Hi, All
After several weeks of work I managed, with the help of the forum, to define a flash memory section in the .cmd file and create a table in the main .c file. But when I compile the program and started debugging, in the flash memory window I see that it does not contain the data I saved.
I need the LUT to generate a sinusoidal signal, directing the table.
I am using the experimental kit for the microcontroller TMS320F28035 and CCS V7.0
Thank you very much for your help
Sebastián
