I'm trying to include SFRA in my project.
I'm following the document C2000 Software Frequency Response Analyzer (SFRA) Library & Compensation Designer v1.10 Feb-15.
My doubt is about the warnings below. How to solve this issue?
"../F28035_FLASH_ProjectName.CMD", line 120: warning: no matching section
"../F28035_FLASH_ProjectName.CMD", line 121: warning: no matching section
The warnings are related to the CMD lines below:
ramfuncs : LOAD = FLASHE, //FLASHD,
RUN = RAML0,
LOAD_START(_RamfuncsLoadStart),
LOAD_SIZE(_RamfuncsLoadSize),
LOAD_END(_RamfuncsLoadEnd),
RUN_START(_RamfuncsRunStart),
PAGE = 0
--library=rts2800_ml.lib<fs_mpy.obj>
--library=SFRA_IQ_Lib.lib<SFRA_IQ_INJECT.obj>
--library=SFRA_IQ_Lib.lib<SFRA_IQ_COLLECT.obj>
The CMD file is shown below
_Cla1Prog_Start = _Cla1funcsRunStart;
-heap 0x200
-stack 0x200
// Define a size for the CLA scratchpad area that will be used
// by the CLA compiler for local symbols and temps
// Also force references to the special symbols that mark the
// scratchpad are.
CLA_SCRATCHPAD_SIZE = 0x100;
--undef_sym=__cla_scratchpad_end
--undef_sym=__cla_scratchpad_start
MEMORY
/* Note that the memory allocation below does not create sections as necessary for
the CLA on the F2803x.
PAGE 0:
RAML0 : origin = 0x008000, length = 0x000800 /* on-chip RAM (L0-L1)*/
RAML3 : origin = 0x009000, length = 0x001000 /* data RAM (L3) */
OTP : origin = 0x3D7800, length = 0x000400 /* on-chip OTP */
FLASHH : origin = 0x3E8000, length = 0x002000 /* on-chip FLASH */
FLASHG : origin = 0x3EA000, length = 0x002000 /* on-chip FLASH */
FLASHF : origin = 0x3EC000, length = 0x002000 /* on-chip FLASH */
FLASHE : origin = 0x3EE000, length = 0x002000 /* on-chip FLASH */
FLASHD : origin = 0x3F0000, length = 0x002000 /* on-chip FLASH */
// FLASHC : origin = 0x3F2000, length = 0x002000 /* on-chip FLASH */
// FLASHA : origin = 0x3F6000, length = 0x001F80 /* on-chip FLASH */
FLASHA : origin = 0x3F2000, length = 0x005F80 /* on-chip FLASH */
CSM_RSVD : origin = 0x3F7F80, length = 0x000076 /* Part of FLASHA. Program with all 0x0000 when CSM is in use. */
BEGIN : origin = 0x3F7FF6, length = 0x000002 /* Part of FLASHA. Used for "boot to Flash" bootloader mode. */
CSM_PWL : origin = 0x3F7FF8, length = 0x000008 /* Part of FLASHA. CSM password locations in FLASHA */
IQTABLES : origin = 0x3FE000, length = 0x000B50 /* IQ Math Tables in Boot ROM */
IQTABLES2 : origin = 0x3FEB50, length = 0x00008C /* IQ Math Tables in Boot ROM */
IQTABLES3 : origin = 0x3FEBDC, length = 0x0000AA /* IQ Math Tables in Boot ROM */
BOOTROM : origin = 0x3FF27C, length = 0x000D44 /* Boot ROM */
RESET : origin = 0x3FFFC0, length = 0x000002 /* part of boot ROM */
VECTORS : origin = 0x3FFFC2, length = 0x00003E /* part of boot ROM */
PAGE 1 :
BOOT_RSVD : origin = 0x000000, length = 0x000050 /* Part of M0, BOOT rom will use this for stack */
// RAMM0 : origin = 0x000050, length = 0x0003B0 /* on-chip RAM block M0 */
RAMM0 : origin = 0x000050, length = 0x0007B0 /* on-chip RAM block M0 */
// RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */
dataRAM : origin = 0x008800, length = 0x000800 /* on-chip RAM block L1 */
// RAML2 : origin = 0x008C00, length = 0x000400 /* on-chip RAM block L2 */
// FLASHB : origin = 0x3F4000, length = 0x002000 /* on-chip FLASH */
CLA_CPU_MSGRAM : origin = 0x001480, length = 0x000080 /* CLA-R/W, CPU-R message RAM */
CPU_CLA_MSGRAM : origin = 0x001500, length = 0x000080 /* CPU-R/W, CLA-R message RAM */
SECTIONS
/* Allocate program areas: */
.cinit : > FLASHA, PAGE = 0
.pinit : > FLASHA, PAGE = 0
.text : > FLASHA, PAGE = 0
codestart : > BEGIN PAGE = 0
RUN = RAML0,
PAGE = 0
Cla1Prog : LOAD = FLASHD, //FLASHC, /* Note for running from RAM the load and RUN can be the same */
RUN = RAML3,
LOAD_START(_Cla1funcsLoadStart),
LOAD_SIZE(_Cla1funcsLoadSize),
LOAD_END(_Cla1funcsLoadEnd),
RUN_START(_Cla1funcsRunStart),
PAGE = 0
SFRA_IQ_Data : > RAML3, ALIGN = 64, PAGE = 0
csmpasswds : > CSM_PWL PAGE = 0
csm_rsvd : > CSM_RSVD PAGE = 0
/* Allocate uninitalized data sections: */
.stack : > RAMM0, PAGE = 1
// .ebss : > RAMM1, PAGE = 1
// .esysmem : > RAMM1, PAGE = 1
// .ebss : > RAMM0, PAGE = 1
// .esysmem : > RAMM0, PAGE = 1
// .ebss : > dataRAM, PAGE = 1
.ebss : > RAML3, PAGE = 0
.esysmem : > dataRAM, PAGE = 1
Cla1Data : > dataRAM, PAGE = 1
/* Initalized sections go in Flash */
/* For SDFlash to program these, they must be allocated to page 0 */
.econst : > FLASHA PAGE = 0
.switch : > FLASHA PAGE = 0
/* Allocate IQ math areas: */
IQmath : > FLASHA PAGE = 0 /* Math Code */
IQmathTables : > IQTABLES PAGE = 0, TYPE = NOLOAD /* Math Tables In ROM */
Cla1ToCpuMsgRAM : > CLA_CPU_MSGRAM PAGE = 1
CpuToCla1MsgRAM : > CPU_CLA_MSGRAM PAGE = 1
.reset : > RESET, PAGE = 0, TYPE = DSECT
vectors : > VECTORS PAGE = 0, TYPE = DSECT
/* Uncomment the section below if calling the IQNexp() or IQexp()
functions from the IQMath.lib library in order to utilize the
relevant IQ Math table in Boot ROM (This saves space and Boot ROM
is 1 wait-state). If this section is not uncommented, IQmathTables2
will be loaded into other memory (SARAM, Flash, etc.) and will take
up space, but 0 wait-state is possible.
IQmathTables2 : > IQTABLES2, PAGE = 0, TYPE = NOLOAD
IQmath.lib<IQNexpTable.obj> (IQmathTablesRam)
/* Uncomment the section below if calling the IQNasin() or IQasin()
IQmathTables3 : > IQTABLES3, PAGE = 0, TYPE = NOLOAD
IQmath.lib<IQNasinTable.obj> (IQmathTablesRam)
SECTIONS
/************* DPLIB Sections C28x ************************/
/* ADCDRV_1ch section */
// ADCDRV_1ch_Section : > dataRAM PAGE = 1
/* ADCDRV_4ch section */
// ADCDRV_4ch_Section : > dataRAM PAGE = 1
/* CNTL_2P2Z section */
CNTL_2P2Z_Section : > RAML3 PAGE = 0
CNTL_2P2Z_InternalData : > RAML3 PAGE = 0
CNTL_2P2Z_Coef : > RAML3 PAGE = 0
/* CNTL_3P3Z section */
CNTL_3P3Z_Section : > RAML3 PAGE = 0
CNTL_3P3Z_InternalData : > RAML3 PAGE = 0
CNTL_3P3Z_Coef : > RAML3 PAGE = 0
/*DLOG_4CH section */
DLOG_4CH_Section : > RAML0 PAGE = 0
DLOG_BUFF : > RAML0 PAGE = 0
/*MATH_EMAVG section */
MATH_EMAVG_Section : > RAML0 PAGE = 0
/*PFC_ICMD section*/
PFC_ICMD_Section : > RAML0 PAGE = 0
/*PFC_INVSQR section*/
PFC_INVSQR_Section : > RAML0 PAGE = 0
/* PWMDRV_1ch driver section */
PWMDRV_1ch_Section : > RAML0 PAGE = 0
/* PWMDRV_1chHiRes driver section */
PWMDRV_1chHiRes_Section : > RAML0 PAGE = 0
/* PWMDRV_PFC2PhiL driver section */
PWMDRV_PFC2PhiL_Section : > RAML0 PAGE = 0
/* PWMDRV_PSFB driver section */
PWMDRV_PSFB_Section : > RAML0 PAGE = 0
/* PWMDRV_DualUpDwnCnt driver section */
PWMDRV_DualUpDwnCnt_Section : > RAML0 PAGE = 0
/* PWMDRV_ComplPairDB driver section */
PWMDRV_ComplPairDB_Section : > RAML0 PAGE = 0
/* ZeroNet_Section */
ZeroNet_Section : > RAML0 PAGE = 0
/* PWM_DRV_BOOST_Section */
PWM_DRV_BOOST_Section : > RAML0 PAGE = 0
/* DUPWM_DRV_INV_Section */
DUPWM_DRV_INV_Section : > RAML0 PAGE = 0
/* TimeSlice_Section */
TimeSlice_Section : > RAML0 PAGE = 0
/* GEN_Sin_Cos_Section */
GEN_Sin_Cos_Section : > RAML0 PAGE = 0
/* ADCDRV_8ch_Section */
ADCDRV_8ch_Section : > RAML0 PAGE = 0
/* SEL_3X1MULT_IREF_Section */
SEL_3X1MULT_IREF_Section : > RAML0 PAGE = 0
/* RMS_CALC_AC_Section */
RMS_CALC_AC_Section : > RAML0 PAGE = 0
/* RMS_CALC_DC_Section */
RMS_CALC_DC_Section : > RAML0 PAGE = 0
/* CLE_Section */
CLE_Section : > RAML0 PAGE = 0
/* SUBTRACT_2IN_1OUT_Section */
SUBTRACT_2IN_1OUT_Section : > RAML0 PAGE = 0
/*DLOG_4ch sections*/
DLOG_4ch_Section : > RAML0 PAGE = 0
/*REACT_PWR_Section*/
REACT_PWR_Section : > RAML0 PAGE = 0
/*SOMADOR_3IN_1OUT_Section*/
SOMADOR_3IN_1OUT_Section : > RAML0 PAGE = 0
/*VBLE_Section*/
VBLE_Section : > RAML0 PAGE = 0
/*DCBUS_DEC_Section*/
DCBUS_DEC_Section : > RAML0 PAGE = 0
/*VPVLE_Section*/
VPVLE_Section : > RAML0 PAGE = 0
/*VBUSLIMIT_Section*/
VBUSLIMIT_Section : > RAML0 PAGE = 0
/*SEL_2X1MULT_NO_GAIN_Section*/
SEL_2X1MULT_NO_GAIN_Section : > RAML0 PAGE = 0
/*PROP_CNTL_Section*/
PROP_CNTL_Section : > RAML0 PAGE = 0
The Console is shown below:
**** Build of configuration F2803x_FLASH for project 251016b_DPLibTemplate-F2803x ****
"C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
'Building file: ../ADCDRV_PHB_NS1500_8ch.asm'
'Invoking: C2000 Compiler'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="ADCDRV_PHB_NS1500_8ch.pp" "../ADCDRV_PHB_NS1500_8ch.asm"
'Finished building: ../ADCDRV_PHB_NS1500_8ch.asm'
'Building file: ../Analog.c'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="Analog.pp" "../Analog.c"
'Finished building: ../Analog.c'
'Building file: ../CURRENT_LOOP_ERROR.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="CURRENT_LOOP_ERROR.pp" "../CURRENT_LOOP_ERROR.asm"
'Finished building: ../CURRENT_LOOP_ERROR.asm'
'Building file: ../Comm_Interfaces.c'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="Comm_Interfaces.pp" "../Comm_Interfaces.c"
'Finished building: ../Comm_Interfaces.c'
'Building file: ../DC_BUS_DECOUPLING.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="DC_BUS_DECOUPLING.pp" "../DC_BUS_DECOUPLING.asm"
'Finished building: ../DC_BUS_DECOUPLING.asm'
'Building file: C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/source/DSP2803x_CodeStartBranch.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="DSP2803x_CodeStartBranch.pp" "C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/source/DSP2803x_CodeStartBranch.asm"
'Finished building: C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/source/DSP2803x_CodeStartBranch.asm'
'Building file: C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/source/DSP2803x_GlobalVariableDefs.c'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="DSP2803x_GlobalVariableDefs.pp" "C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/source/DSP2803x_GlobalVariableDefs.c"
'Finished building: C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/source/DSP2803x_GlobalVariableDefs.c'
'Building file: C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/source/DSP2803x_usDelay.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="DSP2803x_usDelay.pp" "C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/source/DSP2803x_usDelay.asm"
'Finished building: C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/source/DSP2803x_usDelay.asm'
'Building file: ../DUPWM_DRV_INV_NS1500.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="DUPWM_DRV_INV_NS1500.pp" "../DUPWM_DRV_INV_NS1500.asm"
'Finished building: ../DUPWM_DRV_INV_NS1500.asm'
'Building file: ../IHM_Interface.c'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="IHM_Interface.pp" "../IHM_Interface.c"
'Finished building: ../IHM_Interface.c'
'Building file: ../PHBNS1500_CNTL_2P2Z.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="PHBNS1500_CNTL_2P2Z.pp" "../PHBNS1500_CNTL_2P2Z.asm"
'Finished building: ../PHBNS1500_CNTL_2P2Z.asm'
'Building file: ../PHBNS1500_CNTL_3P3Z.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="PHBNS1500_CNTL_3P3Z.pp" "../PHBNS1500_CNTL_3P3Z.asm"
'Finished building: ../PHBNS1500_CNTL_3P3Z.asm'
'Building file: ../PHBNS1500_CNTL_3P3Z_RESET.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="PHBNS1500_CNTL_3P3Z_RESET.pp" "../PHBNS1500_CNTL_3P3Z_RESET.asm"
'Finished building: ../PHBNS1500_CNTL_3P3Z_RESET.asm'
'Building file: ../PROP_CONTROLLER.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="PROP_CONTROLLER.pp" "../PROP_CONTROLLER.asm"
'Finished building: ../PROP_CONTROLLER.asm'
'Building file: C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/CNF/PWM_1ch_Cnf.c'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="PWM_1ch_Cnf.pp" "C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/CNF/PWM_1ch_Cnf.c"
'Finished building: C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/CNF/PWM_1ch_Cnf.c'
'Building file: ../PWM_DRV_BOOST_NS1500-DPL-ISR.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="PWM_DRV_BOOST_NS1500-DPL-ISR.pp" "../PWM_DRV_BOOST_NS1500-DPL-ISR.asm"
'Finished building: ../PWM_DRV_BOOST_NS1500-DPL-ISR.asm'
'Building file: ../PWM_DRV_INV_NS1500.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="PWM_DRV_INV_NS1500.pp" "../PWM_DRV_INV_NS1500.asm"
'Finished building: ../PWM_DRV_INV_NS1500.asm'
'Building file: ../ProjectName-CLA_Tasks.cla'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="ProjectName-CLA_Tasks.pp" "../ProjectName-CLA_Tasks.cla"
'Finished building: ../ProjectName-CLA_Tasks.cla'
'Building file: ../ProjectName-DPL-ISR.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="ProjectName-DPL-ISR.pp" "../ProjectName-DPL-ISR.asm"
'Finished building: ../ProjectName-DPL-ISR.asm'
'Building file: ../ProjectName-DevInit_F2803x.c'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="ProjectName-DevInit_F2803x.pp" "../ProjectName-DevInit_F2803x.c"
'Finished building: ../ProjectName-DevInit_F2803x.c'
'Building file: ../ProjectName-Main.c'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="ProjectName-Main.pp" "../ProjectName-Main.c"
'Finished building: ../ProjectName-Main.c'
'Building file: ../REACTIVE_POWER_CALC.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="REACTIVE_POWER_CALC.pp" "../REACTIVE_POWER_CALC.asm"
'Finished building: ../REACTIVE_POWER_CALC.asm'
'Building file: ../RMS_CALC_AC.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="RMS_CALC_AC.pp" "../RMS_CALC_AC.asm"
'Finished building: ../RMS_CALC_AC.asm'
'Building file: ../RMS_CALC_DC.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="RMS_CALC_DC.pp" "../RMS_CALC_DC.asm"
'Finished building: ../RMS_CALC_DC.asm'
'Building file: ../SEL_2X1MULT_IREF.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="SEL_2X1MULT_IREF.pp" "../SEL_2X1MULT_IREF.asm"
'Finished building: ../SEL_2X1MULT_IREF.asm'
'Building file: ../SEL_2X1MULT_NO_GAIN.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="SEL_2X1MULT_NO_GAIN.pp" "../SEL_2X1MULT_NO_GAIN.asm"
'Finished building: ../SEL_2X1MULT_NO_GAIN.asm'
'Building file: ../SEL_3X1MULT_IREF.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="SEL_3X1MULT_IREF.pp" "../SEL_3X1MULT_IREF.asm"
'Finished building: ../SEL_3X1MULT_IREF.asm'
'Building file: ../SOMADOR_2IN_1OUT.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="SOMADOR_2IN_1OUT.pp" "../SOMADOR_2IN_1OUT.asm"
'Finished building: ../SOMADOR_2IN_1OUT.asm'
'Building file: ../SOMADOR_3IN_1OUT.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="SOMADOR_3IN_1OUT.pp" "../SOMADOR_3IN_1OUT.asm"
'Finished building: ../SOMADOR_3IN_1OUT.asm'
'Building file: ../SUBTRACT_2IN_1OUT.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="SUBTRACT_2IN_1OUT.pp" "../SUBTRACT_2IN_1OUT.asm"
'Finished building: ../SUBTRACT_2IN_1OUT.asm'
'Building file: ../SolarHv_DCAC-DLOG_4ch.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="SolarHv_DCAC-DLOG_4ch.pp" "../SolarHv_DCAC-DLOG_4ch.asm"
'Finished building: ../SolarHv_DCAC-DLOG_4ch.asm'
'Building file: ../SolarHv_DCAC-GEN_SIN_COS.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="SolarHv_DCAC-GEN_SIN_COS.pp" "../SolarHv_DCAC-GEN_SIN_COS.asm"
'Finished building: ../SolarHv_DCAC-GEN_SIN_COS.asm'
'Building file: ../VBUSLIMIT_LOOP_ERROR.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="VBUSLIMIT_LOOP_ERROR.pp" "../VBUSLIMIT_LOOP_ERROR.asm"
'Finished building: ../VBUSLIMIT_LOOP_ERROR.asm'
'Building file: ../VBUS_LOOP_ERROR.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="VBUS_LOOP_ERROR.pp" "../VBUS_LOOP_ERROR.asm"
'Finished building: ../VBUS_LOOP_ERROR.asm'
'Building file: ../VPV_LOOP_ERROR.asm'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --include_path="C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" --include_path="C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/C_macros" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/include" --include_path="C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_common/include" --include_path="C:/ti/controlSUITE/libs/app_libs/digital_power/f2803x_v3.4/asm_macros" --include_path="C:/ti/controlSUITE/libs/math/IQmath/v15c/include" --include_path="C:/ti/controlSUITE/development_kits/~SupportFiles/F2803x_headers" --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 --preproc_with_compile --preproc_dependency="VPV_LOOP_ERROR.pp" "../VPV_LOOP_ERROR.asm"
'Finished building: ../VPV_LOOP_ERROR.asm'
'Building target: ProjectName.out'
'Invoking: C2000 Linker'
"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/bin/cl2000" -v28 -mt -ml --cla_support=cla0 -Ooff --advice:performance=all -g --define="_DEBUG" --define="FLASH" --define="LARGE_MODEL" --diag_warning=225 -z -m"ProjectName.map" --stack_size=0x380 --warn_sections -i"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/lib" -i"C:/ti/ccsv6/tools/compiler/c2000_6.4.11/include" -i"C:/ti/controlSUITE/libs/math/IQmath/v160/lib" -i"C:/ti/controlSUITE/libs/app_libs/SFRA/v1_10_00_00/IQ/lib" --reread_libs --xml_link_info="ProjectName_linkInfo.xml" --rom_model -o "ProjectName.out" "./ADCDRV_PHB_NS1500_8ch.obj" "./Analog.obj" "./CURRENT_LOOP_ERROR.obj" "./Comm_Interfaces.obj" "./DC_BUS_DECOUPLING.obj" "./DSP2803x_CodeStartBranch.obj" "./DSP2803x_GlobalVariableDefs.obj" "./DSP2803x_usDelay.obj" "./DUPWM_DRV_INV_NS1500.obj" "./IHM_Interface.obj" "./PHBNS1500_CNTL_2P2Z.obj" "./PHBNS1500_CNTL_3P3Z.obj" "./PHBNS1500_CNTL_3P3Z_RESET.obj" "./PROP_CONTROLLER.obj" "./PWM_1ch_Cnf.obj" "./PWM_DRV_BOOST_NS1500-DPL-ISR.obj" "./PWM_DRV_INV_NS1500.obj" "./ProjectName-CLA_Tasks.obj" "./ProjectName-DPL-ISR.obj" "./ProjectName-DevInit_F2803x.obj" "./ProjectName-Main.obj" "./REACTIVE_POWER_CALC.obj" "./RMS_CALC_AC.obj" "./RMS_CALC_DC.obj" "./SEL_2X1MULT_IREF.obj" "./SEL_2X1MULT_NO_GAIN.obj" "./SEL_3X1MULT_IREF.obj" "./SOMADOR_2IN_1OUT.obj" "./SOMADOR_3IN_1OUT.obj" "./SUBTRACT_2IN_1OUT.obj" "./SolarHv_DCAC-DLOG_4ch.obj" "./SolarHv_DCAC-GEN_SIN_COS.obj" "./VBUSLIMIT_LOOP_ERROR.obj" "./VBUS_LOOP_ERROR.obj" "./VPV_LOOP_ERROR.obj" "C:/ti/controlSUITE/device_support/f2803x/v126/DSP2803x_headers/cmd/DSP2803x_Headers_nonBIOS.cmd" "../F28035_FLASH_ProjectName.CMD" "C:/ti/controlSUITE/libs/math/IQmath/v15c/lib/IQmath.lib" -l"libc.a" -l"rts2800_ml.lib" -l"IQmath.lib" -l"SFRA_IQ_Lib.lib"
<Linking>
warning: build attribute vendor section TI missing in
"C:/ti/controlSUITE/libs/math/IQmath/v15c/lib/IQmath.lib<IQ22div.obj>":
compatibility cannot be determined
"C:/ti/controlSUITE/libs/math/IQmath/v15c/lib/IQmath.lib<IQ24div.obj>":
"C:/ti/controlSUITE/libs/math/IQmath/v15c/lib/IQmath.lib<IQ24sqrt.obj>":
"C:/ti/controlSUITE/libs/math/IQmath/v15c/lib/IQmath.lib<IQmathTables.obj>":
'Finished building target: ProjectName.out'
**** Build Finished ****
