs 0xfffffc40 36: 01 03 mova @r3, r1 ; 38: 0e 3a jl $-994 ;abs 0xfffffc56 3a: 0b 3b jl $-488 ;abs 0xfffffe52 3c: 0b 27 jz $-488 ;abs 0xfffffe54 3e: 19 11 01 12 rra 4609(r9) ;01201 42: 06 40 mov r0, r6 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:28 44: 18 97 42 19 cmp 6466(r7),r8 ;0x01942 48: 01 13 reti ;return from interupt 4a: 00 00 beq 4c: 06 05 mova @r5, r6 ; 4e: 00 03 bra @r3 ; 50: 08 3a jl $-1006 ;abs 0xfffffc62 52: 0b 3b jl $-488 ;abs 0xfffffe6a 54: 0b 49 mov r9, r11 ; 56: 13 02 mova @r2+, r3 ; 58: 17 00 mova @r0+, r7 ; 5a: 00 07 bra @r7 ; 5c: 34 00 03 0e mova 3587(r0),r4 ;PC rel. 0x00e61 60: 3a 0b 3b 0b mova 2875(r11),r10 ;0x00b3b 64: 49 13 calla r9 ; 66: 02 17 popm #1, r2 ;16-bit words C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:29 68: 00 00 beq 6a: 08 34 jge $+18 ;abs 0x7c 6c: 00 03 bra @r3 ; 6e: 08 3a jl $-1006 ;abs 0xfffffc80 70: 0b 3b jl $-488 ;abs 0xfffffe88 72: 0b 49 mov r9, r11 ; 74: 13 02 mova @r2+, r3 ; 76: 17 00 mova @r0+, r7 ; 78: 00 09 bra @r9 ; 7a: 2e 01 3f 19 mova &71999, r14 ;0x1193f 7e: 03 0e mova @r14, r3 ; 80: 3a 0b 3b 0b mova 2875(r11),r10 ;0x00b3b 84: 27 19 11 01 rpt #8 { movax @r1+, r1 ; initializer(): 88: 12 06 mova @r6+, r2 ; 8a: 40 18 97 42 movx.w &0x00119,19(r7) ; 0x00013 8e: 19 01 13 00 92: 00 0a bra @r10 ; 94: 05 00 mova @r0, r5 ; 96: 03 08 mova @r8, r3 ; 98: 3a 0b 3b 0b mova 2875(r11),r10 ;0x00b3b 9c: 49 13 calla r9 ; 9e: 02 18 00 00 rpt #3 { beqx C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:31 a2: 0b 89 sub r9, r11 ; a4: 82 01 01 11 mova #69889, r2 ;0x11101 a8: 01 31 jn $+516 ;abs 0x2ac aa: 13 00 mova @r0+, r3 ; ac: 00 0c bra @r12 ; ae: 8a 82 01 00 sub r2, 1(r10) ; b2: 02 18 91 42 movx.? &0x00018,134400(r1); Reserved use of A/L and B/W bits detected b6: 18 00 00 0d ba: 34 00 03 0e mova 3587(r0),r4 ;PC rel. 0x00ebf be: 3a 0b 3b 0b mova 2875(r11),r10 ;0x00b3b c2: 49 13 calla r9 ; c4: 02 18 00 00 rpt #3 { beqx ... Disassembly of section .debug_loc: 00000000 <.debug_loc>: ... qfree(): C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 8: 01 00 mova @r0, r1 ; a: 5c 00 rrcm #1, r12 ; c: 00 00 beq e: 00 00 beq 10: 00 00 beq 12: 00 01 bra @r1 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 (discriminator 1) 14: 00 5d add r13, r0 ; ... 1e: 01 00 mova @r0, r1 ; 20: 5c 00 rrcm #1, r12 ; ... C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:26 2e: 00 00 beq 30: 00 01 bra @r1 ; 32: 00 5e add r14, r0 ; ... 3c: 01 00 mova @r0, r1 ; 3e: 5d 00 rrcm #1, r13 ; 40: 00 00 beq 42: 00 00 beq C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:28 44: 00 00 beq 46: 00 01 bra @r1 ; 48: 00 5e add r14, r0 ; ... 52: 02 00 mova @r0, r2 ; 54: 7e 00 00 00 mova r0, 0(r14) ; 58: 00 00 beq 5a: 00 00 beq 5c: 00 00 beq 5e: 01 00 mova @r0, r1 ; 60: 5e 00 rrcm #1, r14 ; ... C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:29 6e: 00 00 beq 70: 00 01 bra @r1 ; 72: 00 5b add r11, r0 ; ... 7c: 01 00 mova @r0, r1 ; 7e: 5a 00 rrcm #1, r10 ; 80: 00 00 beq 82: 00 00 beq 84: 00 00 beq initializer(): 86: 00 01 bra @r1 ; 88: 00 5b add r11, r0 ; ... 92: 01 00 mova @r0, r1 ; 94: 5e 00 rrcm #1, r14 ; 96: 00 00 beq 98: 00 00 beq 9a: 00 00 beq 9c: 00 01 bra @r1 ; 9e: 00 5b add r11, r0 ; ... C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:31 b0: 01 00 mova @r0, r1 ; b2: 5c 00 rrcm #1, r12 ; b4: 00 00 beq b6: 00 00 beq b8: 00 00 beq ba: 00 04 bra @r4 ; bc: 00 f3 and #0, r0 ;r3 As==00 be: 01 5c add r12, r1 ; c0: 9f 00 00 00 cmpa #0, r15 ; ... d0: 00 01 bra @r1 ; d2: 00 5c add r12, r0 ; ... dc: 03 00 mova @r0, r3 ; de: 7c 7c subc.b @r12+, r12 ; e0: 9f 00 00 00 cmpa #0, r15 ; e4: 00 00 beq C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:33 e6: 00 00 beq e8: 00 04 bra @r4 ; ea: 00 f3 and #0, r0 ;r3 As==00 ec: 01 5c add r12, r1 ; ee: 9f 00 00 00 cmpa #0, r15 ; f2: 00 00 beq f4: 00 00 beq ... Disassembly of section .debug_aranges: 00000000 <.debug_aranges>: qfree(): C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:15 0: 1c 00 mova @r0+, r12 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:23 2: 00 00 beq 4: 02 00 mova @r0, r2 ; 6: 00 00 beq C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 8: 00 00 beq a: 04 00 mova @r0, r4 ; ... Disassembly of section .debug_line: 00000000 <L0>: C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:15 0: e0 00 adda r0, r0 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:23 2: 00 00 beq 4: 02 00 mova @r0, r2 ; 6: 20 00 00 00 bra &0 ; 0000000a <L0>: C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 a: 01 01 mova @r1, r1 ; c: fb 0e suba r14, r11 ; e: 0d 00 mova @r0, r13 ; 10: 01 01 mova @r1, r1 ; 12: 01 01 mova @r1, r1 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 (discriminator 1) 14: 00 00 beq 16: 00 01 bra @r1 ; 18: 00 00 beq 1a: 01 00 mova @r0, r1 ; 1c: 65 78 subc.b @r8, r5 ; 1e: 74 72 subc.b #8, r4 ;r2 As==11 20: 61 63 addc.b #2, r1 ;r3 As==10 22: 74 2e jc $-790 ;abs 0xfffffd0c C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:26 24: 63 00 00 00 mova r0, &196608 ; 0x30000 28: 00 00 beq 2a: 00 05 bra @r5 ; 2c: 02 00 mova @r0, r2 ; 2e: 00 00 beq 30: 00 03 bra @r3 ; 32: 0e 01 mova @r1, r14 ; 34: 03 08 mova @r8, r3 ; 36: 09 00 mova @r0, r9 ; 38: 00 01 bra @r1 ; 3a: 03 02 mova @r2, r3 ; 3c: 09 00 mova @r0, r9 ; 3e: 00 01 bra @r1 ; 40: 00 02 bra @r2 ; 42: 04 01 mova @r1, r4 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:28 44: 06 03 mova @r3, r6 ; 46: 00 09 bra @r9 ; 48: 00 00 beq 4a: 01 06 mova @r6, r1 ; 4c: 03 01 mova @r1, r3 ; 4e: 09 00 mova @r0, r9 ; 50: 00 01 bra @r1 ; 52: 03 02 mova @r2, r3 ; 54: 09 00 mova @r0, r9 ; 56: 00 01 bra @r1 ; 58: 03 01 mova @r1, r3 ; 5a: 09 00 mova @r0, r9 ; 5c: 00 01 bra @r1 ; 5e: 03 02 mova @r2, r3 ; 60: 09 00 mova @r0, r9 ; 62: 00 01 bra @r1 ; 64: 03 02 mova @r2, r3 ; 66: 09 00 mova @r0, r9 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:29 68: 00 01 bra @r1 ; 6a: 03 01 mova @r1, r3 ; 6c: 09 00 mova @r0, r9 ; 6e: 00 01 bra @r1 ; 70: 00 02 bra @r2 ; 72: 04 02 mova @r2, r4 ; 74: 03 77 .word 0x7703; ???? 76: 09 00 mova @r0, r9 ; 78: 00 01 bra @r1 ; 7a: 03 14 pushm.a #1, r3 ;20-bit words 7c: 09 00 mova @r0, r9 ; 7e: 00 01 bra @r1 ; 80: 03 7f .word 0x7f03; ???? 82: 09 00 mova @r0, r9 ; 84: 00 01 bra @r1 ; initializer(): 86: 00 02 bra @r2 ; 88: 04 01 mova @r1, r4 ; 8a: 03 7f .word 0x7f03; ???? 8c: 09 00 mova @r0, r9 ; 8e: 00 01 bra @r1 ; 90: 03 05 mova @r5, r3 ; 92: 09 00 mova @r0, r9 ; 94: 00 01 bra @r1 ; 96: 03 01 mova @r1, r3 ; 98: 09 00 mova @r0, r9 ; 9a: 00 01 bra @r1 ; 9c: 03 01 mova @r1, r3 ; 9e: 09 00 mova @r0, r9 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:31 a0: 00 01 bra @r1 ; a2: 03 02 mova @r2, r3 ; a4: 09 00 mova @r0, r9 ; a6: 00 01 bra @r1 ; a8: 03 02 mova @r2, r3 ; aa: 09 00 mova @r0, r9 ; ac: 00 01 bra @r1 ; ae: 03 01 mova @r1, r3 ; b0: 09 00 mova @r0, r9 ; b2: 00 01 bra @r1 ; b4: 03 01 mova @r1, r3 ; b6: 09 00 mova @r0, r9 ; b8: 00 01 bra @r1 ; ba: 03 02 mova @r2, r3 ; bc: 09 00 mova @r0, r9 ; be: 00 01 bra @r1 ; c0: 03 01 mova @r1, r3 ; c2: 09 00 mova @r0, r9 ; c4: 00 01 bra @r1 ; c6: 03 01 mova @r1, r3 ; c8: 09 00 mova @r0, r9 ; ca: 00 01 bra @r1 ; cc: 03 02 mova @r2, r3 ; ce: 09 00 mova @r0, r9 ; d0: 00 01 bra @r1 ; d2: 03 02 mova @r2, r3 ; d4: 09 00 mova @r0, r9 ; d6: 00 01 bra @r1 ; d8: 03 01 mova @r1, r3 ; da: 09 00 mova @r0, r9 ; dc: 00 01 bra @r1 ; de: 09 02 mova @r2, r9 ; e0: 00 00 beq e2: 01 01 mova @r1, r1 ; Disassembly of section .debug_str: 00000000 <.debug_str>: qfree(): C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:15 0: 65 78 subc.b @r8, r5 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:23 2: 74 72 subc.b #8, r4 ;r2 As==11 4: 61 63 addc.b #2, r1 ;r3 As==10 6: 74 2e jc $-790 ;abs 0xfffffcf0 C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 8: 63 00 75 6e mova r0, &224885 ; 0x36e75 c: 73 69 .word 0x6973; ???? e: 67 6e addc.b @r14, r7 ; 10: 65 64 addc.b @r4, r5 ; 12: 20 69 addc @r9, r0 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 (discriminator 1) 14: 6e 74 subc.b @r4, r14 ; 16: 00 63 adc r0 ; 18: 68 75 subc.b @r5, r8 ; 1a: 6e 6b addc.b @r11, r14 ; 1c: 00 47 br r7 ; 1e: 4e 55 add.b r5, r14 ; 20: 20 43 br #2 ;r3 As==10 22: 31 31 jn $+612 ;abs 0x286 C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:26 24: 20 35 jge $+578 ;abs 0x266 26: 2e 33 jn $-418 ;abs 0xfffffe84 28: 2e 30 jn $+94 ;abs 0x86 2a: 20 2d jc $+578 ;abs 0x26c 2c: 67 20 jnz $+208 ;abs 0xfc 2e: 2d 4f mov @r15, r13 ; 30: 73 00 71 66 mova r0, 26225(r3); 0x06671 34: 72 65 addc.b @r5+, r2 ; 36: 65 00 77 6f mova r0, &356215 ; 0x56f77 3a: 72 64 addc.b @r4+, r2 ; 3c: 00 69 addc r9, r0 ; 3e: 6e 69 addc.b @r9, r14 ; 40: 74 69 addc.b @r9+, r4 ; 42: 61 6c addc.b @r12, r1 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:28 44: 69 7a subc.b @r10, r9 ; 46: 65 72 subc.b #4, r5 ;r2 As==10 48: 00 6d addc r13, r0 ; 4a: 70 6f addc.b @r15+, r0 ; 4c: 6f 6c addc.b @r12, r15 ; 4e: 73 00 61 64 mova r0, 25697(r3); 0x06461 52: 64 72 subc.b #4, r4 ;r2 As==10 54: 65 73 subc.b #2, r5 ;r3 As==10 56: 73 00 73 65 mova r0, 25971(r3); 0x06573 5a: 63 6f .word 0x6f63; ???? 5c: 6e 64 addc.b @r4, r14 ; 5e: 66 72 subc.b #4, r6 ;r2 As==10 60: 65 65 addc.b @r5, r5 ; 62: 72 00 66 72 mova r0, 29286(r2); 0x07266 66: 65 65 addc.b @r5, r5 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:29 68: 65 72 subc.b #4, r5 ;r2 As==10 6a: 00 43 clr r0 ; 6c: 3a 5c add @r12+, r10 ; 6e: 63 79 .word 0x7963; ???? 70: 67 77 subc.b @r7, r7 ; 72: 69 6e addc.b @r14, r9 ; 74: 36 34 jge $+110 ;abs 0xe2 76: 5c 68 6f 6d addc.b 28015(r8),r12 ;0x06d6f 7a: 65 5c add.b @r12, r5 ; 7c: 6e 72 subc.b #4, r14 ;r2 As==10 7e: 69 70 subc.b @r0, r9 ; 80: 67 5c add.b @r12, r7 ; 82: 53 4f .word 0x4f53; ???? 84: 46 54 add.b r4, r6 ; initializer(): 86: 57 41 52 45 mov.b 17746(r1),r7 ;0x04552 8a: 5c 57 4f 52 add.b 21071(r7),r12 ;0x0524f 8e: 4b 49 mov.b r9, r11 ; 90: 4e 47 mov.b r7, r14 ; ... Disassembly of section .comment: 00000000 <.comment>: qfree(): C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:15 0: 00 47 br r7 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:23 2: 43 43 clr.b r3 ; 4: 3a 20 jnz $+118 ;abs 0x7a 6: 28 53 incd r8 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 8: 4f 4d mov.b r13, r15 ; a: 4e 49 mov.b r9, r14 ; c: 55 4d 20 54 mov.b 21536(r13),r5 ;0x05420 10: 65 63 addc.b #2, r5 ;r3 As==10 12: 68 6e addc.b @r14, r8 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 (discriminator 1) 14: 6f 6c addc.b @r12, r15 ; 16: 6f 67 addc.b @r7, r15 ; 18: 69 65 addc.b @r5, r9 ; 1a: 73 20 jnz $+232 ;abs 0x102 1c: 4c 69 addc.b r9, r12 ; 1e: 6d 69 addc.b @r9, r13 ; 20: 74 65 addc.b @r5+, r4 ; 22: 64 20 jnz $+202 ;abs 0xec C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:26 24: 2d 20 jnz $+92 ;abs 0x80 26: 6d 73 subc.b #2, r13 ;r3 As==10 28: 70 34 jge $+226 ;abs 0x10a 2a: 33 30 jn $+104 ;abs 0x92 2c: 2d 67 addc @r7, r13 ; 2e: 63 63 .word 0x6363; ???? 30: 20 35 jge $+578 ;abs 0x272 32: 2e 33 jn $-418 ;abs 0xfffffe90 34: 2e 30 jn $+94 ;abs 0x92 36: 2e 32 jn $-930 ;abs 0xfffffc94 38: 31 39 jl $+612 ;abs 0x29c 3a: 29 20 jnz $+84 ;abs 0x8e 3c: 35 2e jc $-916 ;abs 0xfffffca8 3e: 33 2e jc $-920 ;abs 0xfffffca6 40: 30 00 00 00 Address 0x00000042 is out of bounds. bra -1(r0) ;PC rel. 0x00041 Disassembly of section .MSP430.attributes: 00000000 <.MSP430.attributes>: C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:15 0: 41 16 popm.a #5, r5 ;20-bit words C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:23 2: 00 00 beq 4: 00 6d addc r13, r0 ; 6: 73 70 .word 0x7073; ???? C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 8: 61 62 addc.b #4, r1 ;r2 As==10 a: 69 00 01 0b mova r0, &592641 ; 0x90b01 e: 00 00 beq 10: 00 04 bra @r4 ; 12: 02 06 mova @r6, r2 ; C:\cygwin64\home\nripg\SOFTWARE\WORKING/extract.c:25 (discriminator 1) 14: 01 08 mova @r8, r1 ; 16: 01 00 Address 0x00000016 is out of bounds. .word 0xffff; ????
