• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » WEBENCH® Design Center » Simulation and Models Forum » Tina-ti - Question about AC Transfer Characteristcs function for Gain & Phase
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
William Bond
Posted by William Bond
on Mar 01 2012 03:27 AM
Prodigy80 points
Hi all,
I'm new to Tina-ti, so thanks in advance for any help you may be able to give me.
I have simulated the drive stage for an amplifier of a real circuit for a unit which checks conductivity of boiler water.  The unit uses a constant amplitude drive of a 1kH (400mV p-p)  triangle waveform signal into a load, with a feedback loop to ensure that the signal is always constant as the resistance of the  load or wiring losses change (from a few ohms  to several k).
In the simulation I have used a signal generator to produce a triangle waveform of 68mV p-p at I/P of the amplifier, and this produces a constant O/P of 400mV p-p (as the real unit does).
The simulation works fine & gives me the same results as the real unit.  But I need to make some changes to the amplifier, but before I do I would like to try & look at what the phase margin of the loop is.
Here's my issue, if the I/P is 68mV & O/P 400mV, this gives a fixed gain of around 15.92dB and I I double the sig gen amplitude, the O/P doubles accordingly.   But the AC Transfer Characteristics tool (see below), shows the gain as never getting much above 0dB.
The first plot below is for a load is for a load of 220Ω & a simulated cable resistance of 100Ω.  The second plot is for a load of 22Ω & a cable resistance of 10Ω.
Am I being stupid here & not seeing the wood for the trees here ?  So any help would be brilliant.
Hope this is sufficient detail, but I can load the cct if that would help.
Many Thanks
William B
 0435.Forum2.doc
TINA TI Simulation amplifier Phase margin Gain
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Marcos López - WEBENCH Design Center
    Posted by Marcos López - WEBENCH Design Center
    on Mar 01 2012 08:54 AM
    Intellectual1340 points
    Hello William,
            From what you mentioned everything seems ok and you should get a gain of ~16dB. Lets try taking a look at the circuit you have to get a better idea of your setup  and run simulations on my end. Upload your cct and then we can take it from there. Hopefully we can pin down what's making your gain less than 0dB.
    -Marcos
    Report Abuse
    • Reply
  • William Bond
    on Mar 01 2012 09:35 AM
    Prodigy80 points
    5852.BC3250 TDS Drive Stage.zipThanks Marcos,
    Here's the cct file.
    Regards, Bill
    Report Abuse
    • Reply
  • William Bond
    on Mar 01 2012 09:36 AM
    Prodigy80 points
    Regards, Bill
    Report Abuse
    • Reply
  • William Bond
    on Mar 01 2012 09:40 AM
    Prodigy80 points
    Hi Marcos
    Oops, meant to upload a PDF of the cct as well as the Tina.ti Schematic file (which I uploaded twice).
    Regards, Bill
    3225.BC3250 TDS Drive Stage.pdf
    Report Abuse
    • Reply
    on Mar 09 2012 10:51 AM
    Hi William,
            I ran a few sims on your circuit and I think the reason why your AC doensn't seem to match the transient gain is because of the operating point of the transistors TR2 and TR3.
    If you run a DC operating point on the circuit you will notice that these guys are a bit far from being on the verge of the linear region. This creates a big deadzone in your output
    and for a small signal (AC) analysis the simulator might be linearizing your circuit around that deadzone where the transistors have very small gain. If you drive your ckt with a small
    triangle wave you will notice that the output is smaller than the input. Again, this is my main source of suspicion and what I've gotten so far from tinkering with this puppy. If you feel
    like I made a mistake or arrived at a wrong conclusion feel free to repost and we can keep working on the circuit.
    -Marcos
    Report Abuse
    • Reply
  • William Bond
    on Mar 12 2012 03:42 AM
    Verified Answer
    Verified by William Bond
    Prodigy80 points
    Many Thanks Marco,
    That was really well spotted; I think you may be onto something there.
    As it happens, the O/P transisters I used for the simulation are not the devices that are actually used in the product (because I couldn't find them in the transistor selector) in TINA-ti.  They are actually:  TR2 (FMMT497) & TR3 (FMMT597); which are two SOT23 devices from DIODES Inc.
    Perhaps if I had two transtors in the simulation that were a lot closer to the real ones, may be this would make the simulation work ??
    Many Thanks
    Bill
    Report Abuse
    • Reply
  • William Bond
    on Mar 20 2012 03:32 AM
    Prodigy80 points
    Hi Marco
    Based on your suggestion, I searched around & found the correct models for TR2 & TR3, as well as bias diode D12.
    This made a big improvement, as you can see from the attached  AC Analysis & cct
    Although I’m still not quite sure why it only shows the expected gain of around 16dB, at a frequency around 280Hz, when the sig gen at the front of the circuit is running and producing its amplified output at 1kHz ?
    Many Thanks again for your help in this.
    Bill5226.BC3250 TDS Drive Stage (4).zip
    Report Abuse
    • Reply
    on Apr 16 2012 17:28 PM
    William,
            I don't have a clear answer at this moment, I will have to dig into this and find a solution at a later time. I apologize for the inconvenience.
    -Marcos.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
