I need to do some simulation for DC/DC converter. but the TI websit just supply the Spice model for the control IC and i always failure to change to saber model. How can i do with it.
Thanks a lot
Ni,
The PSpice models for power products located in the product folders are encrypted and can only be used in PSpice version 15.7 or higher. If you need to use a different simulator, you will need an unencrypted PSpice model. You will also need to make sure that the software you are using can import PSpice models into it.
You can use this post as a reference for requesting an unencrypted PSpice model:
http://e2e.ti.com/support/development_tools/webench_design_center/f/234/t/36943.aspx
If you have a direct contact at TI for support or sales, they can also make the request for you.
Britt
