we're planning to use the LM5116 for a non-isolated power supply. After downloading the pspice transient model and starting the simulation in PSPICE version 16.0, I get the following output:
**** 09/29/14 11:13:34 ******* PSpice 16.0.0 (July 2006) ****** ID# 0 ******** ** Profile: "Startup-trans" [ E:\Notes\PowerSupply\PSPICE\LM5116_PSPICE_TRANS\lm5116_trans-pspicefiles\startup\trans.sim ] **** CIRCUIT DESCRIPTION ****************************************************************************** ** Creating circuit file "trans.cir" ** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS *Libraries: * Profile Libraries : * Local Libraries : .LIB "../../../lm5116_trans.lib" * From [PSPICE NETLIST] section of C:\OrCAD\OrCAD_16.0\tools\PSpice\PSpice.ini file: .lib "nom.lib" *Analysis directives: .TRAN 0 2.2m 0 4n SKIPBP .OPTIONS ABSTOL= 10n .OPTIONS ITL1= 1500 .OPTIONS ITL2= 1000 .OPTIONS ITL4= 1000 .OPTIONS RELTOL= 0.003 .OPTIONS VNTOL= 1u .PROBE V(alias(*)) I(alias(*)) .INC "..\Startup.net" **** INCLUDING Startup.net **** * source LM5116_TRANS R_R4 0 FB 1.21k C_C22 0 VIN 47u IC=0 V_V1 N146406651 0 +PULSE 0 48 100u 10u 10u 1 3 R_Rload 0 OUT {12/5} X_Q2 SW LO CS M1_NMOS R_R3 OUT FB 10.7k C_C11 0 VIN 2.2u C_C6 FB N14640359 1.5n R_R12 VCCX OUT 1 C_C9 0 VIN 2.2u R_R10 N14640359 COMP 39k R_R2 0 UVLO 9.31k C_C7 UVLO 0 1n IC=0 D_D2 UVLO VIN myD27227 C_C8 0 VIN 2.2u X_L1A SW OUT LDCR PARAMS: L=10u DCR=5.8m C_C3 SS 0 10n IC=0 D_D1 VCC N14640207 myD27227 C_C5 FB COMP 15p X_C17 0 OUT CESR PARAMS: C=47u ESR=5m IC=0 X_C19 0 OUT CESR PARAMS: C=47u ESR=5m IC=0 R_R11 0 CS 0.01 X_C18 0 OUT CESR PARAMS: C=47u ESR=5m IC=0 C_C12 0 VIN 1u C_C1 SW N14640207 1u X_C16 0 OUT CESR PARAMS: C=47u ESR=5m IC=0 X_C20 0 OUT CESR PARAMS: C=22u ESR=5m IC=0 R_R15 RAMP VCC 750k R_RS N146406651 VIN 50m R_R1 VIN UVLO 102k R_R16 N14640207 HB 2.2 X_Q1 VIN HO SW M1_NMOS C_C4 0 RAMP 330p C_C2 VCC 0 1u IC=0 C_C10 0 VIN 2.2u C_C14 0 VCCX 1u C_C13 VIN 0 0.1u R_R13 VIN EN 1MEG R_R9 0 RT/SYNC 12.4k X_U1 VIN UVLO RT/SYNC EN RAMP 0 SS FB COMP OUT 0 CS 0 0 LO VCC VCCX HB + HO SW 0 LM5116_TRANS **** RESUMING trans.cir **** .END Unable to find index file lm5116_trans.ind for library file lm5116_trans.lib Making new index file lm5116_trans.ind for library file lm5116_trans.lib Index has 25 entries from 1 file(s). ERROR -- Invalid model Level for Mosfet X_U1.BSIM3N **** 09/29/14 11:13:34 ******* PSpice 16.0.0 (July 2006) ****** ID# 0 ******** ** Profile: "Startup-trans" [ E:\Notes\PowerSupply\PSPICE\LM5116_PSPICE_TRANS\lm5116_trans-pspicefiles\startup\trans.sim ] **** Diode MODEL PARAMETERS ****************************************************************************** myD27227 IS 1.000000E-15 N .1 RS .05 TT 10.000000E-12 JOB ABORTED **** 09/29/14 11:13:34 ******* PSpice 16.0.0 (July 2006) ****** ID# 0 ******** ** Profile: "Startup-trans" [ E:\Notes\PowerSupply\PSPICE\LM5116_PSPICE_TRANS\lm5116_trans-pspicefiles\startup\trans.sim ] **** JOB STATISTICS SUMMARY ****************************************************************************** Total job time = .03
I changed nothing to the original simulation and there seems to be an error in U1. Please advise how to solve this. Thanks in advance.
