• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » WEBENCH® Design Center » Tools - Other Forum » verify output of tps40060 cct
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Ahmed 10245
Posted by Ahmed 10245
on Aug 26 2009 22:52 PM
Intellectual350 points
hello All, I hv the circuit that is supposed to convert 48v 1A input to 5v 6A output using tps40060 , I am trying to confirm it by my own but yet not succeded due to inexpertise in design software, can anybody help me to just confirm whether the circuit gives desired o/p or not .
Waiting for ur reply
Ahmed
switcherpro
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • janier
    Posted by janier
    on Aug 27 2009 17:19 PM
    Verified Answer
    Verified by Rick Downs - WEBENCH Design Center
    Prodigy600 points
    Ahmed, the graphic did not come through in your post.  As I stated in another post, try SwticherPro using TPS40200 and see if it works.
    Regards, Janie
    Report Abuse
    • Reply
  • robin bek`
    Posted by robin bek`
    on Jan 22 2011 19:53 PM
    Prodigy30 points
    Can you respond in the correct.
    Using another seems like a bad response.  If TI doesn't support the chip who will?
    Can you respond in the correct way? Using another part seems like a bad response. If TI doesn't support the chip who will?
    Report Abuse
    • Reply
  • robin bek`
    on Jan 22 2011 20:39 PM
    Prodigy30 points
    Can you respond in the correct way.
    Report Abuse
    • Reply
  • Michael Krasnicki
    Posted by Michael Krasnicki
    on Jan 24 2011 10:09 AM
    Expert3875 points
    Hi Robin,
    TI does support TPS40060. You can obtains answers on this part in the "Non-Isolated DC/DC" forum. However, TI has not added the TPS40060 into SwitcherPro, which is our SMPS design tool. For people who are not familiar with SMPS design, it maybe more convenient to select a part that is integrated in SwitcherPro since SwitcherPro automated many of the design steps. Hence, we suggested that Ahmed take a look at the TPS40200, which is in SwitcherPro.
    In addition to the datasheet, we do provide a PSPICE macro model for the
    TPS40060. It is available here: http://www.ti.com/spicerack
    Michael
    Michael Krasnicki
    Analog eLab
    Texas Instruments
    Report Abuse
    • Reply
  • robin bek`
    on Jan 24 2011 11:02 AM
    Prodigy30 points
    Hi Michael
    Thanks for the response.
    I am hoping you can help me.
    I designed this part into a PCB without doing some initial testing. And I am having problems getting it working.
    Over the weekend I blew a few devices.
    I am a pspice expert, but the orcad version of that model does not seem to work I always get this message.
    Unable to find netlist file:c:\documents and settings\robinb\desktop\tps40060_pspice_transient_model\tps40060_pspice_trans_02apr2009\tps40060-pspicefiles\startup\Startup-tran.out.net
    Since I use the original pspice there maybe compatibility issues. I need to install orcad on a virgin computer.
    Also I was trying to use to switcher pro.
    Do you think that the TPS40055 or tps 400057 is a better model to use in switcher pro? Since it seems to be a lower voltage version of the tps40060.
    Also would you have a spreadsheet that would allow me to change parameters?
    Thanks for your help.
    Report Abuse
    • Reply
  • Michael Krasnicki
    on Jan 26 2011 16:05 PM
    Expert3875 points
    Hi Robin,
    Sorry for the delayed reply.
    The controller/converter PSPICE macro-models that TI releases are all encrypted. They will only work in Cadence SPB/PSPICE 15.7 or higher. Unfortunately, the TINA-TI model for this device is not yet available. We are working on it but I don't have a firm release date. If your company has an NDA with TI, you can request an unencrypted PSPICE model through your sales person. Sometimes the unencrypted models work in old versions of PSPICE.
    I asked one of the apps engineers who is very familar with the 40k line if you can use a TPS40055/TPS40057 SwitcherPro design with a TPS40060. He said "the voltage feed forward / UVLO resistor, the RT resistor, soft-start capacitor, current limit resistor and compensation components will all likely need to be changed". Unfortunately, that is essentially the entire design.
    I am not aware of any spreadsheet calculator for the TPS40060. I would highly recommend that you ask this question on the "Non-Isolated DC/DC" forum. Maybe someone has something.
    Sorry I wasn't more help.
    Michael
    Michael Krasnicki
    Analog eLab
    Texas Instruments
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
