Hi team,
I recently observed an issue with uninitialzed local variables. Whenever there is a local variable declared and is used without initializing, compiler throws a warning "#551-D Variable "xx" is used before its value is set". The same is not reported for a structure. If some of the elements of a structure are initialzed and some are not initialized ard are used, compiler doesn't throw up any warning.
I observed this on compilers arm_15.12.2.STS and ti-cgt-arm_5.2.5.
Kindly check this and let us know if you agree.
Thanks and Regards,
Vishwanath Reddy.
