typedef long double real64; class IBase { public: virtual real64 getReal() = 0; }; class Bar : public IBase { public: Bar() : m_real(0) { } virtual real64 getReal(); private: real64 m_real; }; real64 Bar::getReal() { return m_real; } class Foo { public: Foo() { m_bar = new Bar(); } IBase* m_bar; }; Foo& getFoo() { static Foo foo; return foo; } void test() { Foo& foobar = getFoo();; real64 newReal = 1; newReal += foobar.m_bar->getReal(); }
The above sample code produces the following compiler output:
**** Build of configuration Debug for project FW ****
"C:\\ti\\ccsv6\\utils\\bin\\gmake" -j 4 error.obj
'Building file: ../error.cpp'
'Invoking: C2000 Compiler'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --tmu_support=tmu0 --float_support=fpu32 --cla_support=cla1 --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --advice:performance=all -g --define=LARGE_MODEL --define=ARCH28075 --display_error_number --diag_wrap=off --diag_warning=225 --diag_warning=255 --verbose_diagnostics --buffer_diagnostics --gen_func_subsections=on --preproc_with_compile --preproc_dependency="error.pp" --cmd_file="configPkg/compiler.opt" "../error.cpp"
>> ../error.cpp, line 48: INTERNAL ERROR: Decomposition error
This may be a serious problem. Please contact customer support with a
description of this problem and a sample of the source files that caused this
INTERNAL ERROR message to appear.
Cannot continue compilation - ABORTING!
>> Compilation failure
gmake: *** [error.obj] Error 1
**** Build Finished ****
The error occurs in the line:
If I split the line into two lines without the += operator (assign the value to a temporary variable, then add that variable), the code compiles without error.
For me that solves the issue, but I wanted to report it anyway, as the error message suggests.
