I am using LCDK6748 .In this,there is 6748.cmd file is present.There are some sections like .text ,.bss etc.How to check which section is having how much memory in the available DDR2
There are two methods to consider.
The first method ... Inspect the map file created by the linker. In a CCS project, this file is usually called name_of_project.map, and is found in the Debug directory, or whatever the name is used for the current build configuration.
The second method ... In CCS, a graphical view of the map file is provided with the Memory Allocation view. Use the menu selection View | Memory Allocation.
Thanks and regards,
-George
