I'm getting the above error when trying to run in Tina.I know that the PSpice models for power products are encrypted .I need the above TINA-TI models for designs urgently.Thank you for any help.
Cynthia
Cynthia,
We do not currently have a PSpice model for the TPS40077. I will add the UCC27424 to the TINA translation queue.
Britt
Britt,
Thank you for your reply.So does it mean that I cannot use the TPS40077 for simulation or design?
Cynthia
Cynthia,
It means that we do not have a simulation model for the device. So, at this time, you cannot run a simulation of the TPS40077. This should not preclude using the device for a design. The datasheet, EVM, and other technical documents may be used to create a design and verify it's perfromance. The datasheet has step by step instructions on how to use the device and the EVM and its guide show a verified design using the TPS40077.
Regardless of simulation, we do advise that a prototype be built and measured in the lab for any design using TI products. This is the best way to verify the design and how it will perform for your application.
Britt
Britt,
I want to know how long i will wait for the UCC27424 model.
Thank you.
Cynthia
Cynthia,
The UCC27424 TINA-TI model was released to the product folder was today. It should show up after the next web update. Please check back on the product folder in 24-48 hours.
