Hello Everyone,
Iam trying to integrate a new alg_plugin inside VisionSDK(ver 2.11) for tda3x. I followed the steps mentioned in VisionSDK_UserGuide_BuildSystem doc, still iam facing below issues
1) I have added a new folder my_algo under " \vision_sdk\examples\tda2xx\src\alg_plugins "
2) I have also updated the ALG_LISTS inside cfg.mk file under \vision_sdk\configs.
3)gmake showconfig
Iam unable to see my alg_plugin name on terminal after doing gmake showconfig .Hence my plugin is not correctly added and hence it is not compiling. Am I missing any step???
I tried adding my alg_plugin path inside makefile under " \vision_sdk\examples\tda2xx\src\alg_plugins ",I have updated makefile as follows:
ifeq ($(ALG_surroundview),yes)
include $(MODULE_SRC_BASE_PATH)/commonutils/SRC_FILES.MK
include $(MODULE_SRC_BASE_PATH)/my_algo/SRC_FILES.MK
endif
Now ,my alg_plugin is able to compile.
Is this the correct method to add the plugin, as it was done in the previous versions of VisionSDK???
If not, what is it Iam missing?
Neha
