I am having trouble adding the portable implementation of the ED25519 public-key generation(github.com/.../ed25519) in a SimplePeripheral.c project from BLE Stack, using CCSv7:
I have created a folder and added all the files from the ED25519 source there, i have also included its path in Properties>>Include Options
I am wondering that the CC2650 does not have enough memory for implementing the ED25519.
Get this erros:
#10010 errors encountered during linking; "simple_peripheral_cc2650lp_app.out" not built simple_peripheral_cc2650lp_app C/C++ Problem
#10099-D program will not fit into available memory. placement with alignment fails for section ".cinit" size 0x8be8 . Available memory ranges: cc26xx_app.cmd /simple_peripheral_cc2650lp_app/TOOLS line 124 C/C++ Problem
#10099-D program will not fit into available memory. run placement with alignment fails for section "GROUP_1" size 0x985e . Available memory ranges: cc26xx_app.cmd /simple_peripheral_cc2650lp_app/TOOLS line 130 C/C++ Problem
Here goes the console response of the build:
**** Build of configuration FlashROM for project simple_peripheral_cc2650lp_app ****
"C:\\ti\\ccsv7\\utils\\bin\\gmake" -k -j 4 all -O
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/config/app_ble.cfg'
'Invoking: XDCtools'
"C:/ti/xdctools_3_32_00_06_core/xs" --xdcpath="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/packages;C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages;C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/bios_6_45_02_31/packages;C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/uia_2_00_05_50/packages;C:/ti/ccsv7/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.M3 -p ti.platforms.simplelink:CC2640F128 -r release -c "C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS" --compileOptions "-mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path=\"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/target\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc\" --include_path=\"C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc\" --include_path=\"C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162\" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi " "C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/config/app_ble.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring app_ble.xem3 from package/cfg/app_ble_pem3.cfg ...
generating custom ROM library makefile ...
Starting build of library sources ...
making C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/config/src/sysbios/rom_sysbios.aem3 ...
gmake[1]: Entering directory `C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/config/src/sysbios'
gmake[1]: Nothing to be done for `all'.
gmake[1]: Leaving directory `C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/config/src/sysbios'
Build of libraries done.
clem3 package/cfg/app_ble_pem3.c ...
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/config/app_ble.cfg'
'Building file: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/mw/display/Display.c'
'Invoking: ARM Compiler'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/Display/Display.d" --obj_directory="Drivers/Display" --cmd_file="configPkg/compiler.opt" "C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/mw/display/Display.c"
'Finished building: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/mw/display/Display.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx/util.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Application/util.d" --obj_directory="Application" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx/util.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx/util.c'
'Building file: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/mw/display/DisplayDogm1286.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/Display/DisplayDogm1286.d" --obj_directory="Drivers/Display" --cmd_file="configPkg/compiler.opt" "C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/mw/display/DisplayDogm1286.c"
'Finished building: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/mw/display/DisplayDogm1286.c'
'Building file: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/mw/display/DisplayUart.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/Display/DisplayUART.d" --obj_directory="Drivers/Display" --cmd_file="configPkg/compiler.opt" "C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/mw/display/DisplayUart.c"
'Finished building: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/mw/display/DisplayUart.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app/simple_peripheral.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Application/simple_peripheral.d" --obj_directory="Application" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app/simple_peripheral.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app/simple_peripheral.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx/ecc/ECCROMCC26XX.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/ECC/ECCROMCC26XX.d" --obj_directory="Drivers/ECC" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx/ecc/ECCROMCC26XX.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx/ecc/ECCROMCC26XX.c'
'Building file: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/SPI.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/SPI/SPI.d" --obj_directory="Drivers/SPI" --cmd_file="configPkg/compiler.opt" "C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/SPI.c"
'Finished building: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/SPI.c'
'Building file: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/UART.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/UART/UART.d" --obj_directory="Drivers/UART" --cmd_file="configPkg/compiler.opt" "C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/UART.c"
'Finished building: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/UART.c'
'Building file: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/pin/PINCC26XX.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/PIN/PINCC26XX.d" --obj_directory="Drivers/PIN" --cmd_file="configPkg/compiler.opt" "C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/pin/PINCC26XX.c"
'Finished building: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/pin/PINCC26XX.c'
'Building file: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/dma/UDMACC26XX.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/UDMA/UDMACC26XX.d" --obj_directory="Drivers/UDMA" --cmd_file="configPkg/compiler.opt" "C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/dma/UDMACC26XX.c"
'Finished building: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/dma/UDMACC26XX.c'
'Building file: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/spi/SPICC26XXDMA.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/SPI/SPICC26XXDMA.d" --obj_directory="Drivers/SPI" --cmd_file="configPkg/compiler.opt" "C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/spi/SPICC26XXDMA.c"
'Finished building: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/spi/SPICC26XXDMA.c'
'Building file: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/rf/RF.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/RF/RF.d" --obj_directory="Drivers/RF" --cmd_file="configPkg/compiler.opt" "C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/rf/RF.c"
'Finished building: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/rf/RF.c'
'Building file: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/uart/UARTCC26XX.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Drivers/UART/UARTCC26XX.d" --obj_directory="Drivers/UART" --cmd_file="configPkg/compiler.opt" "C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/uart/UARTCC26XX.c"
'Finished building: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/drivers/uart/UARTCC26XX.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/icall_cc2650.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ICall/icall_cc2650.d" --obj_directory="ICall" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/icall_cc2650.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/icall_cc2650.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/app/ble_user_config.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ICallBLE/ble_user_config.d" --obj_directory="ICallBLE" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/app/ble_user_config.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/app/ble_user_config.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/icall.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ICall/icall.d" --obj_directory="ICall" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/icall.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/icall.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info/cc26xx/devinfoservice.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="PROFILES/devinfoservice.d" --obj_directory="PROFILES" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info/cc26xx/devinfoservice.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info/cc26xx/devinfoservice.c'
'Building file: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/mw/extflash/ExtFlash.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Middleware/extflash/ExtFlash.d" --obj_directory="Middleware/extflash" --cmd_file="configPkg/compiler.opt" "C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/mw/extflash/ExtFlash.c"
'Finished building: C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/tidrivers_cc13xx_cc26xx_2_16_01_13/packages/ti/mw/extflash/ExtFlash.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/host/gatt_uuid.c'
'Invoking: ARM Compiler'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="PROFILES/gatt_uuid.d" --obj_directory="PROFILES" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/host/gatt_uuid.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/host/gatt_uuid.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/host/gattservapp_util.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="PROFILES/gattservapp_util.d" --obj_directory="PROFILES" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/host/gattservapp_util.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/host/gattservapp_util.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx/simple_gatt_profile.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="PROFILES/simple_gatt_profile.d" --obj_directory="PROFILES" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx/simple_gatt_profile.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx/simple_gatt_profile.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/iar/config/ccfg_app_ble.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/ccfg_app_ble.d" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/iar/config/ccfg_app_ble.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/iar/config/ccfg_app_ble.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/target/board.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/board.d" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/target/board.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/target/board.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/app/icall_api.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ICallBLE/icall_api.d" --obj_directory="ICallBLE" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/app/icall_api.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/app/icall_api.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx/peripheral.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="PROFILES/peripheral.d" --obj_directory="PROFILES" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx/peripheral.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx/peripheral.c'
'Building file: C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app/main.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/main.d" --obj_directory="Startup" --cmd_file="configPkg/compiler.opt" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app/main.c"
'Finished building: C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app/main.c'
'Building file: ../ed25519/ge.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ed25519/ge.d" --obj_directory="ed25519" --cmd_file="configPkg/compiler.opt" "../ed25519/ge.c"
'Finished building: ../ed25519/ge.c'
'Building file: ../ed25519/sign.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ed25519/sign.d" --obj_directory="ed25519" --cmd_file="configPkg/compiler.opt" "../ed25519/sign.c"
'Finished building: ../ed25519/sign.c'
'Building file: ../ed25519/sha512.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ed25519/sha512.d" --obj_directory="ed25519" --cmd_file="configPkg/compiler.opt" "../ed25519/sha512.c"
'Finished building: ../ed25519/sha512.c'
'Building file: ../ed25519/fe.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ed25519/fe.d" --obj_directory="ed25519" --cmd_file="configPkg/compiler.opt" "../ed25519/fe.c"
'Finished building: ../ed25519/fe.c'
'Building file: ../ed25519/verify.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ed25519/verify.d" --obj_directory="ed25519" --cmd_file="configPkg/compiler.opt" "../ed25519/verify.c"
'Finished building: ../ed25519/verify.c'
'Building file: ../ed25519/sc.c'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/ed25519" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/examples/simple_peripheral/cc26xx/app" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/icall/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/roles" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/dev_info" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/profiles/simple_profile" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/heapmgr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/controller/cc26xx/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/target" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/hal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/osal/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/sdata" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/services/src/saddr" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/components/icall/src/inc" --include_path="C:/ti/simplelink/ble_sdk_2_02_00_31/src/inc" --include_path="C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162" --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ed25519/sc.d" --obj_directory="ed25519" --cmd_file="configPkg/compiler.opt" "../ed25519/sc.c"
'Finished building: ../ed25519/sc.c'
'Building target: simple_peripheral_cc2650lp_app.out'
'Invoking: ARM Linker'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../../../../src/config/build_components.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/build_config.opt" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/app/../../iar/stack/../../ccs/config/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --define=USE_ICALL --define=POWER_SAVING --define=SBP_TASK_STACK_SIZE=700 --define=GAPROLE_TASK_STACK_SIZE=520 --define=HEAPMGR_SIZE=0 --define=Display_DISABLE_ALL --define=BOARD_DISPLAY_EXCLUDE_UART --define=xBOARD_DISPLAY_EXCLUDE_LCD --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_MAX_NUM_ENTITIES=6 --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL --define=MAX_NUM_BLE_CONNS=1 --define=CC2650_LAUNCHXL --define=CC26XX -g --c99 --gcc --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi -z -m"simple_peripheral_cc2650lp_app.map" --heap_size=0 --stack_size=256 -i"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/lib" -i"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.12.0.STS/include" --reread_libs --diag_suppress=10247-D --diag_suppress=16002-D --diag_wrap=off --display_error_number --warn_sections --xml_link_info="simple_peripheral_cc2650lp_app_linkInfo.xml" --rom_model --compress_dwarf=on --unused_section_elimination=on -o "simple_peripheral_cc2650lp_app.out" "C:/ti/simplelink/ble_sdk_2_02_00_31/examples/cc2650lp/simple_peripheral/ccs/config/ccs_linker_defines.cmd" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx/ccs/cc26xx_app.cmd" "./Application/simple_peripheral.obj" "./Application/util.obj" "./Drivers/Display/Display.obj" "./Drivers/Display/DisplayDogm1286.obj" "./Drivers/Display/DisplayUart.obj" "./Drivers/ECC/ECCROMCC26XX.obj" "./Drivers/PIN/PINCC26XX.obj" "./Drivers/RF/RF.obj" "./Drivers/SPI/SPI.obj" "./Drivers/SPI/SPICC26XXDMA.obj" "./Drivers/UART/UART.obj" "./Drivers/UART/UARTCC26XX.obj" "./Drivers/UDMA/UDMACC26XX.obj" "./ICall/icall.obj" "./ICall/icall_cc2650.obj" "./ICallBLE/ble_user_config.obj" "./ICallBLE/icall_api.obj" "./Middleware/extflash/ExtFlash.obj" "./PROFILES/devinfoservice.obj" "./PROFILES/gatt_uuid.obj" "./PROFILES/gattservapp_util.obj" "./PROFILES/peripheral.obj" "./PROFILES/simple_gatt_profile.obj" "./Startup/board.obj" "./Startup/ccfg_app_ble.obj" "./Startup/main.obj" "./ed25519/fe.obj" "./ed25519/ge.obj" "./ed25519/sc.obj" "./ed25519/sha512.obj" "./ed25519/sign.obj" "./ed25519/verify.obj" -l"configPkg/linker.cmd" -llibc.a -l"C:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162/driverlib/bin/ccs/driverlib.lib" -l"C:/ti/simplelink/ble_sdk_2_02_00_31/src/rom/common_rom_releases/03282014/common_rom.symbols"
<Linking>
"C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx/ccs/cc26xx_app.cmd", line 130: error #10099-D: program will not fit into available memory. run placement with alignment fails for section "GROUP_1" size 0x985e . Available memory ranges:
SRAM size: 0x4368 unused: 0x3d9c max hole: 0x3d64
"C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx/ccs/cc26xx_app.cmd", line 124: error #10099-D: program will not fit into available memory. placement with alignment fails for section ".cinit" size 0x8be8 . Available memory ranges:
FLASH size: 0xf000 unused: 0x120 max hole: 0x116
FLASH_LAST_PAGE size: 0x1000 unused: 0xfa8 max hole: 0xfa8
error #10010: errors encountered during linking; "simple_peripheral_cc2650lp_app.out" not built
>> Compilation failure
makefile:203: recipe for target 'simple_peripheral_cc2650lp_app.out' failed
gmake[1]: *** [simple_peripheral_cc2650lp_app.out] Error 1
gmake: *** [all] Error 2
makefile:199: recipe for target 'all' failed
**** Build Finished ****
