Hi Ti Team,
We are using the LM5119 dual synchronous Buck converter for our application which require 3.3V of 3A and 5V of 4A output , For this we are going with typical Application Schematic given in LM5119 Datasheet.
In our case i can able to get both 3.3V and 5v output but the current capability of both output voltage is less than 1 Amp Even though the all parts values are same as that mentioned in the datasheet of LM5119.
We are using 19V 2Amp supply to powering up this board(LM5119 Dual Synchronous Buck Converter ).
Kindly suggest me regarding this issue.!!!!!
