I develop DSP applications (C64x+) under DVSDK 4.00.00.22 (xdctools 3.16.03.36) for the Mistral EVM3530 board and I got the following warning about an unsigned int (32 bits) but this should not appears because it is unsigned !
"main.c", line 462: warning #69-D: integer conversion resulted in a change of sign
g_dwConfigStatus |= (1<<31);
I did a search on Ti forum about it but not find answer. What should I do to avoid this false warning? Should remove all sign conversion checking if this option exist?
Thank you,
Daniel
