HI,
I downloaded the model and tried in my circuit. No matter what sense or MR-Bar voltage is the Reset-Bar stays at around 40 mv. Is there a problem with the model? Did anybody use this model and if so did it work?
Vij
HI,
Vij
Vijay,
Which version of this supervisor are you using? I have verified that it works fine. You can see that from the TINA-TI model for TPS3808G01. This can be found in the product folder under "Tools and Software".
Nikhil
Hi Nikhil,
I tried to use this model and id not work for me and I gave up. Now I have to do worst case analysis for the design we manufacturing and I tried TINA model as you suggested. This no different from PSPICE transient model that I down loaded earlier. One of the things that I noticed is the model does not have a pin to connect the ground. Probably that may be the reason it is not working. I am desperate and can you help me? Thanks.
Vijay
