when pspice TPS92070 finished export to TINA-TI?
Hello Desi,
As Britt has already mentioned in this post, we have added this to the translation queue. We try to address translations to TINA-TI to the best of our ability. However there are several parts in the queue right now, so it will take some time to get this done. If you want to increase the priority on this, I would recommend that you get in touch with your local field sales office.
Hello Desi,
We have evaluated the feasibility of converting this model to TINA-TI. Usually most of our models are developed using generic building blocks so they can be ported over to PSpice compatible simulators like TINA-TI. Unfortunately, when the TPS92070 was being developed, the simulations were taking a very long time to run so we had to use inbuilt digital gates in PSpice to develop this model. This makes the model incompatible with simulators other than PSpice. Hence we will not be able to convert this to TINA-TI at this time.
Please note that this is not the norm. Majority of our models are TINA-TI compatible and can be converted. If you need help with your evaluation or research with TPS92070, I would recommend that you post your questions about this part in our LED Driver forum
Hi Desi,
I looked around a little, but could not find a similar part that has a TINA-TI model.
FYI... To find similar parts from TI, you can use the parametric search table:
To final all spice models, you can use
On this page you can use keywords like TINA and <Part Number> in the search box to see if a model exists.
LM3444 does not have a PSpice or TINA-TI model. LM3444 is supported by WEBENCH which can help you generate the application for your needs but there is no simulation enabled for this device in WEBENCH either.
If you are interested in using this device in WEBENCH LED Designer, you can look at this video tutorial on how to use this tool.
