Hi
Can we generate a MISRA C compliance as a separate report using CCSv7.0.
Mallapragada
Hi
Mallapragada
jahnavi mallpragada said:Can we generate a MISRA C compliance as a separate report
Unfortunately, there is no feature of the compiler which does precisely that. You could consider using the option --write_diagnostics_file. This option causes the compiler to emit all the compiler diagnostics to a file with the same base name as the source file, with the extension changed to .err. Perhaps showing those files are free of MISRA diagnostics will be good enough.
Thanks and regards,
-George
