IS there any package available for CCS to include the ARM Cortex-M0 target?
If yes, where can i find it on TI website?
Thank you
Thank you
Stephanie,
What device are you using? Typically when creating a project in CCS you select the device that you are using and it will setup the processor cores that are present.
The CCS toolchain does support Cortex M0.
With what ships with CCS by default you could select "Generic CortexM3 Device" in the project wizard and then adjust for M0 afterwards.
To adjust the build settings you would need to right click on your project and select properties and select the option below.
John
