Hi all,
As many users, I have some problems to translate CSD18532Q5B_DNK_8.bxl into allegro 16.6 version.
Is there solution to use ultra librarian .bxl file to generate a .dra/.psm for allegro 16.6 ?
Thanks you
Jeremy Bonhomme
Hi all,
Thanks you
Jeremy Bonhomme
Jeremy,
Ultra Librarian does support Allegro 16.6. We will test CSD185320Q5B_DNK_8.bxl to see if we see issues. There may be problems with older versions of Ultra Librarian reader with thru hole parts failing. What version are you using? Our vendor says latest version is 6.4.56.
Janet
Thank you for your answer. I use 5.3.409 version but I tried with 6.4.45 and I had same results.
Jeremy,
I didn't try it myself but our vendor verified that the CSD185320Q5B_DNK_8.bxl translates to Allegro 16.6 with 6.4.45 version of UltraLibrarian with no issues. Can you try again and send error file?
Janet
Janet,
I tried another time and I have same result. I don't have error message, only miss 'CustomShapes.scr' in directory when I launch .bat file.
Jeremy
Hello
I've the same problem with 'CustomShapes.scr'. I've try to convert some component to Allegro 16.5 with ultra librarian but I've all the time this error,...
I don"t know if the probleme comes from ultra librarian, Cadence or Texas,..
Laurent
